Page 9 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 201 to 225 of 866
Thread: Few pics of my corsa turbo project
  1. #201
    bux
    bux is offline
    Jul 2006
    Northants
    12.1 sec Corsa..@120
    hubs and shafts goin on this weekend, fill up the gearbox, make a temp exhaust and some kinda temp cooling system and let it tick over for a little bit.............let it cool then do it again....lol. want to run it in nicely!!!
    12 second corsa....12.1 @ 120mph
    vauxsport.com
    Total Vauxhall Cover Car Jan 2009
    Jul 2006
    south wales
    F**d Transit
    nearly there now mate and looking good too ive got the same jobs to do on mine make an exhaust sort out cooling temp and fill the f28 with oil oh and a few wires
    I couldn't repair your brakes, so I made your horn louder.
  4. #203
    bux
    bux is offline
    Jul 2006
    Northants
    have been working on the car tonight, have got the outer cv joints on the shafts, got the m-tec big hubs pressed into the hub assembly's with new bearings, have fitted up the 2.0 16v brakes, fitted a shortened down pipe, and fitted all new bushes in the gear linkage (inside the car) gears are nice now, just waiting for inner joint to turn up tomorrow fingers crossed so i can get the shafts in and fill up the gearbox and get it ticking over for a bit........
    vauxsport.com
  5. #204
    bux
    bux is offline
    Jul 2006
    Northants
    ok front mount is now on!! im well chuffed with how it looks.............wot you rekon??
    a couple of vids...........please note only down pipe is on so its a bit loud!!
    ticking over..........
    http://smg.photobucket.com/albums/v6...running008.flv
    a little rev
    http://smg.photobucket.com/albums/v6...running009.flv
    hope you like
    vauxsport.com
  6. #205
    Suffolk
    335d E90
    Looks proper mate, well suited!
    DRIZZ
    DEVELOPMENTS
  7. #206
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Really is a lovelt well thought out project mate. Hats off to you. Front end looks great!
    how come your turbo cover has an extra cut out at the front on the right hand side?
    Simps.
    p.s. thanks again for the info earlier.
  8. #207
    Quote Originally Posted by bux View Post
    looks great dude!
    gonna be a beasty!
  9. #208
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    stunning mate! has there been any old parts used in the engine bay at all?lmao
  10. #209
    bux
    bux is offline
    Jul 2006
    Northants
    no mostly new parts........lol
    simps, no prob for the info........and i dont no why the tubby cover has a cut out, all i can think is that it is a secondhand one that sum1 had mounted summat under it??? i can only think it would be a fuel press reg??? but its in the wrong place really!! im gunna get a new cover tho, dont want any holes on it, reins the look....lol
    vauxsport.com
  11. #210
    Sep 2004
    boston
    GSXR 600
    good work getting the vids on mate, was thinking that maybe it would be good to get mine down the pod for a drag against yours, would be close i should think, when did you say it will be on the road, and what was your web address again mate.
  12. #211
    May 2001
    South Wales
    Nippy Cav Turbo
    prob cause the silicon hose that ran to the tophat was being dug into by the edge of the tophat cover hence u then have to hacksaw a new curve so it wont rub
  13. #212
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Its not the curve I'm on about Adam. Its on the front edge of the cover. Almost like a mirror image of the cutouts for the breather pipes on tother side. Its no biggy to fix, but I just wondered if he'd done it for a reason.
  14. #213
    bux
    bux is offline
    Jul 2006
    Northants
    Quote Originally Posted by GM NERD View Post
    fingers crossed the 1st of april mate (santa pod).........but it needs to be on the road before then as i need to run it in!!!! i want to do 500miles then do an oil change, if its not run in then i wont race it. but ill let you no. check that web address youll see the list of people that are cummin from my way........
    vauxsport.com
  15. #214
    Sep 2004
    St.Austell, Cornwall
    Astra MK4 1.6 club
    That intercooler is huge compared to the one on my Corsa LET, that could expalin why I coooked it! Where did you get that one from, also how much did it set you back?
  16. #215
    bux
    bux is offline
    Jul 2006
    Northants
    got the remainder of my coolant hoses today so the cooling system is now all plumbed in, just waiting fof the fan to turn up............still waiting for my boost pipes from demon tweeks tho grrrrrrrr, took the money from me, also paid extra on the carrage and the hoses aint even in stock!!!!!!!!
    once my inner cv boot turns up the shaft on the n/s can go on and it will drive!!!!!!!!!! yey
    vauxsport.com
  17. #216
    bux
    bux is offline
    Jul 2006
    Northants
    finally got myself a cv boot today (inner) fitted the joint and shaft etc and it was ready for a test run........unfortuatly a little problem with a stupid brake pipe meant it had no brakes but it was only in the car park where our unit is............its a beast, runs nice and pulls really well.........not really touching boost tho, cant wait to get it on the road now!!!!!!!!!
    vauxsport.com
  18. #217
    Suffolk
    335d E90
    excellent, good luck with the test drive fella
    DRIZZ
    DEVELOPMENTS
  19. #218
    bux
    bux is offline
    Jul 2006
    Northants
    i drove it around the car park, the exhaust is still just the down pipe cut off...........but felt really good, the clutch is wicked, and the gears feel really nice! the suspensions is also really stiff and all feels tight like i wanted it to! i just cant wait to get it on the road now!! going to try and sort the brakes tomorrow but got alot of work to do on my bros pulsar
    vauxsport.com
  20. #219
    Jun 2004
    leicester
    astra gsi let'd
    ive been inspired buy you thead. i brought a calibra turbo friday for my astra gsi. just waiting for good weather strip my astra down.
  21. #220
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    If you are not there, I will hunt you down and kill you!
  22. #221
    bux
    bux is offline
    Jul 2006
    Northants
    like i say i will be there no matter wot......but if the corsa aint ready then i wont be running it!! if i dont run you will deffo see it running in the very near future........im really hoping it will be done tho!!!!!!!!!!!!!!!!!
    vauxsport.com
  23. #222
    Banned
    Oct 2005
    a BMW again lol
    There no pressure to run it mATE, as long as you are there,, thats what matters.
  24. #223
    bux
    bux is offline
    Jul 2006
    Northants
    ill be there, but just a quick update........i drove the car for the 1st time today (was ready to drive on fri night but the brake pipe decided to leak!! so no brakes...) so made a new brake pipe yesterday, bled the brakes and took it down the private road at my workshop.......my god its fast!! didnt really give it any as im still running it in, but christ!! couldnt believe it!!!!! want it on the road now!!!!!!!!!
    vauxsport.com
  25. #224
    Banned
    Oct 2005
    a BMW again lol
    Countdown to road going begins, whats needed to be all road worthy?
  26. #225
    Mar 2006
    Norwich
    Love the project and work gone in.
    Dan.
