15-06-2007, 21:36
#1501 | | MIGWeb User
Join Date: Oct 2003 Location: Nr St Ives, Cambs Drives: 280hp Audi S2 Avant
| Totally gutted for you mate, was going to ask what you were doing this Friday and now I know.
Were off over there on the 31st August if you fancied that.
Hope its not too bad, were you revving it rather hard at the time ?
__________________ Speed doesnt kill, it's how you stop that decides your fate! |
15-06-2007, 21:43
#1502 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| 4k, thats whats so annoying, was just cruising along, then bang, must nbe a component failure, not looking forward to seeing how the piston looks if the plug looks like that though  might bring the 1800 build forward though... |
15-06-2007, 21:45
#1503 | | MIGWeb User
| Really 5hit news matey.
If I could help you out I would.
Fingers crossed its not too fooked |
15-06-2007, 21:46
#1504 | | MIGWeb User
| cheers mate, much appreciated, tommorow will bring more pics...
on a lighter note, laser cut plates are finally here, so will be making the tie bar kits sooner rather than later |
15-06-2007, 21:48
#1505 | | MIGClub Member
Join Date: Apr 2002 Location: High Wycombe Looks@: Drives: The White Wonder
| Ah man that sucks.  |
15-06-2007, 21:50
#1506 | | MIGWeb User
15-06-2007, 22:02
#1507 | | MIGWeb User
Join Date: Sep 2001 Location: Portsmouth Drives: black jap thing
| gutted mate  |
15-06-2007, 22:10
#1508 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
| Bad news that
It seems everyones small blocks xe's are dieing atm  |
15-06-2007, 22:22
#1509 | | MIGWeb User
Join Date: Feb 2003 Location: northampton Drives: nova xe/astravan
| all that hard work,
oh well chin up im sure its not fazed you, just pushes you even more to get it right next time! |
15-06-2007, 23:45
#1510 | | MIGWeb User
| crap !
but it could be worse, it could have let go on the ring itself and you could be taking the engine home in a bucket inside the tow truck ! |
16-06-2007, 00:37
#1511 | | Regional Co-ordinator
| bad luck dude,
but sure you'll be back in now time,
setting a npb at the ring,
__________________ Quote: |
16-06-2007, 13:47
#1512 | | MIGWeb User
| cheers for the comments peeps, it will be back dont worry...
ok, so time for carnage pics!!
somewhow found the motivation to get up there and strip it this morning....
so, as we can see, bit of a mess,there was even swarf on the throttle butterfly!
looks likely that a valve failed and fell into the cylinder, whacking the plug and then snowballing the rest, quite why it failed i dont know, they are one piece valves so the head shouldnt have fallen off(which is kinda well known)and none of the springs or caps are broken, could have been a lifter gone solid, but whatever, its ****ed so no point in ifs or buts, more bits pics
how i left it
so, basicvally the plan is to build a 1800 now, not gonna bother trying to stick a 1600
back together before hand, would be a waste of cash, so watch this space for the new engine...
in the meantime, will be making my tie bar kits so if you're interested let me know
and, for sale, one set of SBD 304 degree 11.9 mm lift cams for the 1600, will work with hydraulics
offer around £200 minus the verniers |
16-06-2007, 13:50
#1513 | | MIGWeb User
| Fook, what a mess  Proper nasty.
It'll be cool see a small block 1800
You saving the bodies etc for the 1800? |
16-06-2007, 14:15
#1514 | | MIGWeb User
| Quote:
Originally Posted by LongLiveTheNova You saving the bodies etc for the 1800? | yup, gonna use as much as poss from this engine, but am going to solid lifters hence the cam sale |
16-06-2007, 14:20
#1515 | | MIGWeb User
| Cool, cant wait to see one in a nova, quite unique. |
16-06-2007, 14:37
#1516 | | MIGWeb User
Join Date: Dec 2004 Location: Stockport, N.W Drives: Jap Crap wit Booost!
| Gutted for you Lee, looks a right mess tho.
I was hoping u could just get away with a new head but man its munched loads!
I take it ud be using the 1.8 16v small block?
__________________ Rememeber Pop Up Headlights are the Future! |
16-06-2007, 14:39
#1517 | | MIGWeb User
| that piston a gonna ?
and you mean a late small block 1800 ? |
16-06-2007, 14:42
#1518 | | MIGWeb User
| very much so yup and yup, corsa engine
andy, when i saw the plug in belgium, i kinda knew it was gonna be fubar, there's about 2 mm from the top of the piston to the plug tip @ TDC, so if it had benn given a whack by something, you know its curtains, onnwards and upwards as they say, probably rip the block to bits tommorow |
16-06-2007, 14:46
#1519 | | MIGWeb User
|  that sucks.
