Page 220 of 400 FirstFirst ... 120 170 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 270 320 ... LastLast
Results 5,476 to 5,500 of 9990
Thread: Lee's Garage
  1. #5476
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    it may well get a remap yes, not sure if it'll be before september though
    as for head ccing, yeah basically you have the right idea, you can seal the valves in with grease so you dont have to lap them, ideally you would dry build the head and have a piston in the bore at tdc(grease the rings and mock up gasket to help them seal) then with the head in place fill the top up via the plug hole, this takes everything into account including your valve cut outs
    then work out your swept volume( pi r squared times stroke) add the cc figue you get to that and then divide the whole lot by the cc figure, gives you your static cr
    SHoNkyOpELs.de
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    you can then take a cc of the head off the car using a bit of perspex to seal the chamber up, so you can equalise all the chamber volumes, and easily work out how much you need to remove skim-wise to get your desired cr
    SHoNkyOpELs.de
  4. #5478
    Jan 2006
    Maidstone, Kent
    Re: Lee's Garage
    even if i wanted to, if i needed too i dont think i would be able to skim it much due to lift on the cams! lol
    what CC was you head?
    X18XE1 & Z18XE:
    bore: 80.5 mm, stroke: 88.2 mm, capacity: 1796 cc
    Compression ratio: 10.5:1
    Max power: 85 kw @ 5400 rpm
    Max torquw: 170 Nm @ 3400 rpm
    and
    Pie(3.142)x r(40.25)squared x stroke(88.2)
    pie x 1620.06 (2dp) x 88.2
    pie x 142889.51 (2dp)
    448958.85mm3 (2dp) = swept volume
    44895.89cm3
    is that right! lol
  5. #5479
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    yeah those figures are right, i think my head was 48cc as stock but not 100% on that, i then skimmed off 45 thou, which is loads, and i had the block decked a bit too to get to 12.2-1
    SHoNkyOpELs.de
  6. #5480
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Re: Lee's Garage
    Holiday in Germany Lee, or something else?
    Wedding Photographer packages starting at just Ј500!!
  7. #5481
    Jan 2006
    Maidstone, Kent
    Re: Lee's Garage
    right il finish my inlet porting this week, and get cracking (still awaiting shims from piper to turn up mind!)
    stock is 10.5:1
    at a guess, after piston cuts out, and head work, with a skim it might not bring it back to 10.5:1
    how much of a difference to power would upping it to say 11.0:1 and 11.5:1 etc etc?
  8. #5482
    Jul 2006
    oban, scotland
    corsa rally car
    Re: Lee's Garage
    cheers, if they were stock Vaux bits then i wouldn't need a tool tbh, its just the Hewland design makes removing the flanges extra tough, if this tool fails i'll use a porta power as before, just don't really like putting so much load on the gearcasing!
    sorry forgot you had the hewland box!
  9. #5483
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by DaveB View Post
    bit of a (30th)birthday treat to myself, hiring a megane r26r at the ring and getting very drunk with team shonkyopels.de mainly...cant wait!
    Quote Originally Posted by Warren-G View Post
    stock is 10.5:1
    i couldnt tell you a figure for the different compression, but tbh you wont want to be going anywhere above 11.5 on stock piston crowns anyway
    SHoNkyOpELs.de
  10. #5484
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by kennybarbour View Post
    yeah no worries mate
    SHoNkyOpELs.de
  11. #5485
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Re: Lee's Garage
    Sounds like fun Lee! Whats the cost on the hiring/insurance etc?
  12. #5486
    Jan 2006
    Maidstone, Kent
    Re: Lee's Garage
    oh right, well id think if i could just keep it 10.5:1 that would be fine
    was interested what real difference it would make that was all, for what reason couldnt you do that (again out of interest what would happen)
  13. #5487
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    erm, i'm hiring for one fully inclusive day split over two evening sessions(cheers dale!) comes to 999 euros, including lap tickets and fuel, looks to be a bloody good car though, caged up, decent tyres etc, and the best thing is its not mine!
    they do cheaper cars(alfas, clios etc) and more expensive(m3 gt3!!)details here
    Home of 'ring rentals and instruction
    SHoNkyOpELs.de
  14. #5488
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    the cylinder pressures would get to the point that the piston collapsed, same as in the 1600, you'd need some omegas or similar after that, i think 10.5 should be achievable, you can deck the block a little bit too and gain some power by reducing the squish clearance, needs careful mock up measuring though! remember the rods will stretch at higher revs, so add .5mm to any clearance you're measuring
    SHoNkyOpELs.de
  15. #5489
    Jan 2006
    Maidstone, Kent
    Re: Lee's Garage
    i know what you mean about decking the block, then modding the pistons, but i dont think il be doing that due to my clearance issues!
    what spring rates are you running lee?
  16. #5490
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    suspension? 275 front 400 rear
    SHoNkyOpELs.de
  17. #5491
    Dec 2001
    East Sussex
    Cav with TB's & lots
    Re: Lee's Garage
    30th???? you old old old old old git! lmao
    New focus looks good.
    Is that 'panther black'?
    999euros could get you a few real good hookers or even a young hotel maid for the night!
  18. #5492
    Dec 2004
    Essex
    Re: Lee's Garage
    well there wasnt any talk of not getting any hookers...
  19. #5493
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    Quote Originally Posted by Giles View Post
    i know, must be bad when you get to like 35 or so huh?
    and yes it is panther black, just ordered some new brakes and suspension for it, they'll be here in a week or so, let the subtle mods commence!
