LinkBack (284) Thread Tools
Old 23-01-2007, 20:38   1 links from elsewhere to this Post. Click to view. #26
Drives: Hilux surf/MK1 astra
http://www.mk1oc.com/forum/
Hi there "Insaneswede" love the MK1 I am also doing a MK1 up my 1.2s will soon be sporting a 2ltr 16v on bike carbs complete with rebore to 2.1 and possabley kent cams
You might want to check out the link to the MK1OC at the top of this post there are a few of us MK1ers still loving these cars back to glory
Take care and hope to see you on the site soon
Sorry have been told youre already on the mk1oc lovvley car and engine any way.
LIFES TO SHORT TO LIVE SLOW.
Billing pics 2006
madads is offline   Reply With Quote
Old 24-01-2007, 13:05   #27
Drives: Astra MkI
Hello, cool you like my car.
i´m already regged at that forum, but i feel it´s almost 'dead'.
Rgds
Kadett GT/E
Sometimes you are the bug
sometimes you are the windsheild
InsaneSwede is offline   Reply With Quote
Old 27-01-2007, 09:58   #28
Drives: Mk3 Astra
Originally Posted by InsaneSwede View Post
A sat for a while at my friends peterg´s workshop and started to mockup my forthcoming exhaustmanifold.
How long are your primary pipes? Did you determine a set length for tuning? Or was it just how it ended up?
Are you using a 2.2 block also? What did you do on the bottom end?
Any more pics of the 8v head? I've tried a similar chamber, based on the Esslinger 2.3 Pinto ARCA head...
Sorry for all the questions
Stef
Stefan is offline   Reply With Quote
Old 27-01-2007, 17:56   #29
Drives: Astra MkI
Stef
Hello.
The manifold i fabricate will have 550mm primarypipes and 130mm secondary pipes.
It will be in 4-2-1 version to help enhance engings lower rpm, and as for the long tubes is also because of my 272 degree special grinded camshafts.
The bottom end is containing +5mm arrowrods and woessnerpistons
the stroke is 95.4mm and the bore is 87mm , i have also a 10mm studgirdle to help keep things together at this long stroke.
And yes it´s based on an X22XE engine.
too bad the 8v head is so long ago i ported so the other pics i took are gone.
But yes it is similar to that Ford head.
no worries mate on the questions.
rgds
Patrick
Old 27-01-2007, 18:04   #30
Drives: Astra coupe turbo
Thats some mental manifold, going to lose a hell of a lot of heat being so big surely?
mattcoupturbo is offline   Reply With Quote
Old 27-01-2007, 19:24   #31
Drives: Astra MkI
no problem with loosing het.
stainless and wrapped with bandage keeps the heat in.
it might just take about 0.1seconds more to heat it up..
Old 27-01-2007, 19:57   #32
GDN16v's Avatar
Drives: NOVA 1.6 16v + Cav
Love the car, proper old school!! Manifold is a work of art, must of taken some time to do that!!
1.6 16v Nova. Soon to be xe cav!!
GDN16v is offline   Reply With Quote
Old 27-01-2007, 20:01   #33
Drives: 118d,G1.8SE2,C1.2SXi
very smart, what made you choose that balance between inlet and exhaust valve size?
Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
MarkyG is offline   Reply With Quote
Old 28-01-2007, 07:35   #34
Drives: Astra MkI
honestly.. about 2 hrs
but there are no weldings done yet.. just mocking up..
Rgds
Old 28-01-2007, 07:41   #35
Drives: Astra MkI
Through some calculations ofcourse
but honestly more 'gutfeeling'
My 2.3 litre engine wouldn´t have any 'upper' rpm scale with std valvesizes.
the thought about my engine is that it should be a 'heaviley' tuned NA engine.
and then turbo on that (Almost like todays WRC engines)
My calculations is that it would produce easily 230hp with no boost at this state.
and that is on fairly low rpms,, somewhere around 6000rpm.
it might get hard to get proper gasflow/speed you might think when running this big valves.
But my calculations and gutfeeling tells me that increased volume in engine would have reached Mach1 quite quickly with std dimensions.(no good)
Hope thats a good answer
Rgds
Old 28-01-2007, 10:32   #36
Drives: corsa c20let
wall ways had soft spot for the mk1 astra looking good
rich.21 is offline   Reply With Quote
Old 28-01-2007, 11:10   #37
Drives: Corsa Tbo n Prelude
Incredible project, nothing like it in the uk.... would love to see it in the flesh.
