LinkBack (53) Thread Tools
Old 02-05-2008, 13:38   2 links from elsewhere to this Post. Click to view. #1751
Drives: nova 1.8 16v on tbs
Re: Nova 1.0 build (Trackday car)
cos they were mega cheap and the dunlop is a stiff sidewalled tyre too
shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008
lee303 is offline   Reply With Quote
Old 02-05-2008, 15:43   #1752
Drives: Nova Coupe
55 will be interesting! lol
The Simps is offline   Reply With Quote
Old 02-05-2008, 16:20   #1753
Drives: A Lowly Nova
Fair do's, if the sidewalls are nice & stiff then the profile shouldn't be a massive problem on a light car like the nova, just the ride height to deal with clearing the front arches, good to get them cheap as well, bonus.
Are replacements cheap or will you only have the 4 to play with at the nice price?
I'm going to go for medium compound AO48R's purely because I know they are a stock tyre so can be replaced no problem & proven to perform on a light car like the nova.
I've made my mistakes buying cheap remould types (Indysport - TR's) & then (too hard) Yokohama slicks, both were a waste of time & I should have just bitten the bullet & bought the right tyres for the car in the first place.
Good to see you have another option available to you, hope it works out well.
ANY COLOUR YOU WANT AS LONG AS IT'S WHITE.
essexgte is offline   Reply With Quote
Old 02-05-2008, 18:55   #1754
Drives: Nova Coupe
I've just picked up a set of A048r's in soft compound part worn to have a try with. Never done a trackday with a performance tyre so looking forward to seeing the difference.
Will it matter that much if I go for a good standard road tyre on the back?
Old 02-05-2008, 21:07   #1755
it may well make the balance of the car a little wayward, but tbh the rear wheels are mainly there to stop the bumper hitting the floor so you'll be ok
Old 03-05-2008, 08:03   #1756
Regional Co-ordinator
spanishfly's Avatar
Drives: ACT Nova TBs & less
Well he 55 profile, make the overall diameter 17mm more. I really need to go up around 20mm on my suspension anyway (To make the lower arms sit flat) If I can't get these on the car, i'll just sell them on, i'm sure to get my money back
South-Eastern Coordinator
My nova
www.shonkyopels.de (now working lmao)
spanishfly is offline   Reply With Quote
Old 03-05-2008, 10:46   #1757
Drives: Nova Coupe
thats the spirit!
lee, the way I looked at it is that if the back end steps out its not a bad thing!
Old 07-05-2008, 14:23   #1758
spanishfly's Avatar
Well todays extra HOT work. I've had to retire now due to heat. Although I did start at 9
Todays mission: Fit following parts:
400 lb rear springs,
275 lb Front springs,
Oil pressure sender and gauge,
Oil temp sender and guage,
Rubber mount Facet,
Seperate switch for facet,
Fit SBD type C manifold.
Well to start of on a bad, I didn't fit the type C, going to do it when I can get the rest of the system made too.
New 7" 400lb spring compared to the std 9" 190lb I had in there. The shorter spring has meant the same ride height is possible with the spring sitting higher. (clearing, I hope my 55 profile tyres)
Sitting in the arch happy, when I let the car down it doesn't dip at all, even with the shocks on soft!!
Front springs, Blue are the new 275lb, 8", black are the 250lb 9".
To some peoples disapointment, I have also raised the vehicles front ride height.
This is how it sits now,
because it means I get...
Then onto the gauges...
First to fit the temp sender and oil pressure sensor...
I mounted them here,
Anyone clarify where these go..
Rear mount, Engine mount, Gearbox mount.
Will get on tomorrow and do the mounts and the other things i've got to do.
Old 07-05-2008, 14:27   #1759
Drives: BMW E36 320 Coupe
looking good as always dude. excellent progress. those sbd manifolds make a hll of a difference too! so much more flow
namkeaps is offline   Reply With Quote
Old 07-05-2008, 14:28   #1760
DaveB's Avatar
Drives: Corsa XE with TBs
TypeC Manifolds are huge aren't they? I'm fitting mine tonight
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 07-05-2008, 14:35   #1761
spanishfly's Avatar
Yes, I'm going to get a front sitting fan, as I reckon the nova one will have to be sacrificed! Still need to wrap it too!
Old 07-05-2008, 14:40   #1762
DaveB's Avatar
Hmm, I'll let you know how I get on then LOL Haven't even unwrapped mine from the bubble wrap it came in If the fan touches the manifold I'm going to tuck the rad under the slam panel and mount the top with er, cable ties
I'm not wrapping mine; aside from the cost, and effort of wrapping it - I drive the car on too many 'country' roads for it to last long without bottoming out.
