Page 95 of 400 FirstFirst ... 45 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 145 195 ... LastLast
Results 2,351 to 2,375 of 9990
Thread: Lee's Garage
  1. #2351
    Glasgow
    saab turbo
    could you not have made a modified blank plate that incorporated the pipe? less weld to rely on.
    as i understand it welding cast is a bugger.
    my other idea is run the pipe through the blank plate and bung up the hole in the block where standard pipe joins?
    curiosity killed the cat...................but for a while i was a suspect!!
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    its harder to make it all seal up to the inlet pipe and th eblock if its part of the plate though, adn the lip on the inlet to the block would probably mean you wouldnt be able to do it that way either tbh, its fine how it is, welding cast is easy with a good enough mig welder these days as they put alot less carbon into cast nowadays compared to years ago
    SHoNkyOpELs.de
  4. #2353
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    so, having found out my gearbox is a hockley, and having it rejected by quaife, thought i'd just rebuild it myself!lmao
    not a big deal, except for fifth gear, which had somehow seized so hard onto the shaft, it took me all day to remove it yesterday!
    you need to remove it first before the gears will come out of the sandwich plate.
    the box arrived back minus its selector assembly, that was in a bag with it, so, having sworn and faffed alot with the fifth gear, here's what we started with today
    as you can see, quite a few bits! the main reason for the rebuild was the missing synchro lug on second gear, i have a spare box at the garage with nearly new synchro hubs on it, so stripped that to bits to get the spares, the started to strip the main shaft on my SCCR and ,made the best box out of the two, thats why there's two fifth gear selectors in the above pic, the one in my spares box had snapped at some point and been welded up, didnt use that one obviously!
    this is the offending fifth gear, is quite a tight fit!
    the gear set out of the plate, is held in with tow circlips, one normal and one external tagged
    so, in the vices soft jaws and away we go!
    got the pu;ller out and removed first gear, having previosuly removed a circlip
    this is the broken bit on the first/second synchro, note missing lug
    so, bit of fiddling, and a new one is in
    then refitted first, and the bearing retaining circlip, and the bearing it retains
    then get the newly painted sandwich plate
    hold the gears all meshed up, then refit into plate, retaining with a cirlip on each shaft
    now time to refit fifth! is one million times easier when you can heat it in isolation from the shaft
    on she goes, then fit a circlip, and fit two thrust washer halves to the other shaft, and a wrap around roller bearing
    thrust washer comes in two bits so it can be fitted into the groove on the shaft
    now fit reverse gear and its selector, then first/second gear selector
    then fit thrid/fourth selctor,fifth gear selector, and then fifth gear itself and its synchro runner
    this goes in here to act as a fifth gear detent
    then the gear and runner go on
    then fit the reverse detent, stops you getting reverse when you dont want it!
    then fit the roll pinsin the selector rods, you can assemble these 180 degrees out, but you'll soon know, as the box will be stuck in one gear or another! lmao
    then finally time to fit the corss shaft and detents that hold the gears in once selected, the longer one goes in the thrid/forth gear shaft
    refit end cover, then pop the lot back in the box, remebering to fi tthe fifth gear thrust washer on its shaft
    i did it upside down so it wouldnt fall off the shaft either!
    job done, just waiting for the turret to dry before i fit that too!
    quite glad to get that all done after yesterdays saga i can tell you! should now have no crunching into second either! not as bad a job as it looks or sounds either, although if you have no previous experience i can see it being fairly dauntinglmao
    Brian is edging closer to spraying, kurrust time at the mo!
    SHoNkyOpELs.de
  5. #2354
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    nice work.
    www.shonkyopels.de
  6. #2355
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    cheers
    SHoNkyOpELs.de
  7. #2356
    Jul 2002
    Stoke/Leamington Spa
    Whirling Dervish
    Good work matey, i really need to sort out a box for mine but i have so little patience know i couldn't get through a rebuild like you've just done without breaking something.
    "I have nothing to declare"
  8. #2357
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    its not that bad tbh, as long as your methodical and keep everything in order, and having the right pullers etc is a big help, fifth gear was just a pain in the ass though!!
    SHoNkyOpELs.de
  9. #2358
    Very cool,
    So its all good in the box now?
  10. #2359
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yup, all fixed
    SHoNkyOpELs.de
  11. #2360
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    that looked like a nightmare! If thats was me i would have had to of taken a million fotos so i new how things went back together! lol
  12. #2361
    yup, all fixed
    Sweet, get that engine built.
    Quote Originally Posted by The Simps View Post
    You and me both...
  13. #2362
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    its a good task to accomplish though, and really lets you see how your gearbox works, i love stuff like that
    SHoNkyOpELs.de
  14. #2363
    Apr 2002
    High Wycombe Looks@:
    The White Wonder
    glad you know what goes on in that box!
    Total Carlton (Carlton Forum)
  15. #2364
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    well, it still worked when i finished and i didnt have any parts left over, so i think i dolmao
    SHoNkyOpELs.de
  16. #2365
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    lol
    Gearbox parts scare me lmao
    Top job that
  17. #2366
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    I'd only do that with my G/box if I had a spare sat there to use if it went wrong.
    I was thinking there were no gaskets either until last couple of shots showed the tube of sealant & the sealant oozing through the gaps.
    Top write up as always Lee. Most people could use that as a rebuild guide tbh.
  18. #2367
    Oct 2005
    Oswestry
    corsa c 1.3
    I was thinking the same about the rebuild guide, a tad out of my league I thinks tho lmao
    good work.