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 02-02-2007, 10:27   #38
Drives: Astra MkI
Thanks guys..
here´s a quick piccie of yesterdays work..
rgds
Old 02-02-2007, 10:44   #39
Drives: Astra mk3 GSI
dude wow, loving mk1 astra and your pics are just simply awesome...
Originally Posted by stevenwoody View Post
never seen a UFO!!!! but i have seen a UFN (unidentified flying naan) in a curry house one night that was spectacular
NIFFER022 is offline   Reply With Quote
Old 03-02-2007, 09:09   #40
Drives: Astra MkI
finished trigger disc.
Old 03-02-2007, 12:04   #41
Drives: Nova c16xe,Calibra
Can't believe I haven't looked at this thread until now. It's absolutely awesome, I'll definately be pointing others in the direction of this thread.
Keep up the great work
1.6 16v Throttle-bodied Nova
193bhp @ 7977rpm, 13.85s 1/4 mile, 5.36s 0-60mph
dhdev is offline   Reply With Quote
Old 03-02-2007, 22:43   #42
Drives: Astra MkI
Thanks mate
here´s a couple of pics of todays work:
i also started to tack some welds on the manifold.. but i didn´t remember how i taped it up..
so when i got home to view my pics from the other day.. i have routed them wrong *LOL*
so no pics on that today
cheers!
Old 03-02-2007, 23:07   #43
Drives: 1.4bar = 356bhp :-)
the inlet manifold is the sexiest item. any more pics of it at different angles etc ?
price to make another ?
leesturbo is offline   Reply With Quote
Old 04-02-2007, 16:33   #44
Drives: Astra MkI
Hello..
Browse around in my photobucket.. it might be some pics there.
http://i93.photobucket.com/albums/l69/Wetterskog/
at the moment i´m really pissed off.
my plans for the outlet manifold has just been junked.. it wont fit at all.
i´m over 8cm short of space upwards against hood.... fock!
Old 04-02-2007, 16:59   #45
Hello..
just go with the easy nissan 200 manifold ,
it works very well as used by plenty of ppl now!
and it is compact and puts the turbo in a nice postion?
Old 04-02-2007, 17:21   #46
Rick Draper's Avatar
Drives: 2.2bar = 500bhp :-)
Is that a AP racing twin plate clutch? Looks like it is?
Losers and cheats do win, just ask Lewis Hamilton and mclaren
Rick Draper is offline   Reply With Quote
Old 04-02-2007, 19:11   #47
Drives: Astra MkI
Hi again.,.. my turbosetup is 'backwards' i got turboinlet on the left side,(battery side)
so 'Nissan' Won´t fit.
and i got some obsession of making everything myself
Old 04-02-2007, 19:13   #48
Drives: Astra MkI
hi!
almost.. it´s a Sachs twinplate 200mm '960Nm' clutch.
bought it very cheap, made for Saab.. changed the hubs in the discs, this way it was very cheap.
Old 04-02-2007, 20:17   #49
Are you using Toyota running gear? Looks mint. How did you go about making a adapter plate for the gearbox to the engine, any pics?
Old 04-02-2007, 20:50   #50
Jimbo's Avatar
Drives: The wife up the wall
This would be of great interest to me and many many others........
Clicky link for rebuild thread..I am the 5th dan black belt grand master of the sacred dojo of "Muppetsport" Wax on, wax off, Engine out, engine in.......Quote: Daley..My funking helmet STINKS man!
Jimbo is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/293172-insaneswedes-astra-mki.html
Posted By For Type Date
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 07-01-2009 12:07
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 03-01-2009 11:49
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 30-12-2008 12:20
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 27-12-2008 16:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2008 04:02
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 19:40
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 17:13
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 16:26
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 22-12-2008 13:04
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-12-2008 15:34
Alice - Rechercher VIDEOS CALIBRA 700CV This thread Refback 13-12-2008 19:25
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 01-12-2008 14:38
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 30-11-2008 17:32
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 29-11-2008 19:52
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 24-11-2008 06:47
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 10:20
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 09:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-11-2008 06:50
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 19-11-2008 08:55
Calibra Club Estonia This thread Refback 05-11-2008 22:18
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-11-2008 17:27
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 02-11-2008 10:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-10-2008 23:15
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-10-2008 19:11
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 19-10-2008 11:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 11-10-2008 15:48
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-09-2008 18:41
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 29-09-2008 18:01
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 28-09-2008 20:58
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 25-09-2008 22:14
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 19-09-2008 18:35
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-09-2008 07:14
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 13-09-2008 18:55
