Page 268 of 400 FirstFirst ... 168 218 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 318 368 ... LastLast
Results 6,676 to 6,700 of 9990
Thread: Lee's Garage
  1. #6676
    Oct 2003
    glasgow/oban
    like its a hire car
    Re: Lee's Garage
    Its IRS, so a complete set of control arms, hub, shock, spring, brake, wheel and quarter panel would be the least I would want to change before trusting it 100% again
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by jr@corsasport View Post
    **** i cant imagine you beeing that calm in that event mate ? beam/stub axel and 1/4 or more serious ?
    LOL, i was, until he said i 'must be a terrible driver' at which point i 'suggested' we just swap details and leave it at that....
    such a ball ache though, hire car company rang the wrong phone all day so no hire car till tomorrow, ditto the bodyshop, deep joy...
    SHoNkyOpELs.de
  4. #6678
    Nov 2005
    Chester - North West
    Vectra C CDTI
    Re: Lee's Garage
    you could put the VW boys to shame with that camber Lee. Glad your ok tho thats the main thing
    I've fixed this for you. Benn
  5. #6679
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Re: Lee's Garage
    That nova goes like a rocket! looks and sounds so good, hope you get the focus sorted!
    Daz.
  6. #6680
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by Kev_G View Post
    lol, sadly yes, has some decent toe in too!! and cheers
    Quote Originally Posted by daz1492 View Post
    Daz.
    cheers, will remove the video shortly though, as soon as i finish winding up the people leaving comments on it about undertaking and 2 litre turboslmao
    SHoNkyOpELs.de
  7. #6681
    Glasgow
    saab turbo
    Re: Lee's Garage
    lee as long as your ok thats the main thing. the rest is metal and can be fixed/repaired as neccessary
    you can't
    curiosity killed the cat...................but for a while i was a suspect!!
  8. #6682
    Dec 2008
    banbury
    Re: Lee's Garage
    2 litre turboslmao
    was an 09 impreza, 2.5l turbo mate, lol
  9. #6683
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by Ghost_Walker View Post
    you can't
    Quote Originally Posted by alexcrosse View Post
    must be fun to have nothing to do all day except trawl through youtube looking for things to get upset about lmao
    SHoNkyOpELs.de
  10. #6684
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    righty, went up this evening and did absolutely nothing lmao!! did route through some gearboxes for willay and measure a alternator mount for spanish, but other than that it was an evening of pure mincing, old school stylee
    Brian has had a go at his first manifolds first primary though, looks bloody great!!
    the tube peened out to eh inside of the flange nicely whe it was still warm from welding
    he did get it somewhat hot though as he was having so much fun with the tig torch, but the bench will be fine once we make a new top lmao
    so, one down 5 to go but he doesn't want to do them all till he gets the secondary tubing as he wont be able to get to all the tubes for welding if he does, so this weekend should see some significant progress
    SHoNkyOpELs.de
  11. #6685
    May 2007
    Hinckley
    '98 Corsa XE
    Re: Lee's Garage
    Exhaust looks impressive! Managed to borrow a bore mic and micrometer from work today and measured up my crank and block turns out everything is ok, thanks for the advice
  12. #6686
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    just saw that in your thread, good stuff! wish i had access to nice micrometers at worklmao
    SHoNkyOpELs.de
  13. #6687
    May 2007
    Hinckley
    '98 Corsa XE
    Re: Lee's Garage
    The guys at work are really helpful and certainly know there stuff just a shame it's for motorbikes and not vauxhalls! Was a bit nervous knowing how expensive they are but well worth knowing it's right from the start. Any idea where I can get mains bolts from? Seem to be able to find con rod bolts but not mains... Sorry for the thread hi-jack.
  14. #6688
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    vaux is your best bet tbh, or SBD if you want non stander, i always use stock ones though, not had one fail ever
    SHoNkyOpELs.de
  15. #6689
    Feb 2007
    Northants
    Re: Lee's Garage
    I know it's a bit late, but I did my uni placement at BTB so I can give you a few insider tips on making that manifold.
    Tip 1 - If you can, stick the tube through the flange (oo-err) so that you have a few mm poking out the other side, and leave this on while you weld it.
    Tip 2 - You should tack the primary in place first and then use a blowtorch (or oxy-acetylene) to heat the inside of the primary up so you can bash it out to shape. Use a tool made from some bar stock (about 20mm dia), about 8 inches long so you can hold one end, and a hammer. The idea is you stick the shaping "tool" down the primary and then wallop it with a hammer to shape the primary to the flange - i.e. the tool is held perpendicular to the flange and you hit it sideways. It works perfectly.
    Oh and round the end of the tool off so you don't get marks on the inside of the primary!
    Tip 3 - Weld the primary to the flange after you've done this, then carefully grind off the excess primary tube. You can tap the primary out a bit if there are any gaps between it and the flange, but it should be pretty good.
    Also, your flange isn't going to be very flat after you've welded it, so you should look into getting it linished flat afterwards.
  16. #6690
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    righty, a fun filled tuesday, mainly because i have nothing to do so just spend my time eating chicken nuggets and taking the piss out of the manta builders…
    although matts is taking some shape now!!
    admittedly, its mostly just a shape, but i like it! lmao
    brian meanwhile removed the v6 currently in the bay to sort the clutch release bearing while he waits for more exhaust tubing to turn up
    he can finish his dry sump off too, apparently, its working quite well at scavenging already!! lmao
    oh, and we arsed about a bit too…
    more on that later...
    SHoNkyOpELs.de
  17. #6691
    MIGWeb User novashed's Avatar
    Feb 2003
    northampton
    manta A/ combo/e46 328se
    Re: Lee's Garage
    more on that later...[/quote]
    lol we've all done this i think?!
