Page 15 of 39 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... LastLast
Results 351 to 375 of 972
Thread: InsaneSwede's Astra MKI
  1. #351
    Aug 2006
    sunny swad, derby
    mk3 astra turbo
    its a toyota celica gt one i think he was recalling?
    Quote Originally Posted by elitedriver View Post
    see, now even i didn't pay that much attention, but even i know it's a toyota box......... first page, first post or two.......
    Go back to relpying to every thread..
    Quote Originally Posted by 16vastraturbo View Post
    and didnt see that.. is pages ago...
  4. #353
    Oct 2002
    Sweden
    Astra MkI
    A small mod i did yesterday.
    now the coils fits with std VW loom underneeth cover:
    and as you might have guessed, I´m installing the loom as we speak.
    The loom is taken from the same VW as the coils.
    just stripped it and it fits almost perfectly with some rerouting.
    and a little bonus.. it´s 'silver' wires is the loom.
    will make a very nice and light loom.
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  5. #354
    Oct 2002
    Sweden
    Astra MkI
    Thougt id write up a full engine spec for you guys now when it´s defenitive.
    X22XE block and crankshaft.
    strengthened with 'concrete' and 'girdlescrews' at the top of the block
    Bored to 87.00mm
    small mods done to oilsystem to increase flow.
    Headstuds modified to M12 thread with helicoil inserts.
    95.4mm stroke
    87mm woessners with full skirt.
    10.5-1 compressionratio
    148mm Arrowrods with special bearings to block off 'oilsquirt' to make more ridgid oilfilm
    Girdle for the mainbearings made in 10mm steel
    Special windagetray
    Uprated oilpump for more flow and with steelgears and nylonvalve.
    Lightened flywheel with 200mm Sachs twinplate clutch speced for 960Nm
    Fully balanced with special triggerdisc on pulley.
    The head is equipped with this spec:
    34.5mm inlet valves Flows 308 cfm at 28" and 13mm lift
    31mm outlet valves Flows 28x cfm at 28" and 13mm lift
    272 camshafts with extreme acceleration on the 'ramps' to make as much open valves as possible during 272 degrees.
    Double valvesprings
    Sbdev chromemolly retainers
    Bronze guides
    Special inletmanifold
    Special outletmanifold
    Special camsprockets
    Engine management:
    DTA S60pro
    4 coils
    1680cc bosch injectors
    Aeromotive regulator
    Rons fuelpump(mechanical)
    Turbosetup:
    Garrett GT3582r with tial exhausthousing 0.82 A/R
    Tial 44mm wastegate
    GreddY Type-R BOV
    Ford RS 500 Intercooler
    Everymod is made by myself without balancing and boring block to 87.00mm
    Rgds
    Kadett GT/E
  6. #355
    MIGClub Member donvaux's Avatar
    Jul 2005
    pontypool, s.wales
    Corsa VXRArctic, Combo
    that is absolutly gorgeous mate
  7. #356
    Why the vw bits? Is that just so you can run the 4coilpacks that sit on the plugs?
  8. #357
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    wow thats some spec, a real piece of engineering!
    what's the estimated power goin up to with the new manifold?
  9. #358
    Oct 2002
    Sweden
    Astra MkI
    Yes exactly.
    and as i stripped the loom i saw the 'superthin' cables and you know all what that mean,,,
    so there was no hesitation to choose the enemys loom *lol*
    Kadett GT/E
  10. #359
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by rc View Post
    I aim too max out the Turbo.
    It might be hard to reach 700hp+ as the world record are for GT3582R as my engine wont rev that high to produce big numbers.
    But i hope for a trainpulling torque instead.
