WRGB06 story complete on our website.
We are getting ready to do it again! We will be in Wales next week preparing for the rally. The car has gone through a makeover. The specs are now:
Specs on the car:
Astra OPC Rally Car
Group N3
Team: Kickastra
www.kickastra.com
Driver/Co-driver: Adrian Linton / Jonathan Linton
Sponsors: Ravensden PLC
www.ravensden.co.uk
Engine Type: X20XER
Bore/Stroke: 86.00 x 86.00 mm
Engine Capacity: 1,998 cc
Max Power: 165PS / 118kW @ 6,500 RPM
Max Torque: 19,2kgm / 188Nm @ 4,300 RPM
Engine Management: Std. Siemens Simtec 70 - Reflashed
Weight: 1,130kg (160kg removed!)
Transmission: F23 with Hewland dog-engagement close-ratio gear kit
Drexler plate LSD
Ratios:
1st 2.54
2nd 1.80
3rd 1.44
4th 1.22
5th 1.04
Reverse 3.31
Final Drive: 4.429
Performance (Std. Car):
Max Speed (mph) 136
0-60mph (secs) 8.2
Exhaust: Sandtler stainless steel group N motorsport system with BRAID FIA-homologated catalytic converter
Safety:
- FEV FIA Plumbed-in Extinguisher
- OMP FIA Handheld Extinguisher
- Sabelt FIA Harnesses
- Autolec Electronic Cut-Out Switch
- Carbon Fibre Door Panels
Chassis:
- Sparco FIA-Homologated Cr-Mo Multi-point Weld-in Roll Cage
Suspension:
- Front: AVO (
www.avouk.com) 40mm inverted insert double-adjustable with remote cannister - special Kickastra design for >8" travel
- Rear: AVO (
www.avouk.com) single adjustable
Brakes:
- Tarmac: 308mm front / 264mm rear
- Gravel: 308mm front / 264mm rear
Wheels/Tyres:
- Tarmac: 7.5J x 17 / Dont know yet!
- Gravel: 6.5J x 15 Special Revolution Wheels / Silverstone S525 15/62 R15
