Page 8 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 176 to 200 of 866
Thread: Few pics of my corsa turbo project
  1. #176
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Nice work matey, wont be long untill your hooning about in it you lucky sod!
    www.wix.com/vxlgsi/zxr-750-r
    bux
    bux is offline
    Jul 2006
    Northants
    12.1 sec Corsa..@120
    ok ive finally found some time to post up some pics of a few of my new parts (of which most are already fitted...lol)
    mocal oil cooler
    oil cooler fitting kit
    fuel rail with saab reds and 3.5 bar frp
    m-tec 6 speed short shifter
    finally my turbo is back from universal turbos, stage 1 (hybrid) with uprated actuator
    12 second corsa....12.1 @ 120mph
    vauxsport.com
    Total Vauxhall Cover Car Jan 2009
  4. #178
    Jan 2002
    Oswestry, United Kingdom
    Cbr 600 F
    How Much Was The Short Shiftrer Mate???
    Is It A Specific For The 6 Speed?
    How Much Was Turbo Recon
    Great Work!
  5. #179
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Hybrid looks great - Fair price too!
    Keith
  6. #180
    bux
    bux is offline
    Jul 2006
    Northants
    short shifter is approx £80 i think............ turbo recon cost me just over £500 but i had to have quite a bit done to it!
    vauxsport.com
  7. #181
    bux
    bux is offline
    Jul 2006
    Northants
    cheers for comments peeps.........
    well today has been very hectic, started on it at bout 9 and finished bout 5.30 but has been a very productive day tho!!
    oil cooler is now finally finished totally, had to make up a couple more mounts to finish that off........
    rear suspension is now finished too (coilovers on)
    engine wiring loom is all fitted now and completely wired up, ecu is fitted in the original corsa position which is a bloody squeeze buty its all there and good!!
    short shifter kit is fitted, had to cut and weld part of it, and also had to modify my rear mount and another part of the linkage to get clearance, finally got all the gears tho after alot of pissin about!! need to order a new bush tho for the main gear stick as its worn and is a tiny bit sloppy......and i dont want any of that!!!
    finally, started to tidy up some of the engine wiring out of the way so it looks tidy as......but then got board!
    once the turbo hoses are here im gunna fire it up!!! cant wait (thats if it starts...lol)
    few pics
    vauxsport.com
  8. #182
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    Wheres the main rad?
  9. #183
    MIGClub Member Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    looking well good! keep up great work!
  10. #184
    bux
    bux is offline
    Jul 2006
    Northants
    main rad isnt in yet!! im sorting out my hoses and then me and my mate are having custom alloys rads made! also turbo has to go on this week once the turbo coolant hoses (roose in blue silicone) get here so there wouldnt be any point in fitting it if i did have it, ive had a corsa diesel rad in there tho whils measuring and fitting all the other stuff!!
    vauxsport.com
  11. #185
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Hey Steve, what chips will you be running? Not sure if i should keep the std injectors for phase 2 or go to the saab reds, would they be overkill? Also I want a new FPR, where'd you source yours?
    Keith
  12. #186
    looks funking ace dude,
  13. #187
    bux
    bux is offline
    Jul 2006
    Northants
    keith got my fpr from lmf (they get them from m-tec), its a 3.5 bar reg and fits straight onto the original fuel rail which is wot i wanted! as for chips either going to run regal phase 2 or im going to enquire about m-tecs own chips, see wot power ratings, price etc they do. Im using saab reds, but my mate just brought a set of vxr injectors and they fitted in a treat but not sure if they are going to over fuel abit for just under 300bhp?? lmf can source a lot of different sizr fpr but i think 3.5 is ample and its the one they recommend if you go on there site for around 300bhp
    turbo's are awesome aint they!! top job they did!
    vauxsport.com
  14. #188
    bux
    bux is offline
    Jul 2006
    Northants
    did a few bits today, just really cleaned up some stuff and put some hoses in place so i can see where i can hide various wires.............btw the large silicone hose isnt final its a temp measure, i will be getting hard pipes made! but to get it running it will do for now.......
    vauxsport.com
  15. #189
    Macclesfield
    www.Retrobike.c
    Looking mint.
    Any pics of the rear coilover setup? Gaz or Avo?
    Back in the scene
  16. #190
    bux
    bux is offline
    Jul 2006
    Northants
    no i didnt take any to be fair, thought everybody wudnt wanna see them!! lol just a set of fk coil overs (gas shocks) lol.
    vauxsport.com
  17. #191
    Macclesfield
    www.Retrobike.c
    So its the standard FK rear setup, normal shock and then a spring with a height adjustable coller on the beam?
    Back in the scene
  18. #192
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Quote Originally Posted by bux View Post
    Turbo was a complete shock, i kept thinking to myself, i hope they clean it! But it came back looking awesome. Need to make sure the LET gets as clean now!
    Keith
  19. #193
    bux
    bux is offline
    Jul 2006
    Northants
    rick.....yeah thats it mate! yellow shocks, blue springs and adjustable colar that sits on the axle.......
    vauxsport.com
  20. #194
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    looks superb
  21. #195
    bux
    bux is offline
    Jul 2006
    Northants
    right quite a big update really i suppose, put the turbo on tonight along with a few other bits and bobs, such as inlet hose, plumbed in the recirc valve, and other bits and bobs, this meant that its time to see if it fires, so crank it over for a bit to get oil pressure, and plug in the coil...............will she start tho, that was the question.....lol
    of course it did, the corsa is alive!!!! wohooooooooooo only started it very briefly, it has no exhaust on it wot so ever so sounds like a tractor but i just wanted the reasurance that it would start up, im chuffed to bits now, intercooler should be on tomorrow, and ordering coolant hoses asap now too!!!
    vauxsport.com
  22. #196
    Suffolk
    335d E90
    Well done chap!
    DRIZZ
    DEVELOPMENTS
  23. #197
    Macclesfield
    www.Retrobike.c
    Its a good feeling aint it when you fire it up for the first time! Took my corsa for its first spin today, went well just the usual problems to iron out before its 100% finished.
    Back in the scene
  24. #198
    bux
    bux is offline
    Jul 2006
    Northants
    yeah deffo is mate!! sounded funny tho due to no exhaust or intercooler etc, but its just the reasuurance that it will fire up you want aint it, all the time, effort and money all seems worth it now!!!!!
    vauxsport.com
  25. #199
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    glad to hear it fired up sweet
    hopefully itll go trouble free for you from here, seeing as how youve done such a thorough job
  26. #200
    MIGClub Member CortraGTE's Avatar
    Jul 2005
    On Guard
    XE Nova
    Nice one mate looks quality!
    Royal Marines Commando
