LinkBack (53) Thread Tools
Old 23-03-2008, 22:18   9 links from elsewhere to this Post. Click to view. #1676
Drives: nova 1.8 16v on tbs
well, i can only speak from my experience, but mine were fine round brands, i'm confident the kit is sorted with the mods now done anyways
shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008
lee303 is offline   Reply With Quote
Old 24-03-2008, 08:15   #1677
Regional Co-ordinator
spanishfly's Avatar
Drives: ACT Nova TBs & less
I'll let ya know soon, i'm booking myself for a go on brands. I know when I went out in your car it certainly felt good
South-Eastern Coordinator
My nova
www.shonkyopels.de (now working lmao)
spanishfly is offline   Reply With Quote
Old 24-03-2008, 13:20   #1678
Drives: Nova Coupe
What the car?
The Simps is offline   Reply With Quote
Old 24-03-2008, 14:15   #1679
spanishfly's Avatar
Originally Posted by The Simps View Post
What the car?
Old 25-03-2008, 16:29   #1680
Drives: Nova Coupe
Those long flowing locks are so alluring!
Old 25-03-2008, 16:47   #1681
and i have so many other good points it just make me irresistable huh?
Old 25-03-2008, 21:34   #1682
spanishfly's Avatar
I do love your tea
Old 26-03-2008, 01:00   #1683
Drives: Nova Coupe
He is good with the tea! First thing he offered when I walked in the door asking to look at his spider.
Old 07-04-2008, 17:56   #1684
spanishfly's Avatar
Re: Nova 1.0 build (Trackday car)
Ok todays work!
Decided to look at the fuel system, gear linkage and basically went a bit over the top.
This made me realise how much I hate spot welds...
Trial fitting of shifter, the amount of in and out this thing did would seriously have cost alot if the nova was a hooker!
Primed and painted, then decided I might as well do under the seats again too
The start of Fuel system. Going try it like this first, May have to rubber mount the Facet if it gets too annoying. Used cotton braided hose as temp measure, the hose I ordered from a company turned out that when I asked for x mm I/D he chose to send me X mm O/D...
Didn't get many pictures as I was working flatout. Tomorrow I got to finish the fuel system and bolt everything back in. Hopefully I can do a quick service on the engine, put in n/a plugs. Got a trackday on Thursday so fingers crossed it's all ready!
Old 07-04-2008, 18:28   #1685
I would defo rubber mount the facet it will drive you mad
DragXE is offline   Reply With Quote
Old 07-04-2008, 18:29   #1686
Drives: nova xe/astravan
got my swirl pot there too, just makes life easier, why dont you mount the facet under the car?
novashed is offline   Reply With Quote
Old 07-04-2008, 18:48   #1687
Benn's Avatar
Drives: A shineeeey Nova
Shirter looks cool.
Old 08-04-2008, 00:15   #1688
Drives: 280hp Audi S2 Avant
Rubber mount the facet for sure, personally I'd have it under the car near the filler pipe too as its fecking noisy.
One thing I do find very odd, why go to the expense of fitting a swirl pot with -6 fittings then use hose clips on the facet ? either do the lot or don't bother imo as you could of saved yourself a fecking fortune on fittings.
Stick the facet under the car, then you cant see that its not quipped, atleast everything inside the car will be so it wont look odd.
Don't forget the grommets whilst your going through panels, that or use bulkhead fittings if your feeling flush
Speed doesnt kill, it's how you stop that decides your fate!
jonlem is offline   Reply With Quote
Old 08-04-2008, 08:18   #1689
spanishfly's Avatar
Yeah i've done this so far to see what hoses I'll need what sizes etc. I ordered the swirl pot, wish I hadn't done JIC connectors TBH, oh well. Does anyone know where I can get the 'cotton reels' from? Aren't they like mini fuel pump mount or something?
Old 08-04-2008, 08:51   #1690
TonySR's Avatar
Drives: Smoothed Nova C16se
Mini exhaust mounts, Mini centre in Lower Addiscombe (under the bridge) does them for 99p iirc
TonySR is offline   Reply With Quote
Old 08-04-2008, 09:28   #1691
spanishfly's Avatar
Old 08-04-2008, 15:31   #1692
As said if your going to use JIC throughout get some jic adaptors for the facet
Old 08-04-2008, 18:29   #1693
spanishfly's Avatar
I will do all in good time. As I have said i'm not using the black braid stuff either!