The joys of pushing big power threw a small engine. |
16-06-2007, 14:48
#1520 | | MIGWeb User
| yup, **** happens as they say, i have to say it had to happen sometime, i've been to the ring 6 times and driven home every time, sooo glad i had recovery though  |
16-06-2007, 15:18
#1521 | | MIGWeb User
| who do you have your track day insurance with lee ? |
16-06-2007, 15:28
#1522 | | MIGWeb User
Join Date: Apr 2006 Location: Atherstone Drives: 2 many 2 list
| £180 lee posted for the cams? |
16-06-2007, 15:33
#1523 | | MIGWeb User
| Jeez that is bad
Tuned engine or not its just unlucky, certainly not worth mincing about what caused it, just rip it out and break it up.
Roll on smallblock 1.8 power |
16-06-2007, 15:35
#1524 | | MIGWeb User
| Quote:
Originally Posted by stuartp £180 lee posted for the cams? | sounds good to me, will send you my addy in a pm in a bit
0dders, i dont have trackday insurance, i do have european rescue cover with adrian flux though |
16-06-2007, 15:46
#1525 | | MIGWeb User
| Quote:
Roll on smallblock 1.8 power | you're not wrong, i'm kinda leaning towards a valve seat failure, but it matters not, gonna find a small block 1800 soon as... |
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/283840-lees-garage.html | | Posted By | For | Type | Date | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 22-12-2008 09:43 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 21-12-2008 10:52 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 20-12-2008 21:30 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 20-12-2008 21:15 | | here we go, big block v's small block (not the normal thread) - Page 13 - Performance Nova Group - PNG | This thread | Refback | 17-12-2008 12:47 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 10-11-2008 09:20 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 21-10-2008 15:20 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 29-09-2008 13:10 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 29-09-2008 13:07 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 29-09-2008 11:06 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 26-09-2008 05:47 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 24-09-2008 08:14 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 22-09-2008 20:09 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 22-09-2008 10:50 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 22-09-2008 07:51 | | Lanos club -> Âîçìîæíûå ÊÏÏ äëÿ Lanos | This thread | Refback | 22-09-2008 05:54 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-09-2008 09:42 | | cams (true or not) ? - Astra Sport and Astra Owners Club Forum | This thread | Refback | 10-07-2008 16:33 | | lee303's nova groundbreaker.. - Performance Nova Group - PNG | This thread | Refback | 25-06-2008 13:01 | | lee303's nova groundbreaker.. - Performance Nova Group - PNG | This thread | Refback | 24-06-2008 22:32 | | lee303's nova groundbreaker.. - Performance Nova Group - PNG | This thread | Refback | 24-06-2008 19:55 | | lee303's nova groundbreaker.. - Performance Nova Group - PNG | This thread | Refback | 24-06-2008 18:31 | | lee303's nova groundbreaker.. - Performance Nova Group - PNG | This thread | Refback | 24-06-2008 18:30 | | Show me your tuned Z18xe's..... - CORSA-C|UK | This thread | Refback | 24-05-2008 09:08 | | Show me your tuned Z18xe's..... - CORSA-C|UK | This thread | Refback | 22-05-2008 18:42 | | Show me your tuned Z18xe's..... - CORSA-C|UK | This thread | Refback | 22-05-2008 18:20 | | Show me your tuned Z18xe's..... - CORSA-C|UK | This thread | Refback | 22-05-2008 17:43 | | Show me your tuned Z18xe's..... - CORSA-C|UK | This thread | Refback | 22-05-2008 17:43 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 06-05-2008 12:38 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 23:00 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 22:16 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 21:09 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 19:45 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 19:43 | | Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina | This thread | Refback | 03-05-2008 19:42 | | nova adjustable bottom arms. - Performance Nova Group - PNG | This thread | Refback | 10-01-2008 17:44 | | nova adjustable bottom arms. - Performance Nova Group - PNG | This thread | Refback | 29-11-2007 13:14 | | | » Search | | To use the advanced search, please log in. | | » Forum Stats |
Members: 43,212
Threads: 310,608
now!
of being a MIGClub Member.