Old 07-05-2008, 14:42   #1763
spanishfly's Avatar
Old 07-05-2008, 15:15   #1764
CraigGreen's Avatar
Drives: smallblock Novas
Those mounts. L - R
Rear mount, solid drivers side mount. Fr gearbox mount.
Ride height still looks purposefull IMO. Too low encourages bump steer anyway.
V8 blender FTW
Old 07-05-2008, 15:26   #1765
spanishfly's Avatar
Originally Posted by CraigGreen View Post
Those mounts. L - R
Cheers Craig, I thought that was the case.
Yeah rise height still sits well, tyres just don't sit in the arches anymore. Means the lower arms are flat, also as you say bump steer.
Old 07-05-2008, 15:27   #1766
Drives: Corsa c20let
Sorry to hyjack but how long is a Nova? Bumper to bumper?
http://www.migweb.co.uk/forums/proje...wered-let.html
My Astra GSI LET Prodject
fennyLET is offline   Reply With Quote
Old 07-05-2008, 16:26   #1767
Benn's Avatar
Drives: A shineeeey Nova
Looks good dude, i cant wait to get my gaz stuff...
Still cant get oer the 55 tyres...
Ride looks good... could be lower tho I like the colour of your block...lol
i went for 300s for the front...
Old 07-05-2008, 16:31   #1768
spanishfly's Avatar
I was gonna go 280, but they didn't do them in the length I wanted. 300's will be fine, maybe a bit too hard.
Old 07-05-2008, 16:34   #1769
Drives: 280hp Audi S2 Avant
Looks good Spinach, I personally found 275's too soft, as your using good tires you may find it ok.
Speed doesnt kill, it's how you stop that decides your fate!
jonlem is offline   Reply With Quote
Old 07-05-2008, 16:35   #1770
spanishfly's Avatar
Will see how it goes. Next up in this size are 300's, and I reckon they'll be too hard.
Old 07-05-2008, 16:54   #1771
Benn's Avatar
All i'm worried about.
Old 07-05-2008, 19:41   #1772
Is this the sender adaptor you used? http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=022
DragXE is offline   Reply With Quote
Old 07-05-2008, 19:42   #1773
spanishfly's Avatar
Yes from the same person too
Old 07-05-2008, 19:56   #1774
ad4mb1nns's Avatar
Drives: carefully....
looking good mate has been a good read
Turbo Nova
ad4mb1nns is offline   Reply With Quote
Old 07-05-2008, 20:27   #1775
spanishfly's Avatar
Tags
fire rats!, red nova=faster, shonky opel .de
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/287511-nova-1-0-build-trackday-car.html
Posted By For Type Date
Took a few photos of the Sport.. - Page 3 - Performance Nova Group - PNG This thread Refback Yesterday 16:04
Custom Tie Bar and Wishbone setup - Page 3 - Performance Nova Group - PNG This thread Refback 04-01-2009 22:08
15" white speedline 2020's lightweight mag - Page 2 - Performance Nova Group - PNG This thread Refback 03-01-2009 10:24
Breaking my Nova - parts & price list - Page 3 - Performance Nova Group - PNG This thread Refback 02-01-2009 21:54
Mallory park trackday pics - Page 5 - Performance Nova Group - PNG This thread Refback 01-01-2009 19:00
whats every ones view on the new mot rule - Page 4 - Performance Nova Group - PNG This thread Refback 29-12-2008 11:02
Heated glass. - Page 19 - Performance Nova Group - PNG This thread Refback 27-12-2008 16:10
1/4 Mile Times-Add yours - Page 3 - Performance Nova Group - PNG This thread Refback 23-12-2008 07:31
shaving 256mm brakes - Page 3 - Performance Nova Group - PNG This thread Refback 22-12-2008 23:59
supercharging red top - Performance Nova Group - PNG This thread Refback 22-12-2008 15:03
supercharging red top - Performance Nova Group - PNG This thread Refback 22-12-2008 13:20
www.novaload.net - Page 3 - Performance Nova Group - PNG This thread Refback 22-12-2008 01:28
Heated glass. - Page 19 - Performance Nova Group - PNG This thread Refback 21-12-2008 10:54
Heated glass. - Page 16 - Performance Nova Group - PNG This thread Refback 17-12-2008 15:29
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 16-10-2008 22:18
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 16:17
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 13:52
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 11:12
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 14-10-2008 22:19
