Page 10 of 228 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 60 110 ... LastLast
Results 226 to 250 of 5681
Thread: Spanishfly's Garage, now with added garlic.
  1. #226
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Just been removing paint to weld the cage in (Is there actually any benefit) Run out of bolts
    Coilovers STILL not here so can't move on to that!
    www.shonkyopels.de
    Oct 2002
    Actually just decided i'm gonna get the angle grinder to start cutting annoying metal! Vx must of made these cars for 4/5 people they have rear seat mounts!!!!
    www.shonkyopels.de
  4. #228
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    lol, gotta love removeing paint, you using a wire wheel? make sure you make some nice spreader plates for that cage mate just prdered my rose joints for my tie bars, so should ne able to start making them next week
  5. #229
    Oct 2002
    Sweet matey! i've used washers atm Would making a plate out of 2mm or 3mm be better? Is there much point welding it!? While writting this my shocks turned up
    This is gonna sound ghey, how do you remove the seat mounts WITHOUT creating holes? I don't want to drill the spot welds and leave holes! Do you just cut it till it's somewhat flush?
    www.shonkyopels.de
  6. #230
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    cut them flush or get a spot weld drill, has a flat bottom and a pin to guide it so it will only go through one skin pain in the arse doing spotwelds though, so some of my brackets are fully off, some cut flushlmao
    as for the cage, i would bolt it in on the legs, but tag it to the shell on the a and b pillars, but you can even make these points bolt in if you use the original seatbelt mounts on the b pillar and make a captive nut setup in the a pillar
    the spreader plates need to be 2mm minimum, and be a lot bigger than the rear arch feet and front cage legs, the ones on the sill need a foot making that links to the sill and the floor, kinda stepped if you see what i mean, also do yourself a favour and weld the nuts on the back of plates for the roll hoop feet and on the inner plate for the rear arch you normally get with the cage, makes your life alot easier!
  7. #231
    Oct 2002
    Nice one Lee. Pm sent!
    www.shonkyopels.de
  8. #232
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    no worries, just ask if you need any help/advice
  9. #233
    Oct 2002
    You know I will do! Actually if ya wanna be my technical helpline wanna pm me your number lmao
    www.shonkyopels.de
  10. #234
    Oct 2002
    The sexiness arrived! Word of WARNING to all, if you want coilovers all round you need the kit pt number that ends in 'E' and not 'D'. I have the 'd' one and therefore have to send back the rears and get the ones I want! First looks and I have the say they look awesome!I've had Leda coilovers on the mk3 and mk2 leda shocks yet these LOOK better quality. Of course once fitted its where it matters!
    My eccentric top mounts look sexy too... only prob with them is when you pick them up there so light A very good kit also. Will be fitting the bearing tomorrow, and will prob start the fitting of the front stuff also mark out approx where the rear turrets will go!
    www.shonkyopels.de
  11. #235
    Oct 2002
    Oh and also you get an individual print out of how the shock performed on the test
    www.shonkyopels.de
  12. #236
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    plenty of pics needed of them coilovers being fitted!
    Looking awesome!
    How much were they?
  13. #237
    Oct 2002
    Well the kit (GHA310D) on raldes is 405 plus the vat... turns out thats for the fronts with normal rear set up... for an extra £40-50 (iirc) you can get the full coilover kit (GHA310E). I will have alot of pics, tomorrow may start putting them on, or continue with the boring paint removal... any bets what I do tomorrow.... lmao
    www.shonkyopels.de
  14. #238
    Oct 2002
    Oh and they give ya a big slag of a sticker Not sure where it will go! It's large
    www.shonkyopels.de
  15. #239
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    Coilovers are stunnin
    well im working half day tommorow and then its rush rush rush to get the nova loomed up and running!
  16. #240
    Dec 2003
    Luton
    ? yes I do thank you
    ooooooooh my knickers are getting all damp!!
    I'll be round about 10 tomorrow homie, 10:30 if I get real lost again lmao
  17. #241
    Oct 2002
    Quote Originally Posted by Beenie View Post
    Yo shizle! Sounds good Gotta get the F28 out and ready Someone is picking it up morrow Gotta remove linkage and front mount
    I'll prob start on car around 9-ish!
    Yes Rob they are, I keep stroking them, kinda wanna keep them as an expensive ornament!lmao
    www.shonkyopels.de
  18. #242
    Oct 2002
    Oh by the way people, I thought I may state that the standard rear set up GAZ shocks are also great, I just want the extra adjustment! They come with dust boots as std!!!
    www.shonkyopels.de
  19. #243
    let me know what the coilovers are like dude..
  20. #244
    Oct 2002
    will do matey, will update on here. Lee has them FITTED on his, worth asking him, or you searching second opinion?
    www.shonkyopels.de
  21. #245
    Aug 2001
    West Midlands
    Nova Xe Tbs/Nitrous
    are you as sexy as the car mate. just thought id ask?
    Quote Originally Posted by broster
    no more slippages, so its either run out of oil, or we fixed it
  22. #246
    didnt know lee had them...
    will have to have a ride in both...
    have found a few coilovers to be very bouncey even on hard...bar my fks...
  23. #247
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    my old ones were bloody hard even on soft setting but the car did handle superb with them on!
  24. #248
    Suffolk
    335d E90
    Quote Originally Posted by ctunnicliffe01 View Post
    Erm??
