Lee's Garage
Page 21 of 405 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 71 121 ... LastLast
Results 501 to 525 of 10119
Thread: Lee's Garage
  1. #501
    MIGWeb User novashed's Avatar
    Feb 2003
    northampton
    manta A + manta B
    im by no means as experienced as lee with this lump, another guy on here worth speaking to is a local guy to me broster, gained some amazing results from this lump too, think he had a TV feature
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Quote Originally Posted by CraigGreen View Post
    Envious of your progress Lee (as usual).
    How vital are verniers to the output of the engine? Mine has Schrick cams, Mantzel inlet & I might get a BTB manifold. Would the verniers reign in many more ponies in your opinion?
    I doubt I'll look to TBs in the future however.
    super vital if you ask me, aftermarket cams dont tend to have a dowel for the cam pulleys, and even if they do they dont tend to make them that accurate as the cam is designed to work in one position, and what with variations in stuff like height of head off the block affecting things you ould get diffrerent result everytime without a vernier
    i prefer to set my cams up at TDC using the lift on overlap figures as its more accurate than the old degrees for full lift system
    i've seen jumps of 30 BHP on the rollers due to incorectly trimed cams that were only a few degrees out!
    whats the spec of your cams anyways?
  4. #503
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    i need to find some angrier cams for mine!
  5. #504
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    you ona stock ecu? if so you should wait till you get management as you'll be able to make the best use of them then
  6. #505
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    yeah on stock ECU at mo...
    Lee you know any info on the Dastek units that just raise the rev limit?
  7. #506
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    not anything specific, but all the mantzel stuff i've seen have weird power curves that seem to spike at about 5k, limitations of a plenum without a huge cad designed carbon induction box i spose
    just had a thought though, if you use the stock ecu you wont be able to fit verniers as you need the camsensor lumps on the pulley
  8. #507
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    So in other words wait till i do carbs and do the whole lot at once?
  9. #508
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, but i hate carbs, i can understand from a cost point of view, but they just cant do what you need them to, but then i am a bit of an engine freak!
  10. #509
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    haha its not a plan ill be doing soon... maybe next summer if i still have money to spend.
    We'll see.... depends what happens between now and then lmao
  11. #510
    Apr 2006
    Atherstone
    2 many 2 list
    just while were on the subject of cams lee whats the biggest these engines can take before pocketing the pistions is required??? (sp)
  12. #511
    Apr 2006
    biggest cams without pocketed pistons is about 264 degrees (depends on lift at tdc as well). You can fit Dbilas verniers and retain the standard management, they have the cam sensor lugs on them.
  13. #512
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    absolutely no point in fitting cams if they will fit without doing the pistons IMO, they're just too mild for the effort
  14. #513
    Apr 2006
    Atherstone
    2 many 2 list
    nasty pistons it is then (i remember u tellin me know about this lee) hows the nova comin on any further???
  15. #514
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    errr
    bearings are replaced, just got to get some locktight for the flywheel bolts then i'll be putting it back together and in the car
  16. #515
    are the bearing knacked?
  17. #516
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    little bit worn, the high revs tend to shorten the bearing life a bit, and while its out it just makes sense to stick some in
  18. #517
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Nice work mate. Coming along splended! See I would also give the engine a mini rebuild while it's out. Rude not to!
    Lee I 100% back you there. Carbs are just wrong. Turning a modern injection car into carbs just doesn't give the outcome you'd expect. My old nova I had a 1650 on Twin 40's. The sound was awesome, and it was fun at the higher end of the rev range. Around town/traffic it was quite tideous! Rob I strongly suggest to listen to Lee there. Even bike TBs would be loads better than carbs. Standalone management with your plenem would be interesting!
    www.shonkyopels.de
  19. #518
    Apr 2006
    Atherstone
    2 many 2 list
    would i be right in expecting me engine to rev round to 8000rpm maybe a bit more lee? gonna arp bolt in together and up rate the con-rods, pistins and get the crank tuff rided any other advice??
  20. #519
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    you should always listen to me! lmao
    stuart, if you fit steel rods, omegas and get the lot balanced then you can go to 8500 for short bursts(hydraulic lifters being the hold up) with solids you can go to 9k but your oil pump wont go any higher than that, dry sump if you want silly(i.e pointless) revs
    as for other tips, i like having the flywheel double doweled to the crank as its fairly cheap and helps your flywheel bolts out, but as with any engine, the key to higfh revs is getting the head to flow well enough to make it worth it
  21. #520
    Apr 2006
    Atherstone
    2 many 2 list
    Plus i havnt won the lottery yet!!
    Thats were you come in!!