  19. #2368
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    thanks guys, the wirte up in the old blue nova haynes manual is also very good, with many detailed photos
    SHoNkyOpELs.de
  20. #2369
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    But not in the Green manual NO?
    Lost my Blue one years ago.
  21. #2370
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    nah, it just says 'gearboxes are complicated, mkay' in the green onelmao
    SHoNkyOpELs.de
  22. #2371
    May 2002
    edinburgh
    Corsa rally car
    Those F10 sccr boxes were the bane of my life!! i could actually strip one with my eyes shut now! I had a hockley box and once i got used to stipping it you can do it without taking the detent plungers out, there is a particular rebuild order if you do that though. also my 5th gear was a lovely sliding fit onto the shaft , no puller required, shows the hockley quality control i guess.
    looks good though Lee how close are you to having an engine to build? have you had any bother getting a hold of Mr Bowyer yet!
  23. #2372
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, you have to force the detents back into the housing when you refit if you dont take them out though, and as it takes about 2 mins to remove i always do, as for the engine and mr bowyer, getting hold of him is easy, getting him to get back to you is a bit harder!lmao should have all the engine componets soon, then will measure up, send a few bits off for machining then assemble, want it in the car in february if poss
    SHoNkyOpELs.de
  24. #2373
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    well, finally, after what seemed like months(oh wait, thats cos it was!! ) deemon tweeks finally pulled their finger out and got me my tapered ring compressor, anyone who wants one should go direct to summit racing imo
    great bit of kit though
    still waiting on bowyer, but it shouldnt be long now
    SHoNkyOpELs.de
  25. #2374
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Great work Lee
  26. #2375
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    cheers keith, sorry about your problem, and i dont mean to go on, hope you get it sorted one way or t'other
    SHoNkyOpELs.de
  1. 29-01-2012, 23:45
  2. 24-01-2012, 18:34
  3. 19-01-2012, 16:52
  4. 01-12-2011, 12:03
  5. 23-10-2011, 21:43
  6. 21-10-2011, 21:14
  7. 28-09-2011, 20:36
  8. 15-08-2011, 12:06
  9. 10-08-2011, 15:21
  10. 28-07-2011, 15:07
  11. 06-07-2011, 08:40
  12. 29-06-2011, 06:57
  13. 27-06-2011, 19:30
  14. 28-05-2011, 16:33
  15. 25-05-2011, 12:39
  16. 19-05-2011, 16:50
  17. 19-05-2011, 16:50
  18. 18-05-2011, 22:03
  19. 17-05-2011, 09:57
  20. 16-05-2011, 21:53
  21. 10-05-2011, 23:19
  22. 18-04-2011, 05:13
  23. 11-04-2011, 06:46
  24. . .
    Refback This thread
    07-04-2011, 07:52
  25. 12-03-2011, 02:57
  26. 11-03-2011, 19:05
  27. 19-01-2011, 23:02
  28. 02-12-2010, 23:29
  29. 01-12-2010, 20:20
  30. 28-09-2010, 16:30
  31. 28-09-2010, 11:05
  32. 29-08-2010, 10:54
  33. 27-08-2010, 21:57
  34. 19-08-2010, 10:31
  35. 27-07-2010, 11:52
  36. 24-07-2010, 00:49
  37. 18-07-2010, 17:03
  38. 24-06-2010, 09:39
  39. 14-06-2010, 16:47
  40. 17-05-2010, 21:07
  41. 12-05-2010, 00:53
  42. 12-03-2010, 23:31
  43. 05-03-2010, 18:35
  44. 03-03-2010, 00:41
  45. 25-02-2010, 18:47
  46. 03-02-2010, 16:40
  47. 30-01-2010, 19:13
  48. 16-01-2010, 21:38
  49. 16-01-2010, 19:15
  50. 19-07-2009, 02:19
  51. 19-07-2009, 01:37
  52. 06-07-2009, 12:25
  53. 24-06-2009, 09:15
  54. 24-06-2009, 08:53
  55. 26-01-2009, 16:28
  56. 21-01-2009, 19:07
  57. 21-01-2009, 16:13
  58. 21-01-2009, 16:10
  59. 21-01-2009, 16:10
  60. 22-12-2008, 09:43
  61. 21-12-2008, 10:52
  62. 20-12-2008, 21:30
  63. 20-12-2008, 21:15
  64. 17-12-2008, 12:47
  65. 10-11-2008, 09:20
  66. 21-10-2008, 16:20
  67. 29-09-2008, 14:10
  68. 29-09-2008, 14:07
  69. 29-09-2008, 12:06
  70. 26-09-2008, 06:47
  71. 24-09-2008, 09:14
  72. 22-09-2008, 21:09
  73. 22-09-2008, 11:50
  74. 22-09-2008, 08:51
  75. 22-09-2008, 06:54
  76. 03-09-2008, 10:42
  77. 10-07-2008, 17:33
  78. 25-06-2008, 14:01
  79. 24-06-2008, 23:32
  80. 24-06-2008, 20:55
  81. 24-06-2008, 19:31
  82. 24-06-2008, 19:30
  83. 24-05-2008, 10:08
  84. 22-05-2008, 19:42
  85. 22-05-2008, 19:20
  86. 22-05-2008, 18:43
  87. 22-05-2008, 18:43
  88. 06-05-2008, 13:38
  89. 04-05-2008, 00:00
  90. 03-05-2008, 23:16
  91. 03-05-2008, 22:09
  92. 03-05-2008, 20:45
  93. 03-05-2008, 20:43
  94. 03-05-2008, 20:42
  95. 10-01-2008, 17:44
  96. 29-11-2007, 13:14
