03-06-2008, 16:58
#1901 | | MIGWeb User
| Re: Nova 1.0 build (Trackday car) why did you have the new tunnels put on? did you do it because there was not enough clearance?
chris |
03-06-2008, 18:49
#1902 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
| Re: Nova 1.0 build (Trackday car) Quote:
Originally Posted by jedi12 why did you have the new tunnels put on? did you do it because there was not enough clearance?
chris | yes not enough clearance for big tyres. |
24-06-2008, 09:04
#1903 | | MIGWeb User
Join Date: Apr 2006 Location: Atherstone Drives: 2 many 2 list
| Re: Nova 1.0 build (Trackday car) any up dates mate?? |
24-06-2008, 09:45
#1904 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Going to the ring on thursday in the coupe! After that i'll be working on the nova... |
02-07-2008, 17:58
#1905 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Ok this sunday the nova will be getting worked on! Are people who read this thread interested in the coupe? If so I may combine the two in one thread. I did have a Coupe build thing going on but as I don't work on it all the time, I don't bother updating. So shall I keep ya updated on that too? |
02-07-2008, 18:17
#1906 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| Re: Nova 1.0 build (Trackday car) |
02-07-2008, 18:33
#1907 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Hell yeah, both need there own threads..
__________________ Quote: |
02-07-2008, 18:56
#1908 | | MIGClub Member
Join Date: Jul 2001 Location: Suffolk Drives: Vectra GSi & A4 1.8t
Originally Posted by Benn Hell yeah, both need there own threads.. | So you mean no then
__________________ DRIZZ
DEVELOPMENTS |
02-07-2008, 22:40
#1909 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Ok will do a catch up on it! As it will be the car going to Billing I will be doing a few bits! |
06-07-2008, 18:39
#1910 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Todays NOVA update!
Once again thanks to Lee... I'm sure he and Brian will agree my x member was quite shocking! TBH it was lucky my recent crap happened! Pictures will hopefully explain all.
My crossmember once we removed the rad...
Yes they are holes, and the was only one corner of metal left. I'm sure you'll agree EVEN standard mount would of had this problem!
This was the better side!
With a lil play with the pliers this was unvealed!
As you can see it hasn't happened in the last few months! So hopefully it's sorted once and for all (I don't doubt it is for a second). Basically method of repair was, cut away crap metal, fit some box section and re plate. I feel my crossmember must be in the top 5 for strength now
Finished article is...
Drag spec support.
Removed the heavy wing bolts, and have 4 bolts (rather than 10) holding the bumper on! Also removed std oil cooler that did nowt  |
06-07-2008, 18:46
#1911 | | MIGWeb User
Join Date: Feb 2002 Location: West Yorks Drives: Corsa Sport 2.0 XE
| Re: Nova 1.0 build (Trackday car) good work spanish. |
06-07-2008, 18:48
#1912 | | Regional Co-ordinator
Originally Posted by wazpaz good work spanish. | Yeah did a good job of the bolts didn't I.
(Lee done the rest  )
LEt me know about the springs you have. Get a pic!  |
06-07-2008, 18:52
#1913 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Did you not weld around the tca mont bit plates? Mine where a bit crappy there too, think most novas are from rads leaking over the years.. |
06-07-2008, 18:54
#1914 | | MIGWeb User
| Re: Nova 1.0 build (Trackday car) nice pics mate, am very glad we fixed that today tbh, whether it had my tie bars on it or not, it was pretty bad under there  oh and yes, you did a great job of the wing bolts, and dont make a bad cup of tea either!
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
06-07-2008, 19:05
#1915 | | Regional Co-ordinator
Originally Posted by lee303 nice pics mate, am very glad we fixed that today tbh, whether it had my tie bars on it or not, it was pretty bad under there  oh and yes, you did a great job of the wing bolts, and dont make a bad cup of tea either!  |
Benn think your right about the rads! |
06-07-2008, 19:18
#1916 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
Originally Posted by Benn Did you not weld around the tca mont bit plates? Mine where a bit crappy there too, think most novas are from rads leaking over the years.. |  corsas do that too, mine was getting scabby so i plated them up.
those now look bomb proof  |
06-07-2008, 19:33
#1917 | | Regional Co-ordinator
Originally Posted by spanishfly
Benn think your right about the rads! | Quote:
Originally Posted by GBE86  corsas do that too, mine was getting scabby so i plated them up.: | Its a place no one looks at.. till like you you remove the rad or tca and start poking witha screw driver.. before you know it your plating the world. |
06-07-2008, 19:34
#1918 | | Regional Co-ordinator
Originally Posted by GBE86 those now look bomb proof  | agreed Quote:
Originally Posted by Benn Its a place no one looks at.. till like you you remove the rad or tca and start poking witha screw driver.. before you know it your plating the world. |   |
06-07-2008, 19:35
#1919 | | Regional Co-ordinator
| Re: Nova 1.0 build (Trackday car) Else you know shes strong as funk now, good work.
Is your tca prob all sorted then? |
06-07-2008, 19:59
#1920 | | Regional Co-ordinator
Originally Posted by Benn Else you know shes strong as funk now, good work.
Is your tca prob all sorted then? | seems so.  |
06-07-2008, 20:14
#1921 | | MIGWeb User
| Re: Nova 1.0 build (Trackday car) What prompted you to check them in the first place rob?
was it when you started modding the tiebars the other month? |
06-07-2008, 20:17
#1922 | | Regional Co-ordinator
Originally Posted by wazpaz What prompted you to check them in the first place rob?
was it when you started modding the tiebars the other month? | Yes basically the tie bars showed the problem! Glad they did!!! |
06-07-2008, 20:17
#1923 | | Regional Co-ordinator
Originally Posted by spanishfly seems so.  | Good good. Quote:
Originally Posted by spanishfly Yes basically the tie bars showed the problem! Glad they did!!! | Did they start to pull away, or was the tca a prob? |
06-07-2008, 20:31
#1924 | | Regional Co-ordinator
Originally Posted by Benn Good good.
Did they start to pull away, or was the tca a prob? | There was noticable play at PV (hence I did a 14.3 (or whatever) and went home early). Basically it was the crossmember moving! Would like to emphasis infact THERE WAS NOTHING WRONG WITH LEE'S KIT! Just my shonky nova  ! I would happily have him do me another set in the future if I ever crashed this nova! If there is need for further proof of this, view the vid of Lees nova at the ring, he hits every curb! |
06-07-2008, 20:44
#1925 | | MIGClub Member
Join Date: Dec 2001 Location: East Sussex Drives: Cav with TB's & lots
| Re: Nova 1.0 build (Trackday car) I refuse to believe the facts and it HAS to be Lee's kits that caused the problem.
Oh yeah hang on... there's some facts now....
Oh funk it - I'll still blame it on Lee's kit.
Good fix lads and obviously a heads up for all nova (and corsa) owners to have a good prod about in those areas (especially the trappy gob-****e ones).  |
