LinkBack (37) Thread Tools
Old 14-10-2006, 18:17   #126
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
lol,deffo shotgun at the next coomb...
Old 14-10-2006, 18:28   #127
Drives: cali se4
you should have a green rubber sleeve around the spring of the slave cylinder
You've just been NOVAtaken. Gotta luv the tourque steer :nod:. Click here for migwebs chatroom ;).
The car infront is "mine" not a toyota. Hit me, Hit me, Hit me with your modding stick.
Anything you need ask me not jeeves lmao. !!!WARNING THIS PERSON IS EASILY OFFENDED!!!
daveb948576 is offline   Reply With Quote
Old 14-10-2006, 18:30   #128
Drives: 2003 Astra SRi
jealous
Looking amazing
rob_lee_1 is offline   Reply With Quote
Old 14-10-2006, 20:59   #129
Drives: nova 1.8 16v on tbs
really? its new out the box, maybe thats a seperate part?
cheers rob, and benn, no worries, even got an intercom now too! p.s any news on them indicators??
lee303 is offline   Reply With Quote
Old 14-10-2006, 23:51   #130
Drives: cali se4
no no no you must have a green rubber sleeve yes it may be new but soem times they forget to attach it take it back honestly im not meesing you about. its to stop dust/grit getting into the seal/moving parts and creatign a leak.
put the picture up in mech and tech and get a second opinion.
Old 14-10-2006, 23:55   #131
Drives: cali se4
http://www.migweb.co.uk/forums/vauxh...ml#post2967641
Old 15-10-2006, 00:26   #132
Drives: cali se4
Old 15-10-2006, 09:04   #133
alright alright, calm down!! i'll just make my own cover, tis only a dust seal anyways, lots of stuff to do before i get to sorting that though
Old 15-10-2006, 09:09   #134
spanishfly's Avatar
Drives: ACT Nova TBs & less
I have had them with no seal, some of them don't need the green cover. Also i'm sure Lee isn't loooking for 80k out of it so he'll be fine!
South-Eastern Coordinator
My nova
www.shonkyopels.de (now working lmao)
spanishfly is offline   Reply With Quote
Old 15-10-2006, 09:11   #135
what you tring to say? that it'll be in bits again before it wears out??
anyways, off to do the steering now, pics later...
Old 15-10-2006, 09:49   #136
spanishfly's Avatar
Old 15-10-2006, 15:39   #137
and so, the steering, obviously you need this to be pretty strong as
you dont want it flexing or worse when 'aving it round the track!
started by making this plate
then decided to utilise the original bracketry to save adding more plates to the
bulkhead than was necessary, so got some box...
nice and strong side to side but it still neede a bit of triangualtion to
stop the up and down movement
threw some paint around
that done i thought i'd make some blanking plates for the bay and moved the fuel
unions to the old servo position
now i need to move the gearlever and handbrake, this is where i want the lever
typically right in the middle of the strengthener!
also need to remove this mount and move it back a few inches, will probably
just cut the top off the tunnel and re weld it in the right place
and finally, just cos it's a nice bit of engineering,i give you the underneath of my
quaife shifter!
got a few bits for sale now too, see the for sale section
Old 15-10-2006, 17:37   #138
spanishfly's Avatar
Could it be converted to a vrrrromm tic vrooommm? Would make life easier!!! Actually I've just decided you need to fit tipronic!
Old 15-10-2006, 19:33   #139
nah, you need the whole banging the lever down through the box thing if you're gonna do it! on a big alloy tower next to the wheel, alas, this cant be used for that
Old 15-10-2006, 20:05   #140
spanishfly's Avatar
oh sounds like you know so much! Go DO IT
Old 15-10-2006, 20:07   #141
i have the knowledge, just not the money would love to get a sequential though, could move the engine further down and rotate it forward so you could push it right back too
Old 15-10-2006, 20:15   #142
spanishfly's Avatar
One day huh matey!?
Old 15-10-2006, 20:17   #143
Benn's Avatar
you is a crazy mofo,
and i love it.
Old 15-10-2006, 20:38   #144
Drives: Corsa rally car
If you go sequential , dont go quaife 32G they go vroooom tic vrooooom tic vroooooooom BANG grrrrrruncccchhhhhhh -------oil slick! much better with a Sadev.
Seriously though than is some serious mods, the crossbrace that mounts the factory seats, on most rally cars that is removed entirly from the floor as it is a heavy lump of steel. i drilled all the spotwelds out on mine and removed it and there is now lots of room.
