Page 308 of 400 FirstFirst ... 208 258 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 358 ... LastLast
Results 7,676 to 7,700 of 9990
Thread: Lee's Garage
  1. #7676
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Re: Lee's Garage
    good stuff mate.
    www.shonkyopels.de
    May 2007
    Hinckley
    '98 Corsa XE
    Re: Lee's Garage
    Great news on the parts, looking forward to the progress it might even tempt me to get mine finished!
  4. #7678
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    well, it will probably slow up a bit when the pistons etc arrive, need to get it off for balancing then get it built up, then need to sort a couple of things on the gearbox, re position the hopefully repaired pump, re plumb to suit, gonna check/re shim the solids too, and i have a busy month anyways, but don't let that stop you doing yours lmao
    SHoNkyOpELs.de
  5. #7679
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    headgasket has landed at martins, just need to have a quick measure of some shims tomorrow so he can send me some that are in the right ball park, ordered a clutch too so should have all the components here next week
    SHoNkyOpELs.de
  6. #7680
    Oct 2002
    Re: Lee's Garage
    great news mate! 4 paddle?
    www.shonkyopels.de
  7. #7681
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    ya, got a three in error last time, helix say it only affects the life of it though, rather than the torque handling capability
    SHoNkyOpELs.de
  8. #7682
    Re: Lee's Garage
    Oooo cracking on.
  9. #7683
    Middlesex
    sideways
    Re: Lee's Garage
    Made a big hole:
    ...and then started to seal it up...
    All to let the engine go in and come out easier. Without modding the chassis I'd have to take the coil pack off every time the engine comes out or goes in. Might as well do this mod now that the engine's out.
    Brian Sidebotham.
  10. #7684
    Aug 2003
    plymouth
    wife around the
    Re: Lee's Garage
    Are you going from a 3 to a 4 paddle ? Ime the more paddles you have the less bitey it is
    ''THE REAL ROB''
  11. #7685
    Oct 2002
    Re: Lee's Garage
    Yeah going for 4 paddle over the 3 he had.
    www.shonkyopels.de
  12. #7686
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    but i originally ran a 4 then swapped to a three in error, noticed no difference tbh...
    right so with martin about to send the bits over, thought i best check if the crank i have is any good!
    so out with the plastigauge today
    can only do the mains as i don't have the new rods yet, but they all came out very even at just about 0.040 mm, which is fine, so thats good, the journals do need a slight polish though i would think
    end float is spot on too at 0.15
    so that looks good for that crank, brian meanwhile was finishing his new, easy engine fit gearbox tunnel in the manta, looks ace!!
    and will make things a lot easier when sticking it back in, which will probably happen tomorrow
    while he welded and painted that, i took a look at his trusty astra, needed the alternator bushes doing, but on closer inspection, i gave it a cambelt and a quick service too!!!
    reasons why?
    lol, is much better now!!! and he finished the tunnel just in time
    willay popped up too which was nice, even if he has gone a bit boyband with his hair lmao hai mate....
    SHoNkyOpELs.de
  13. #7687
    Oct 2002
    Re: Lee's Garage
    Nice mate. Good to see it was a good lump
    www.shonkyopels.de
  14. #7688
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    yeah, will hold my breath till i get the rods on it and have it measured for ovality, but it bodes well
    SHoNkyOpELs.de
  15. #7689
    Jul 2009
    South East
    Corsa C 1.8 on ITBs
    Re: Lee's Garage
    Good progress as always. I wish I knew half of what you do about engines, the crank would have had to be banana shaped for me to notice if it was bent, lol
  16. #7690
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    well, plastigauge only tells you so much, namely the static running clearance, i don't have a micrometer big enough to measure the journals for ovality, but it at least tells you if the crank has worn excessively, i'll borrow one at some point for a final check, and i'll get the guy who balances it to check it for trueness, but it looks good so far..
    SHoNkyOpELs.de
  17. #7691
    Middlesex
    sideways
    Re: Lee's Garage
    That was a good day up the garage. Had a good few cups of tea and actually did stuff too. Willay, I missed you leaving mate! Sorry. Too busy loving the manta! lmao
    Right, I think I've done most of the mods and prep I wanted to do before the engine and gearbox goes back in the car.
    Finished off the big hole:
    The mounts for the subframe got abused and I ended up stripping the threads on the captive screws which position the subframe onto the chassis legs. So, I had to replace the bolts with new ones. The standard manta bushes here are rubber, but I made up some custom solid mount versions as otherwise the whole suspension (and geometry) moves around all over the place.
    I made a fitting up for the oil pressure sensor and repositioned it, as well as adding fittings to the clutch hydraulics so that I don't have to cut the hydraulics every time I want to remove the engine + gearbox and so that the bleed for the clutch is much easier to get at!!
    ...and th, th, th, th, that's all folks.
    Anyway, got to shoot. House party apparently!
    Brian Sidebotham.
  18. #7692
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    nice work! should be in the bay tomorrow then, see you at breakfastlmao
    SHoNkyOpELs.de
  19. #7693
    Re: Lee's Garage
    Awesome work, like the cut out in the bulk head.