  18. #6692
    Mar 2005
    newport s.wales
    nova
    Re: Lee's Garage
    nice sump
    Built by Pete Burgess, Mapped by Dave Young
  19. #6693
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by novashed View Post
    lol, it has to be done!!
    Quote Originally Posted by corsakid View Post
    nice sump
    its great tbh, the stock scraper luckily works really wll so you don't need a complicated pan, but brains design is sweet!
    SHoNkyOpELs.de
  20. #6694
    Oct 2003
    glasgow/oban
    like its a hire car
    Re: Lee's Garage
    looking good all round! Whats left to do on the nova now? Did the chair feel much safer now youre protected during chicken soup manoeuvres?
  21. #6695
    Sep 2009
    Livingston, West Lothian
    corsa sport 1.6
    Re: Lee's Garage
    just out of curiosity is that built-up with body filler? or fabricated panels with a coat of filler?
    any more pics of the manta? not entirely keen on it at the moment but it's still in the building stage... lol.
  22. #6696
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by alistairolsen View Post
    yesh, although i'm not entirely convinced of its lateral support still...
    Quote Originally Posted by corsaXEV_chris View Post
    its made of expanding foam, filler and fiberglass right now, but thats just the 'mould' as he will be making the entire thing out of fiberglass, DTM clip styleee
    SHoNkyOpELs.de
  23. #6697
    Nov 2005
    Vectra C CDTI
    Re: Lee's Garage
    any news on the focus lee?
  24. #6698
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    nope! must ring them tomorrow as it goes lol
    SHoNkyOpELs.de
  25. #6699
    Re: Lee's Garage
    Manta is gonna be hoooooooooooooooooooj.
  26. #6700
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    it certainly wont be shy!!
    oh and al, only half answered, not sure with the nova tbh, drive it i guess maybe some small tweaks before germany, but not sure yet...i kind of make it up as i go along anywaylmao
    SHoNkyOpELs.de
  1. 29-01-2012, 23:45
  2. 24-01-2012, 18:34
  3. 19-01-2012, 16:52
  4. 01-12-2011, 12:03
  5. 23-10-2011, 21:43
  6. 21-10-2011, 21:14
  7. 28-09-2011, 20:36
  8. 15-08-2011, 12:06
  9. 10-08-2011, 15:21
  10. 28-07-2011, 15:07
  11. 06-07-2011, 08:40
  12. 29-06-2011, 06:57
  13. 27-06-2011, 19:30
  14. 28-05-2011, 16:33
  15. 25-05-2011, 12:39
  16. 19-05-2011, 16:50
  17. 19-05-2011, 16:50
  18. 18-05-2011, 22:03
  19. 17-05-2011, 09:57
  20. 16-05-2011, 21:53
  21. 10-05-2011, 23:19
  22. 18-04-2011, 05:13
  23. 11-04-2011, 06:46
  24. . .
    Refback This thread
    07-04-2011, 07:52
  25. 12-03-2011, 02:57
  26. 11-03-2011, 19:05
  27. 19-01-2011, 23:02
  28. 02-12-2010, 23:29
  29. 01-12-2010, 20:20
  30. 28-09-2010, 16:30
  31. 28-09-2010, 11:05
  32. 29-08-2010, 10:54
  33. 27-08-2010, 21:57
  34. 19-08-2010, 10:31
  35. 27-07-2010, 11:52
  36. 24-07-2010, 00:49
  37. 18-07-2010, 17:03
  38. 24-06-2010, 09:39
  39. 14-06-2010, 16:47
  40. 17-05-2010, 21:07
  41. 12-05-2010, 00:53
  42. 12-03-2010, 23:31
  43. 05-03-2010, 18:35
  44. 03-03-2010, 00:41
  45. 25-02-2010, 18:47
  46. 03-02-2010, 16:40
  47. 30-01-2010, 19:13
  48. 16-01-2010, 21:38
  49. 16-01-2010, 19:15
  50. 19-07-2009, 02:19
  51. 19-07-2009, 01:37
  52. 06-07-2009, 12:25
  53. 24-06-2009, 09:15
  54. 24-06-2009, 08:53
  55. 26-01-2009, 16:28
  56. 21-01-2009, 19:07
  57. 21-01-2009, 16:13
  58. 21-01-2009, 16:10
  59. 21-01-2009, 16:10
  60. 22-12-2008, 09:43
  61. 21-12-2008, 10:52
  62. 20-12-2008, 21:30
  63. 20-12-2008, 21:15
  64. 17-12-2008, 12:47
  65. 10-11-2008, 09:20
  66. 21-10-2008, 16:20
  67. 29-09-2008, 14:10
  68. 29-09-2008, 14:07
  69. 29-09-2008, 12:06
  70. 26-09-2008, 06:47
  71. 24-09-2008, 09:14
  72. 22-09-2008, 21:09
  73. 22-09-2008, 11:50
  74. 22-09-2008, 08:51
  75. 22-09-2008, 06:54
  76. 03-09-2008, 10:42
  77. 10-07-2008, 17:33
  78. 25-06-2008, 14:01
  79. 24-06-2008, 23:32
  80. 24-06-2008, 20:55
  81. 24-06-2008, 19:31
  82. 24-06-2008, 19:30
  83. 24-05-2008, 10:08
  84. 22-05-2008, 19:42
  85. 22-05-2008, 19:20
  86. 22-05-2008, 18:43
  87. 22-05-2008, 18:43
  88. 06-05-2008, 13:38
  89. 04-05-2008, 00:00
  90. 03-05-2008, 23:16
  91. 03-05-2008, 22:09
  92. 03-05-2008, 20:45
  93. 03-05-2008, 20:43
  94. 03-05-2008, 20:42
  95. 10-01-2008, 17:44
  96. 29-11-2007, 13:14