    DRIZZ
    DEVELOPMENTS
  25. #249
    Oct 2002
    www.shonkyopels.de
  26. #250
    Oct 2002
    I'll give ya a ride in the car. You can try out the suspension on route to the dogging hotspot of your choice lmao
    When it's done feel free to ask for an outing
    www.shonkyopels.de
  1. 28-05-2011, 10:17
  2. 14-04-2011, 18:53
  3. 16-01-2011, 19:39
  4. 05-11-2010, 05:56
  5. 20-09-2010, 18:52
  6. 22-08-2010, 22:10
  7. 22-08-2010, 21:00
  8. 22-07-2010, 03:11
  9. 18-06-2010, 09:21
  10. 14-04-2010, 20:34
  11. 09-04-2010, 20:01
  12. 08-04-2010, 18:29
  13. 04-04-2010, 11:01
  14. 29-03-2010, 11:19
  15. 25-03-2010, 00:31
  16. 19-03-2010, 14:06
  17. 18-03-2010, 13:19
  18. 12-03-2010, 09:46
  19. 26-02-2010, 18:34
  20. 12-02-2010, 09:48
  21. 09-02-2010, 23:12
  22. 06-02-2010, 15:22
  23. 01-01-2010, 15:21
  24. 20-12-2009, 19:35
  25. 10-12-2009, 18:26
  26. 28-11-2009, 20:07
  27. 16-11-2009, 11:57
  28. 15-11-2009, 12:47
  29. 21-10-2009, 20:29
  30. 06-07-2009, 14:33
  31. 03-07-2009, 18:24
  32. 01-07-2009, 11:36
  33. 26-06-2009, 16:17
  34. 26-06-2009, 16:17
  35. 24-06-2009, 12:03
  36. 24-06-2009, 09:14
  37. 24-06-2009, 00:46
  38. 23-06-2009, 23:16
  39. 23-06-2009, 22:10
  40. 23-06-2009, 21:17
  41. 23-06-2009, 20:06
  42. 23-06-2009, 20:04
  43. 23-06-2009, 19:43
  44. 23-06-2009, 19:30
  45. 23-06-2009, 19:13
  46. 23-06-2009, 19:09
  47. 10-06-2009, 19:53
  48. 10-06-2009, 15:55
  49. 17-04-2009, 00:05
  50. 30-03-2009, 22:42
  51. 30-03-2009, 11:54
  52. 23-03-2009, 07:28
  53. 21-03-2009, 14:59
  54. 20-03-2009, 20:30
  55. 20-03-2009, 18:38
  56. 08-03-2009, 11:44
  57. 05-03-2009, 17:19
  58. 05-03-2009, 09:41
  59. 05-03-2009, 09:18
  60. 03-03-2009, 20:37
  61. 02-03-2009, 17:32
  62. 01-03-2009, 11:07
  63. 10-02-2009, 22:08
  64. 08-02-2009, 17:28
  65. 05-02-2009, 16:37
  66. 31-01-2009, 15:19
  67. 30-01-2009, 22:32
  68. 26-01-2009, 16:36
  69. 23-01-2009, 16:59
  70. 17-01-2009, 19:06
  71. 10-01-2009, 00:42
  72. 09-01-2009, 21:00
  73. 09-01-2009, 15:54
  74. 09-01-2009, 10:41
  75. 09-01-2009, 10:21
  76. 08-01-2009, 16:04
  77. 04-01-2009, 22:08
  78. 03-01-2009, 10:24
  79. 02-01-2009, 21:54
  80. 01-01-2009, 19:00
  81. 29-12-2008, 11:02
  82. 27-12-2008, 16:10
  83. 23-12-2008, 07:31
  84. 22-12-2008, 23:59
  85. 22-12-2008, 15:03
  86. 22-12-2008, 13:20
  87. 22-12-2008, 01:28
  88. 21-12-2008, 10:54
  89. 17-12-2008, 15:29
  90. 16-10-2008, 23:18
  91. 15-10-2008, 17:17
  92. 15-10-2008, 14:52
  93. 15-10-2008, 12:12
  94. 14-10-2008, 23:19
  95. 14-10-2008, 23:15
  96. 22-09-2008, 21:34
  97. 22-09-2008, 13:26
  98. 23-07-2008, 15:35
  99. 22-07-2008, 22:08
  100. 22-07-2008, 21:58
  101. 12-07-2008, 18:22
  102. 12-07-2008, 02:01
  103. 07-07-2008, 23:04
  104. 07-07-2008, 19:26
  105. 07-07-2008, 19:25
  106. 07-07-2008, 11:04
  107. 07-07-2008, 09:09
  108. 07-07-2008, 06:53
  109. 07-07-2008, 02:30
  110. 06-07-2008, 22:21
  111. 06-07-2008, 22:06
  112. 06-07-2008, 21:17
  113. 06-07-2008, 20:57
  114. 06-07-2008, 20:55
  115. 06-07-2008, 19:52
  116. 06-07-2008, 19:46
  117. 14-05-2008, 21:47
  118. 14-05-2008, 21:38
  119. 28-04-2008, 10:23
  120. 11-04-2008, 16:52
  121. 08-04-2008, 00:11
  122. 07-04-2008, 23:09
  123. 07-04-2008, 21:24
  124. 07-04-2008, 21:24
  125. 07-04-2008, 20:38
  126. 07-04-2008, 20:29
  127. 07-04-2008, 20:27
  128. 23-10-2007, 16:37
Tags for this Thread