    Whats your middle name lee SMALL XE!!lmao cheers
  22. #521
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    its james, somewhat dissapointingly lmao
  23. #522
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    super vital if you ask me, aftermarket cams dont tend to have a dowel for the cam pulleys, and even if they do they dont tend to make them that accurate as the cam is designed to work in one position, and what with variations in stuff like height of head off the block affecting things you could get different results everytime without a vernier
    I prefer to set my cams up at TDC using the lift on overlap figures as its more accurate than the old degrees for full lift system
    I've seen jumps of 30 BHP on the rollers due to incorectly timed cams that were only a few degrees out!
    My engine has the Schrick cams in. I know no more as I bought the engine like that with the Mantzel plenum etc complete.
    30bhp jumps?? On TBs & management I assume?
  24. #523
    Oct 2002
    Listening. What put this <raises index finger> in your bum bum!?!?! Thats sick
    www.shonkyopels.de
  25. #524
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, was an xe, the owner was surprised to say the least!
    you're going turbo no? would have thought you'd want some thing a bit different to an na fast road cam for that
  26. #525
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Quote Originally Posted by spanishfly View Post
    lmao
  1. 02-05-2012, 14:02
  2. 01-04-2012, 20:17
  3. 20-03-2012, 12:51
  4. 29-01-2012, 22:45
  5. 24-01-2012, 17:34
  6. 19-01-2012, 15:52
  7. 01-12-2011, 11:03
  8. 23-10-2011, 20:43
  9. 21-10-2011, 20:14
  10. 28-09-2011, 19:36
  11. 15-08-2011, 11:06
  12. 10-08-2011, 14:21
  13. 28-07-2011, 14:07
  14. 06-07-2011, 07:40
  15. 29-06-2011, 05:57
  16. 27-06-2011, 18:30
  17. 28-05-2011, 15:33
  18. 25-05-2011, 11:39
  19. 19-05-2011, 15:50
  20. 19-05-2011, 15:50
  21. 18-05-2011, 21:03
  22. 17-05-2011, 08:57
  23. 16-05-2011, 20:53
  24. 10-05-2011, 22:19
  25. 18-04-2011, 04:13
  26. 11-04-2011, 05:46
  27. . .
    Refback This thread
    07-04-2011, 06:52
  28. 12-03-2011, 01:57
  29. 11-03-2011, 18:05
  30. 19-01-2011, 22:02
  31. 02-12-2010, 22:29
  32. 01-12-2010, 19:20
  33. 28-09-2010, 15:30
  34. 28-09-2010, 10:05
  35. 29-08-2010, 09:54
  36. 27-08-2010, 20:57
  37. 19-08-2010, 09:31
  38. 27-07-2010, 10:52
  39. 23-07-2010, 23:49
  40. 18-07-2010, 16:03
  41. 24-06-2010, 08:39
  42. 14-06-2010, 15:47
  43. 17-05-2010, 20:07
  44. 11-05-2010, 23:53
  45. 12-03-2010, 22:31
  46. 05-03-2010, 17:35
  47. 02-03-2010, 23:41
  48. 25-02-2010, 17:47
  49. 03-02-2010, 15:40
  50. 30-01-2010, 18:13
  51. 16-01-2010, 20:38
  52. 16-01-2010, 18:15
  53. 19-07-2009, 01:19
  54. 19-07-2009, 00:37
  55. 06-07-2009, 11:25
  56. 24-06-2009, 08:15
  57. 24-06-2009, 07:53
  58. 26-01-2009, 15:28
  59. 21-01-2009, 18:07
  60. 21-01-2009, 15:13
  61. 21-01-2009, 15:10
  62. 21-01-2009, 15:10
  63. 22-12-2008, 08:43
  64. 21-12-2008, 09:52
  65. 20-12-2008, 20:30
  66. 20-12-2008, 20:15
  67. 17-12-2008, 11:47
  68. 10-11-2008, 08:20
  69. 21-10-2008, 15:20
  70. 29-09-2008, 13:10
  71. 29-09-2008, 13:07
  72. 29-09-2008, 11:06
  73. 26-09-2008, 05:47
  74. 24-09-2008, 08:14
  75. 22-09-2008, 20:09
  76. 22-09-2008, 10:50
  77. 22-09-2008, 07:51
  78. 22-09-2008, 05:54
  79. 03-09-2008, 09:42
  80. 10-07-2008, 16:33
  81. 25-06-2008, 13:01
  82. 24-06-2008, 22:32
  83. 24-06-2008, 19:55
  84. 24-06-2008, 18:31
  85. 24-06-2008, 18:30
  86. 24-05-2008, 09:08
  87. 22-05-2008, 18:42
  88. 22-05-2008, 18:20
  89. 22-05-2008, 17:43
  90. 22-05-2008, 17:43
  91. 06-05-2008, 12:38
  92. 03-05-2008, 23:00
  93. 03-05-2008, 22:16
  94. 03-05-2008, 21:09
  95. 03-05-2008, 19:45
  96. 03-05-2008, 19:43
  97. 03-05-2008, 19:42
  98. 10-01-2008, 16:44
  99. 29-11-2007, 12:14