Also could you not do a hydraulic hand brake , they now come with a cable attachment of 2x long throttle cables to pass mot but will snap if ever used! very reasonable from rally design.
novarallycar is offline   Reply With Quote
Old 15-10-2006, 20:43   #145
Add_Gee's Avatar
Drives: E46 320D
ace work, i love reading this thread
Originally Posted by Jack on about diesel tuning
Turn the boost right up and turn your fueling up to match! Leaving a trail of dead dolphins in your wake!
Add_Gee is offline   Reply With Quote
Old 16-10-2006, 14:55   #146
lol, have heard that about older quaife stuff but i thought they'd sorted it, bit pie in the sky anyways
had also thought about hydraulic h/brake but i cant be bothered tbh, not a big handbrake user tbh, only need it to stop the car rolling away
cheers for the tip on the strengthener though, might bin that totally then, i do have brace bars going across for the seats so as you say it should be strong enough
Old 16-10-2006, 15:16   #147
Drives: like a saint-9points
Lee, thats **** hot mate
rodgerq
thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me
rodgerq is offline   Reply With Quote
Old 16-10-2006, 15:47   #148
Drives: 2 many 2 list
i hate treads like this!!! Because i spend hours reading them and not getting any thin done to my nova!! good work there lee and i'l be asking loads of questions soon once my shells been preped hope ya wont mind!! Keep up the good work!!
stuartp is offline   Reply With Quote
Old 16-10-2006, 15:49   #149
GTE_lee's Avatar
Drives: Nova GTE
not sure how that is gonna feel to drive,
great work all round tho
GTE_lee is offline   Reply With Quote
Old 16-10-2006, 16:11   #150
CraigGreen's Avatar
Drives: smallblock Novas
I reckon with the revised seating/steering/pedal locations the car could feel totally different to drive. (or maybe a little)
V8 blender FTW
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/283840-lees-garage.html
Posted By For Type Date
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 22-12-2008 09:43
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 21-12-2008 10:52
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 20-12-2008 21:30
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 20-12-2008 21:15
here we go, big block v's small block (not the normal thread) - Page 13 - Performance Nova Group - PNG This thread Refback 17-12-2008 12:47
Lanos club -> Возможные КПП для Lanos This thread Refback 10-11-2008 09:20
Lanos club -> Возможные КПП для Lanos This thread Refback 21-10-2008 15:20
Lanos club -> Возможные КПП для Lanos This thread Refback 29-09-2008 13:10
Lanos club -> Возможные КПП для Lanos This thread Refback 29-09-2008 13:07
Lanos club -> Возможные КПП для Lanos This thread Refback 29-09-2008 11:06
Lanos club -> Возможные КПП для Lanos This thread Refback 26-09-2008 05:47
Lanos club -> Возможные КПП для Lanos This thread Refback 24-09-2008 08:14
Lanos club -> Возможные КПП для Lanos This thread Refback 22-09-2008 20:09
Lanos club -> Возможные КПП для Lanos This thread Refback 22-09-2008 10:50
Lanos club -> Возможные КПП для Lanos This thread Refback 22-09-2008 07:51
Lanos club -> Возможные КПП для Lanos This thread Refback 22-09-2008 05:54
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-09-2008 09:42
cams (true or not) ? - Astra Sport and Astra Owners Club Forum This thread Refback 10-07-2008 16:33
lee303's nova groundbreaker.. - Performance Nova Group - PNG This thread Refback 25-06-2008 13:01
lee303's nova groundbreaker.. - Performance Nova Group - PNG This thread Refback 24-06-2008 22:32
lee303's nova groundbreaker.. - Performance Nova Group - PNG This thread Refback 24-06-2008 19:55
lee303's nova groundbreaker.. - Performance Nova Group - PNG This thread Refback 24-06-2008 18:31
lee303's nova groundbreaker.. - Performance Nova Group - PNG This thread Refback 24-06-2008 18:30
Show me your tuned Z18xe's..... - CORSA-C|UK This thread Refback 24-05-2008 09:08
Show me your tuned Z18xe's..... - CORSA-C|UK This thread Refback 22-05-2008 18:42
Show me your tuned Z18xe's..... - CORSA-C|UK This thread Refback 22-05-2008 18:20
Show me your tuned Z18xe's..... - CORSA-C|UK This thread Refback 22-05-2008 17:43
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 06-05-2008 12:38
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 23:00
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 22:16
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 21:09
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 19:45
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 19:43
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 03-05-2008 19:42
nova adjustable bottom arms. - Performance Nova Group - PNG This thread Refback 10-01-2008 17:44
nova adjustable bottom arms. - Performance Nova Group - PNG This thread Refback 29-11-2007 13:14
