Oh and also I sorted headlight flash![]()
www.shonkyopels.de
kewl
www shonkyopels de
nice work Rob![]()
rear bumper mount looks heavyMy rear bumper is held on with 2 10mm screws at each end so no metal
What welding needs doing on it? Whens the engine going in?![]()
Need to weld the roll cage gussets in. Engine will be going in ASAP, just reluctant to throw it all in to take out to fit the new gearbox!
www.shonkyopels.de
Big thanks to Dave GSiT, CF plug cover received, Beer and burgers at Billing again![]()
www.shonkyopels.de
So todays work... I ended up using my van and trailer to bring the car home so I could crack on with the welding. I fitted the gussets. Wish I took the seats out as they really got in the way. Oh well all done now
Gussets on A pillar stich welded in (Haven't got gas and couldn't be arsed getting any so non gas mig welding ftw, came out ok)
Primmed with Zinc primer, Don't care how the welds looked, haven't ground them back or anything.
A and B pillar in, painted matt black, I love how they look, make it look more 'RACE' like!
More to follow... Don't wanna do a massive post that can't be posted... TBC
www.shonkyopels.de
So then it was on to polish the new wings and the rest of the car. There was a visible blackness to the whole paintwork, especially the A and B pillars. So I got my 'detailing' cap on, and pulled out my Porter Cable (PC) and bag of polishes waxes etc (must be like £500+ in there) I used menzena Light polish (Cutting) and then Megs gold class watered down for a quick wax.
Here you can see the blackness on the paintwork from where there was once a windscreen seal.
Drivers side polished and that, wing isn't the shiniest, you can see it's not a great finish, but it's the same colour AND from far (on track) you can't see it
Passenger side
Backside
One error I did make though:
Was concentrating on a big bit of carbon, and the pads was also on the wing, oh well not bothered not that visible and it'll do!
I also learnt a new way to clean the polycarbs. I thought I was going to have to get new front, as the we're not very seethru.
Before: Notice the black brown.
After:
Even removed the scratches I had. It was a case of give it a go, if it FAILS then I needed new ones anyway. It didn't fail though
Drivers side.
I then moved onto painting the scuttle. Not looking good TBH, the Zinc primer reacted on two coats, however third was ok when I took it back. Will see how it is.
and to finish off some randoms:
www.shonkyopels.de
Next on the list:
Get windscreen fitted
Fit rest of polycarbs
polish bonnet and boot
FIT ENGINE
Remove tyres from wheels and redo them and ft new tyres.
then it's just lil niggly things![]()
www.shonkyopels.de
what lovely gussets you have![]()
www.shonkyopels.de
Those polys came out awesome mate!! good progress with the rest of the car aswell![]()
www shonkyopels de
looks so much better Rob![]()
Looking good
Come build mine lmao
looking very good mate, looking forward to seeing it in it's former glory![]()
Quality chap, what did you use on the polycarbs?
Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!!
Coupe is looking good in the background too![]()
What did you use on the poly carbs?
Loving the cage tagging plate, look awesome!
Did you flat the wings or just polish them?
Looking good dude.