  20. #7694
    Re: Lee's Garage
  21. #7695
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    so, todays action!
    first thing was to get the engine back on the frame, easy enough, if a little fiddly, bri has also raised the engine about 15mm and i modded the cut out in said frame to give the sump plumbing more room, worked a treat!
    we almost made a frame for a seat and left it at that, but we're getting good at moving it around on the subframe, even have a prop specific dolly wheel now lmao
    then, some jiggery, followed by some pokery occurred, and its in!
    loads more room now with the tunnel mod, can even get the coilpack on and off without dropping the engine lmao
    so, manta 2.0 is born...
    left brian bolting stuff on so i could watch some touring cars hit each other, he should fire her up tuesday with any luck...
    SHoNkyOpELs.de
  22. #7696
    Jun 2001
    newcastle or dundee
    corsa xe, c90 cub
    Re: Lee's Garage
    Good stuff. Any ideas when its likely to go for mapping then?
  23. #7697
    Oct 2002
    Re: Lee's Garage
    nice mate.
    www.shonkyopels.de
  24. #7698
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    erm, asap i suppose, we're gonna do some shaking down ourselves before it goes there, so we know its ready this time! be nice to finally see it drive up and down the lane soon though!!
    SHoNkyOpELs.de
  25. #7699
    Jul 2009
    South East
    Corsa C 1.8 on ITBs
    Re: Lee's Garage
    Manta's looking awesome. You not tempted to spray the bay red while the engine's out one of these many times? I don't dislike it white but it'll be a slag to keep clean....
  26. #7700
    Jun 2010
    Re: Lee's Garage
    Looking good cant wait to see the finished article.
  1. 29-01-2012, 23:45
  2. 24-01-2012, 18:34
  3. 19-01-2012, 16:52
  4. 01-12-2011, 12:03
  5. 23-10-2011, 21:43
  6. 21-10-2011, 21:14
  7. 28-09-2011, 20:36
  8. 15-08-2011, 12:06
  9. 10-08-2011, 15:21
  10. 28-07-2011, 15:07
  11. 06-07-2011, 08:40
  12. 29-06-2011, 06:57
  13. 27-06-2011, 19:30
  14. 28-05-2011, 16:33
  15. 25-05-2011, 12:39
  16. 19-05-2011, 16:50
  17. 19-05-2011, 16:50
  18. 18-05-2011, 22:03
  19. 17-05-2011, 09:57
  20. 16-05-2011, 21:53
  21. 10-05-2011, 23:19
  22. 18-04-2011, 05:13
  23. 11-04-2011, 06:46
  24. . .
    Refback This thread
    07-04-2011, 07:52
  25. 12-03-2011, 02:57
  26. 11-03-2011, 19:05
  27. 19-01-2011, 23:02
  28. 02-12-2010, 23:29
  29. 01-12-2010, 20:20
  30. 28-09-2010, 16:30
  31. 28-09-2010, 11:05
  32. 29-08-2010, 10:54
  33. 27-08-2010, 21:57
  34. 19-08-2010, 10:31
  35. 27-07-2010, 11:52
  36. 24-07-2010, 00:49
  37. 18-07-2010, 17:03
  38. 24-06-2010, 09:39
  39. 14-06-2010, 16:47
  40. 17-05-2010, 21:07
  41. 12-05-2010, 00:53
  42. 12-03-2010, 23:31
  43. 05-03-2010, 18:35
  44. 03-03-2010, 00:41
  45. 25-02-2010, 18:47
  46. 03-02-2010, 16:40
  47. 30-01-2010, 19:13
  48. 16-01-2010, 21:38
  49. 16-01-2010, 19:15
  50. 19-07-2009, 02:19
  51. 19-07-2009, 01:37
  52. 06-07-2009, 12:25
  53. 24-06-2009, 09:15
  54. 24-06-2009, 08:53
  55. 26-01-2009, 16:28
  56. 21-01-2009, 19:07
  57. 21-01-2009, 16:13
  58. 21-01-2009, 16:10
  59. 21-01-2009, 16:10
  60. 22-12-2008, 09:43
  61. 21-12-2008, 10:52
  62. 20-12-2008, 21:30
  63. 20-12-2008, 21:15
  64. 17-12-2008, 12:47
  65. 10-11-2008, 09:20
  66. 21-10-2008, 16:20
  67. 29-09-2008, 14:10
  68. 29-09-2008, 14:07
  69. 29-09-2008, 12:06
  70. 26-09-2008, 06:47
  71. 24-09-2008, 09:14
  72. 22-09-2008, 21:09
  73. 22-09-2008, 11:50
  74. 22-09-2008, 08:51
  75. 22-09-2008, 06:54
  76. 03-09-2008, 10:42
  77. 10-07-2008, 17:33
  78. 25-06-2008, 14:01
  79. 24-06-2008, 23:32
  80. 24-06-2008, 20:55
  81. 24-06-2008, 19:31
  82. 24-06-2008, 19:30
  83. 24-05-2008, 10:08
  84. 22-05-2008, 19:42
  85. 22-05-2008, 19:20
  86. 22-05-2008, 18:43
  87. 22-05-2008, 18:43
  88. 06-05-2008, 13:38
  89. 04-05-2008, 00:00
  90. 03-05-2008, 23:16
  91. 03-05-2008, 22:09
  92. 03-05-2008, 20:45
  93. 03-05-2008, 20:43
  94. 03-05-2008, 20:42
  95. 10-01-2008, 17:44
  96. 29-11-2007, 13:14