    Quote Originally Posted by William View Post
    lmao
    SHoNkyOpELs.de
  20. #5494
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    so, got the new car to the garage today, did an oil change and filter service, air and fuel, then got rid of the unsightly tow bar and some of the tack badging
    before:
    after, much better!
    needs some better headlight bulbs though...
    and then when the bits turn up, suspension and brakes
    oh, did find time to remove the driveshaft from the nova too
    then predictably bent the man tool trying to remove the drive flange, so gave up and came homelmao will get the diff out somehow on saturday...
    SHoNkyOpELs.de
  21. #5495
    MIGClub Member MattJ's Avatar
    Oct 2001
    Kent
    Toyota Celica GT4
    Re: Lee's Garage
    fook mofo, cant believe you bent your 'tool' on the 'flange' *snigger*
  22. #5496
    Re: Lee's Garage
    Turn your damn fogs off!
    Are you still having cv probs?
  23. #5497
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    i know, the flange is just so tight though, it was inevitable...
    SHoNkyOpELs.de
  24. #5498
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    dont worry i dont drive with them on benn, was just for the pic, and i think i have broken something in the diff with my cv woes, probably at brands when i repeatedly blew them to bits at full chat round clearways, giving the diff some odd loadings(and trying to spit me into the pit wall!!)
    SHoNkyOpELs.de
  25. #5499
    Oct 2001
    Kent
    Toyota Celica GT4
    Re: Lee's Garage
    was a proper thick tool though jeeeez get some lube
  26. #5500
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Lee's Garage
    was fully lubed up, even took a run up at one point
    SHoNkyOpELs.de
  1. 29-01-2012, 23:45
  2. 24-01-2012, 18:34
  3. 19-01-2012, 16:52
  4. 01-12-2011, 12:03
  5. 23-10-2011, 21:43
  6. 21-10-2011, 21:14
  7. 28-09-2011, 20:36
  8. 15-08-2011, 12:06
  9. 10-08-2011, 15:21
  10. 28-07-2011, 15:07
  11. 06-07-2011, 08:40
  12. 29-06-2011, 06:57
  13. 27-06-2011, 19:30
  14. 28-05-2011, 16:33
  15. 25-05-2011, 12:39
  16. 19-05-2011, 16:50
  17. 19-05-2011, 16:50
  18. 18-05-2011, 22:03
  19. 17-05-2011, 09:57
  20. 16-05-2011, 21:53
  21. 10-05-2011, 23:19
  22. 18-04-2011, 05:13
  23. 11-04-2011, 06:46
  24. . .
    Refback This thread
    07-04-2011, 07:52
  25. 12-03-2011, 02:57
  26. 11-03-2011, 19:05
  27. 19-01-2011, 23:02
  28. 02-12-2010, 23:29
  29. 01-12-2010, 20:20
  30. 28-09-2010, 16:30
  31. 28-09-2010, 11:05
  32. 29-08-2010, 10:54
  33. 27-08-2010, 21:57
  34. 19-08-2010, 10:31
  35. 27-07-2010, 11:52
  36. 24-07-2010, 00:49
  37. 18-07-2010, 17:03
  38. 24-06-2010, 09:39
  39. 14-06-2010, 16:47
  40. 17-05-2010, 21:07
  41. 12-05-2010, 00:53
  42. 12-03-2010, 23:31
  43. 05-03-2010, 18:35
  44. 03-03-2010, 00:41
  45. 25-02-2010, 18:47
  46. 03-02-2010, 16:40
  47. 30-01-2010, 19:13
  48. 16-01-2010, 21:38
  49. 16-01-2010, 19:15
  50. 19-07-2009, 02:19
  51. 19-07-2009, 01:37
  52. 06-07-2009, 12:25
  53. 24-06-2009, 09:15
  54. 24-06-2009, 08:53
  55. 26-01-2009, 16:28
  56. 21-01-2009, 19:07
  57. 21-01-2009, 16:13
  58. 21-01-2009, 16:10
  59. 21-01-2009, 16:10
  60. 22-12-2008, 09:43
  61. 21-12-2008, 10:52
  62. 20-12-2008, 21:30
  63. 20-12-2008, 21:15
  64. 17-12-2008, 12:47
  65. 10-11-2008, 09:20
  66. 21-10-2008, 16:20
  67. 29-09-2008, 14:10
  68. 29-09-2008, 14:07
  69. 29-09-2008, 12:06
  70. 26-09-2008, 06:47
  71. 24-09-2008, 09:14
  72. 22-09-2008, 21:09
  73. 22-09-2008, 11:50
  74. 22-09-2008, 08:51
  75. 22-09-2008, 06:54
  76. 03-09-2008, 10:42
  77. 10-07-2008, 17:33
  78. 25-06-2008, 14:01
  79. 24-06-2008, 23:32
  80. 24-06-2008, 20:55
  81. 24-06-2008, 19:31
  82. 24-06-2008, 19:30
  83. 24-05-2008, 10:08
  84. 22-05-2008, 19:42
  85. 22-05-2008, 19:20
  86. 22-05-2008, 18:43
  87. 22-05-2008, 18:43
  88. 06-05-2008, 13:38
  89. 04-05-2008, 00:00
  90. 03-05-2008, 23:16
  91. 03-05-2008, 22:09
  92. 03-05-2008, 20:45
  93. 03-05-2008, 20:43
  94. 03-05-2008, 20:42
  95. 10-01-2008, 17:44
  96. 29-11-2007, 13:14