    But.. i´m hoping in power for about 600-650 happy ponnies
    Rgds
    Kadett GT/E
  11. #360
    Oct 2002
    Sweden
    Astra MkI
    and YEAH!!!... photobucket seems to have problems with my folder.
    seems that i have maxed out the freebie abonnemang
    Kadett GT/E
  12. #361
    Oct 2002
    Sweden
    Astra MkI
    something like this
    and now a close pic of one of the welds on the exhaustmanifold:
    A little lesson:
    its VERY important to NOT having any 'ditches' besides the weld.
    this will attract cracks to build up in them.
    It´s not matter if it will happen it´s matter of when.
    Mine welds maybe aren´t the most beatuiful welding in the world.
    but i have no 'ditches'
    i maybe dunno the word for 'ditch'
    It is the thing that runs besides a countryroad and it flows water in them.
    Rgds
    Kadett GT/E
  13. #362
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    looking awesome as ever!
    you just about have 'ditch' right tbh, not really a better word to describe what you are describing that i can think of, welds look ace! do you purge the inside of the tube with gas while you weld too to help smooth the inner welds?
    SHoNkyOpELs.de
  14. #363
    Quote Originally Posted by InsaneSwede View Post
    Yes exactly.
    Ah cool, thank you.
    Why did you go for that kinda coil pack? over the vx one?
  15. #364
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Now long now mate
    Gonna be some very interesting rsults form this i think. The compression being so high is gonna make drive really nice off boost then go absolutly ballistic once on boost.
    10.5:1 is scary high though, too high for my liking...even on ethanol
    Think Mark Shead is still the record holder for the 35r,was on an evo, 736hp sounds familiar
    "THE ROB"
  16. #365
    Jan 2002
    southampton
    sm2'd, T3'd let nova
    ditches, we call it under cut over here
    [quote]The Simps;
    If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
  17. #366
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Rs1 View Post
    Now long now mate
    Yes it´s quite scary as one of the first in Sweden to go that high in compression.
    But we have a couple of dragracing hayabusas in sweden and they run totally mental with high compression and E85 fuel.
    That is interesting enough to test it myself
    Mark Shead and this evo?
    Where to read more of him and the car?
    Rgds
    PAtrick
    Kadett GT/E
  18. #367
    Oct 2002
    Sweden
    Astra MkI
    Ah cool, thank you.
    Well..
    I might be misinformed.
    but isn´t that coilpack on later astras 'wastefire' setup?
    and as i got an highcompression engine i need all the juice i can get to every certain cylinder.
    Wastefire has a problem in high pressures. the coil ignites two cylinders and one of them ignites an 'empty' cylinder with 'no pressure'
    that means the spark has less resistance to fire the 'wrong' cylinder.
    Rgds
    Kadett GT/E
  19. #368
    Oct 2002
    Sweden
    Astra MkI
    Yes i used gas at the inside of the pipes when welding.
    otherwise you got a lot of areas to start cracks in there too.
    Rgds
    Kadett GT/E
  20. #369
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by dan-j View Post
    Learning something every day
    tnx.
    Kadett GT/E
  21. #370
    Well..
    Rgds
    Ah i get you, i wasnt sure if the vw ones worked the same, i'm guessing they dont, as you need all the power to fire in to each bore at a time.
    Very cool dude, you're cleanly a man in the know.
  22. #371
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    stunning
    The cake is a lie :(
  23. #372
    Aug 2006
    sunny swad, derby
    mk3 astra turbo
    how big are them boost pipes?
    looks very smart tho
  24. #373
    Jan 2002
    southampton
    Realy is a stunning build!, it all looks awsome!
    [quote]The Simps;
  25. #374
    Aug 2006
    sunny swad, derby
    mk3 astra turbo
    that purple connecter bit that joins the air filter to the intake pipe, where can you get these from becuz ive been searching every where but cant seam to find them anywhere???
  26. #375
    Mar 2005
    Ho Chi Minh City
    Honda Cb250
    He probably made it out of a yogurt pot
    Two chavs, Dave and Bob race their Novas over a cliff to see who hits the bottom first...who wins? Society.
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
