09-11-2006, 22:39
#176 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
Update on engine plan... Z18XE or C16XE/X16XE is winning the stakes! For now I will nos the C16SE, well it'll be rude not to! |
09-11-2006, 22:40
#177 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| 18 |
09-11-2006, 22:42
#178 | | Regional Co-ordinator
| 18... havent seen one in a nova yet..
__________________ Quote: |
09-11-2006, 22:43
#179 | | MIGWeb User
| go watch some rallycross and you will, its the one beating everything else  |
09-11-2006, 22:45
#180 | | Regional Co-ordinator
| sweet,cant find much of it on tv... |
09-11-2006, 22:46
#181 | | MIGWeb User
| men and motors have it occasionally, and its in world motorsprt and maxpower on skysports, season finishes this weekend though |
09-11-2006, 22:46
#182 | | Regional Co-ordinator
|  i got my eyes on a Z18... what else had them? modern vectras? astras?? as corsa 'sri' carries a premium! |
09-11-2006, 22:47
#183 | | MIGWeb User
| astra |
09-11-2006, 22:50
#184 | | Regional Co-ordinator
| How bout Vectra B 1.8 SRI 130... z18xe anyone? |
09-11-2006, 22:54
#185 | | MIGWeb User
| not 100% on the differences tbh, but i think any 18 will do considering what you'll do to it eventually(tbs etc etc) |
09-11-2006, 22:56
#186 | | MIGWeb User
Join Date: Oct 2003 Location: glasgow/oban Drives: like its a hire car
| vecs big block im pretty sure
__________________ Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!" |
09-11-2006, 22:57
#187 | | Regional Co-ordinator
| I will have to more than likely TB it as there fly-by-wire? |
09-11-2006, 22:57
#188 | | MIGWeb User
| Quote:
Originally Posted by alistairolsen vecs big block im pretty sure | ah, well obviously that matters, whoops  |
09-11-2006, 22:58
#189 | | MIGWeb User
| Quote:
Originally Posted by spanishfly I will have to more than likely TB it as there fly-by-wire? | fly by wire is well doable, but you have to run the whole loom from the donor, tbs rock anyways! |
10-11-2006, 07:05
#190 | | Regional Co-ordinator
| Quote:
Originally Posted by lee303 fly by wire is well doable, but you have to run the whole loom from the donor, tbs rock anyways! | plan will be tbs anyhow! They sound all grizzly and mean business  |
10-11-2006, 10:22
#191 | | MIGClub Member
| is there any point running an 18? I mean it's the same size and I'm guessing the same weight as a 20 but the 20 would have more power.
__________________ My Audi S3 for sale
"migweb" - the place where your opinion can go f**k it's self! |
10-11-2006, 12:56
#192 | | Regional Co-ordinator
| Quote:
Originally Posted by Beenie is there any point running an 18? I mean it's the same size and I'm guessing the same weight as a 20 but the 20 would have more power. | no the Z18XE small block is the same size as the 14/16xe   |
10-11-2006, 13:08
#193 | | MIGClub Member
| o rly?
i never knew that, i always thought from 18 upwards was a big block
go! 18! go! |
10-11-2006, 14:22
#194 | | MIGWeb User
Join Date: May 2003 Location: Dominican Republic Drives: theonly GTE16v in DR
| Quote:
Originally Posted by spanishfly no the Z18XE small block is the same size as the 14/16xe   | whats the specs on those? bore/stroke gen please
__________________ '88 Pontiac Lemans (Astra mk2 GTE) 173.4 bhp/160lb.ft 20XEJ, ET: 14.81@94mph, 60ft: 2.29 Daewootech.com forum admin |
10-11-2006, 16:07
#195 | | MIGWeb User
| slightly bigger bore than the 16 and more stroke, makes a lovely engine from what i'm being told, revvy like the 16 but more torque |
10-11-2006, 17:03
#196 | | MIGClub Member
| Longer stroke and revvy?
If I had an engine with a long stroke I'd concentrate on making it give as much torque as possible, instead of aiming for maximum revs.
That's short stroke/big bore territory.
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
10-11-2006, 17:05
#197 | | MIGWeb User
| yes, but thats the thing with this 18, apparently its still very revvy, its not a huge increase in stroke over the 1600 if you think about it |
10-11-2006, 17:43
#198 | | MIGWeb User
Join Date: Apr 2006 Location: Atherstone Drives: 2 many 2 list
| The corsa c uses a small block 18?? |
10-11-2006, 17:50
#199 | | MIGClub Member
Join Date: Apr 2002 Location: High Wycombe Looks@: Drives: The White Wonder
| all depends on the standard of the OE crank / rods and what not as well.
For instance Vauxhall straight 6 12v has bonkers 95mm bore and 69.8mm stroke. But it hates revving over 6500rpm because its all nastily cast bottom end cant handle it, and its not what the breathing has been set up to do either.
__________________ LURF - The proper pronunciation for "love". Especially emphasized during karaoke sessions.
"Oh, my lurf, my laling, I hunger for your tush, a long and lonely time..." Total Carlton (Carlton Forum) |
10-11-2006, 18:27
#200 | | Regional Co-ordinator
| Go 18 go  |
