Page 11 of 39 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 251 to 275 of 972
Thread: InsaneSwede's Astra MKI
  1. #251
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by astragsi View Post
    all that power from standard LET pistons carnt see them lasting too long unless they are forged??
    great figures tho, what inlet is that engine running. any pics/vids??
    Yes it´s standard Mahle pistons, The LET engine is equipped with some fine little fellas as standard. almost race ready ones..
    They can handle about ~600hp before i recomend shifting them.
    He is running Std inlet manifold with 'EDS' pressurepipe on the throttlebody.
    I don´t got any pics of engine as there aren´t much to see. *lol*
    but i got an piccie of the actual car.
    Swedens cleanest cally,,, *period* (no one else comes near)
    I mocked up a cally in photoshop for him. he fell in love and built one exactly like it.
    Rgds
    Patrick
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
    Feb 2005
    harlow essex
    into lamp posts
    Quote Originally Posted by InsaneSwede View Post
    Yes it´s easier.
    But then you run into an another problem.
    the area of the runners i can buy here in sweden has a lot more inside then it is possible to grind out of std inlet.
    You have to buildup with weld to get around that problem.
    Rgds
    Patrick
    i get you. either way takes time so your way is probably best.
    your mates cally is mint
  4. #253
    Macclesfield
    www.Retrobike.c
    Why do you not take a standard manifold, remove the runners at the flange but leave the stock water pipe setup in place and then weld from that point back?
    Back in the scene
  5. #254
    Mar 2004
    whitby
    single turbo rx7
    Yes it´s easier.
    Rgds
    Patrick
    lol rick or maybe you are still right as i dont properly understand atm lmao
    i miss my vauxhalls breaking down
  6. #255
    May 2005
    north east
    nova turbo b reg
    swede speed or what thought you swede created volvo turbo monster now ya doing this cheeky weapon
    read first page and checked pic s make joint to check all 11 pages out now lmao
    more info and pics of that beast
    top work
    dont hate me cause you aint me !!!!!!!!!!!!!!!!!!!!!!!!!
    dont hate ...............................appreciate
  7. #256
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Quote Originally Posted by corsatdave View Post
    top work
    You sure you didnt have a few joints beofre you wrote that
    lmao
    "THE ROB"
  8. #257
    Oct 2002
    Sweden
    Astra MkI
    top work
    Thanks for having my car as eyecandy to the joint *lol*
    However guys.. this is the finished inletmanifold:
    dirty
    The throttlebody used is from Volvo 960, very compact and ~66mm big
    Rgds
    Patrick
    Kadett GT/E
  9. #258
    Suffolk
    335d E90
    Very posh!
    DRIZZ
    DEVELOPMENTS
  10. #259
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    looks great!
    can see why the water pipe is such a headache, SBD manifolds make it in two pieces, with a seperate pipe that bolts to a flange on the underneath of the lump off the back of the manifold, they might even do you the pipe seperately
  11. #260
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Patrick on the bottom of the mani...well on the entry into it, is that plate welded on one of those that............blows up/out should there be a nitrous fault? Or is there a much simpler explanation,lol?
    "THE ROB"
  12. #261
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Rs1 View Post
    Is it not just a flat thick surface that can be tapped for vacuum pipes?
    Back in the scene
  13. #262
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Ah, your probably right Rick.
    I'm not just inventing things though, there are such plate that are deisgns to blow, not seen one though.
    "THE ROB"
  14. #263
    Macclesfield
    www.Retrobike.c
    Can i ask what make of head gasket you use on you big bhp let's over there? Also what sort of boost levels are you running?
    Back in the scene
  15. #264
    Oct 2007
    Finland
    Very nice project you have here, respect!
    Can I ask about that Cally, is turbo what he uses this; http://www.extremepsi.com/store/cust...roductid=17270 , and what are the proper specs for that?
    We are also building Kadett D LET with my girlfriend´s brother, and thinking what size of turbo we should have for 500hp from the crank. We are making about same kind of engine what that cally has. Here you can watch pictures about our project (and read if you understand finish.. ); http://www.opelclubfinland.fi/forum/...a292231dea88b4
    Keep on going, and good luck for your project! And thanks if it doesn´t bother you to ask my question!
  16. #265
    windsor
    cavalier turbo, fiat
    i want one how much you chargeing
  17. #266
    Dec 2003
    NEWCASTLE
    NOVA 1.6 16v + Vectra GSI
    InsaneSwede - manifold looks well made, nice progress!
    looks great!
    You mean this one!
    Elbow is held on by 2 small m4 bolts (iirc) with a seal!
    1.6 16v Nova. Something newer!!
  18. #267
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    That inlet plenum is awesome. Great work.
  19. #268
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Rick Draper View Post
    That is correct.. we choosed to hide all the vaccum pipes underneeth for cleaner looks.
    Kadett GT/E
  20. #269
    Oct 2002
    Sweden
    Astra MkI
    Ofcourse you can.
    I´m running a slightly modified Z20let gasket with M12 headstuds (standard is M11)
    an another good combination is Cometic and Arp´s
    I use my mod as i wanted to test something new.(and cheaper)
    Rgds
    Kadett GT/E
  21. #270
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Adam Knight View Post
    How much are you paying?
    send a pm,
    Rgds
    Kadett GT/E
  22. #271
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by GDN16v View Post
    Thanks
    Kadett GT/E
  23. #272
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by CraigGreen View Post
    Thank you Craig
    Kadett GT/E
  24. #273
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by jeffgordon View Post
    Yes.. that´s the one ,, SC44 we modded it just a little to make sure it keeps up with the work.
    The 360 bearing isn´t screwed tight when shipped, we fixed that.
    I´m sorry to say that i can´t understand a single word from finish.
    But it depends a little on what pricetag you are willing to pay.
    I should recomend a Garrett GT 3071R for maximal spool etc etc.
    but otherwise this SC44 can do the job, but it is at it´s very last breath.
    Maybe if you go Ethanol fuel it can pump this amount of power all day long.
    But on fuel i would recomend a turbo with bigger Turbine, the compressor in SC44 does the job. but the turbine is restrictive.
    Rgds
    Patrick,,
    Nice station wagon by the way
    Kadett GT/E
  25. #274
    Jan 2003
    Lanarkshire
    Corsa Sport 1.6 16v
    Absoloutly awesome work m8 , just read from start to this point here and all i can say is wow!!! keep up the immense work m8 and hats off to you keeping a log on here and updating us all with pics and info etc
    White Corsa sport - de chavving begins!!
  26. #275
    Oct 2002
    Sweden
    Astra MkI
    Nelson: Thanks for the words
    this wekkend thou,, i haven´t done much on the car.
    I have to set the house ready for a long hard and cold winter.
    But i have cranked the engine to get oilpressure, worked as a charm.
    A tip fory you guys if you want higher flow in oilfilter.
    Use from Chevrolet with 'vortech' V6 engine -99
    This one fits directly but have a bigger filterarea and volume.
    And got my self a run in a friends Audi S2 that i have modified the head in.
    656hp and ~700Nm+ is one hell of a beast to run around in the streets.
    locked middlediff and rear diff the car went crazy at 1.9bar..
    Heck.. we were all over the street....
    Kadett GT/E
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