Old 08-04-2008, 18:45   #1694
Drives: 16v Nova, Astra TD
Deffo get some rubber mounts for the facet, they buzz like f**k
LongLiveTheNova is offline   Reply With Quote
Old 08-04-2008, 19:08   #1695
spanishfly's Avatar
Decided to mount my regulator here. I was going to mount it inside so I could use the gauge to keep an eye on fuel pressure. Lee made me think what could happen.
Rear fuel system complete. Just need to change hose for other hose. Remount Facet too, rubber needed. All hose is grommited and P clipped securely.
I also changed the oil and did a lil service. Ready for thursday trackday, while I was under there I thought I would take another pic of the gorgeous meaningful tie bars
Then I gave it a clean to get all the crappy road salt off it!
Still love the castor on the front wheel
Didn't take a pic, but my exhaust clamp from the manifold to center system broke, that'll be the speed bump
Tomorrow:
Tracking
Rubber mount Facet
General tighten up of all bolts
Hope springs turn up and fit them all up.
Hope Roll cage strengtheners turn up and fit them.
Old 08-04-2008, 19:11   #1696
Cool
Old 08-04-2008, 19:12   #1697
Benn's Avatar
Tie bars look sexy as funk, as do the car...
Old 08-04-2008, 19:41   #1698
Drives: nova gsi
tie bars look good.are they pretty close to the wheel or is it just the angle the picture was taken from?have they made much difference?
adam c is offline   Reply With Quote
Old 08-04-2008, 19:47   #1699
spanishfly's Avatar
They are pretty much (if not) touching on full lock. They seem to be good on the road, i'll let ya know on thursday if it feels better!
Cheers for comments
Old 08-04-2008, 19:48   #1700
A2!
Drives: Kadett 200ts
Looking very good indeed mate. Top work as always
Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!!
A2! is offline   Reply With Quote
Tags
fire rats!, red nova=faster, shonky opel .de
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/287511-nova-1-0-build-trackday-car.html
Posted By For Type Date
Took a few photos of the Sport.. - Page 3 - Performance Nova Group - PNG This thread Refback Yesterday 16:04
Custom Tie Bar and Wishbone setup - Page 3 - Performance Nova Group - PNG This thread Refback 04-01-2009 22:08
15" white speedline 2020's lightweight mag - Page 2 - Performance Nova Group - PNG This thread Refback 03-01-2009 10:24
Breaking my Nova - parts & price list - Page 3 - Performance Nova Group - PNG This thread Refback 02-01-2009 21:54
Mallory park trackday pics - Page 5 - Performance Nova Group - PNG This thread Refback 01-01-2009 19:00
whats every ones view on the new mot rule - Page 4 - Performance Nova Group - PNG This thread Refback 29-12-2008 11:02
Heated glass. - Page 19 - Performance Nova Group - PNG This thread Refback 27-12-2008 16:10
1/4 Mile Times-Add yours - Page 3 - Performance Nova Group - PNG This thread Refback 23-12-2008 07:31
shaving 256mm brakes - Page 3 - Performance Nova Group - PNG This thread Refback 22-12-2008 23:59
supercharging red top - Performance Nova Group - PNG This thread Refback 22-12-2008 15:03
supercharging red top - Performance Nova Group - PNG This thread Refback 22-12-2008 13:20
www.novaload.net - Page 3 - Performance Nova Group - PNG This thread Refback 22-12-2008 01:28
Heated glass. - Page 19 - Performance Nova Group - PNG This thread Refback 21-12-2008 10:54
Heated glass. - Page 16 - Performance Nova Group - PNG This thread Refback 17-12-2008 15:29
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 16-10-2008 22:18
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 16:17
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 13:52
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 15-10-2008 11:12
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 14-10-2008 22:19
VauxSport - Vauxhall advice and chat forum :: View topic - Am I still cool!? This thread Refback 14-10-2008 22:15
F**king hell, Spanish Fly's nova/engine bay in flames - Page 7 - Performance Nova Group - PNG This thread Refback 22-09-2008 20:34
Power to the Van - Page 2 - Astra Sport and Astra Owners Club Forum This thread Refback 22-09-2008 12:26
VauxSport - Vauxhall advice and chat forum :: View topic - GAZ`D Purple Corsa This thread Refback 23-07-2008 14:35
VauxSport - Vauxhall advice and chat forum :: View topic - GAZ`D Purple Corsa This thread Refback 22-07-2008 21:08
