Page 7 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 151 to 175 of 866
Thread: Few pics of my corsa turbo project
  1. #151
    bux
    bux is offline
    Jul 2006
    Northants
    12.1 sec Corsa..@120
    Quote Originally Posted by vxlgsi View Post
    I spy a Muuuuuuultii V...... Good work fella, engine bay looks imaculate....
    i also spy a multi vee, and my chassis mods seemed to have worked, it has approx 10mm of clearance...........so hopefully the engine wont move that much on its munts, but im sure it will be more front to back movement!! we'll see but im happy with it for now anyway, if it touches the chassis leg then so be it!!!!!!!!!
    12 second corsa....12.1 @ 120mph
    vauxsport.com
    Total Vauxhall Cover Car Jan 2009
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Well i wont be modifying my chassis, but if it comes to it ill make some special pulleys to solve the problem.
    www.wix.com/vxlgsi/zxr-750-r
  4. #153
    bux
    bux is offline
    Jul 2006
    Northants
    if you dont alter the chassis then it will deffo rub!! there is no way you can move the alternator over as the belt wont run true on the crank pulley then!! unless your going to make new pulleys for both the crank and alternator, but then your going to be up against trying to find a belt to run on it?? id alter the chassis its easier!!
    vauxsport.com
  5. #154
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    yeah id have to move all the pulleys over abit, ill have to see how it goes.
  6. #155
    MIGClub Member Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    looking good, love the looks of a nice clean rebuilt engine going in there!
  7. #156
    bux
    bux is offline
    Jul 2006
    Northants
    got some saab red injectors turn up today! just waiting for my fuel pressure reg now!! (3.5 bar) also got all the fuel lines plumbed in but they are very close to the steering rack boots.....so need to look into that and see wot i can do! thinking i need to try and find some thinner boots!!
    vauxsport.com
  8. #157
    Oct 2005
    clacton on sea,essex
    corsa c20let
    looking good keep it up
  9. #158
    Aug 2005
    Manchester
    A Slow Corsa
    what belt did you use, going to be wacking a xe in the corsa soon, and cant be bother changing pully's and the belt with engine is too long due to pas setup on it
  10. #159
    bux
    bux is offline
    Jul 2006
    Northants
    speak to "paddy" on here he will supply you the modified mount and belt................i did modify my own bracket but werent happy with it, his mount is spot on tho!!
    vauxsport.com
  11. #160
    Aug 2005
    Manchester
    A Slow Corsa
    modified mount for what?
  12. #161
    bux
    bux is offline
    Jul 2006
    Northants
    modified mount for the alternator adjuster, i cut my original mount out as far as i could go and the adjustment just wasnt enough!! it needed a bit fabricating and welding on the end.........BUT paddy makes a mount that fits straight on with more adjustment!! and supplies a belt with it too!
    vauxsport.com
  13. #162
    bux
    bux is offline
    Jul 2006
    Northants
    small updates.........have cahnged the steering rack boots for non genuine ones and now have clearance! which is all good, rechecked the fuel lines for leaks by buzzin the fuel pump up, all seems ok........ also my mocal oil cooler has turned up and my turbo is now being rebult with uprated internals. will be plumbin in my oil cooler at the weekend all being well!!
    vauxsport.com
  14. #163
    Dec 2006
    Ayrshire, Scotland
    1l Corsa
    Great progress, love reading threads where people strip their engine, makes me want to strip one
    looking good
  15. #164
    MIGWeb User Add_Gee's Avatar
    Mar 2002
    Birmingham
    Vectra B SRi 2.2 Estate
    good read
  16. #165
    bux
    bux is offline
    Jul 2006
    Northants
    cheers lads, all being well the turbo should be back by next weekend and bolted on!! have ordered all new pipes and copper sealing washers etc for the tubo and oil cooler connections............also ordered few other bits and bobs too! cant wait!!!!!!
    vauxsport.com
  17. #166
    bux
    bux is offline
    Jul 2006
    Northants
    bit of progress today, decided to fit up my front mount oil cooler.........had to get a universal fit mocal kit in the end (13 row) but ive managed to mount it spot on and all the connections are all good now, although i ordered about 1meter too much oil hose, will get pics for you asap, it was gettin dark tho when i finished! its a very tight squeeze wot with the rad, oil cooler, intercooler and pipes!!
    vauxsport.com
  18. #167
    Oct 2005
    corsa c20let
    hi there how close is your engine to your bonnet when closed??
    cheers
  19. #168
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Quote Originally Posted by bux View Post
    I take it the caliturbo one doesnt fit too well?
  20. #169
    Mar 2005
    Ho Chi Minh City
    Honda Cb250
    just read the whole thread, a truley top effort, good work!
    Two chavs, Dave and Bob race their Novas over a cliff to see who hits the bottom first...who wins? Society.
  21. #170
    bux
    bux is offline
    Jul 2006
    Northants
    didnt bother trying mate, the thing with the calibra turbo one is that it has metal pipes so your limited as to where you can mount it without bending the pipes...........my mocal cooler came in at only Ј115 delivered to my door and its very slightly bigger than the old cooler too, the best thing is that it looks really cool where ive mounted it (imo) and should be much more efficiant!! ill get pics asao so you can see wot you think!
    vauxsport.com
  22. #171
    bux
    bux is offline
    Jul 2006
    Northants
    Spent about an hour going through my whole loom today checking all the wires for continuety, i also took the loom to bits and pulled the 12v ignition feed (black wire) through to the inside of the grommet so i dont need any wires going through the grommet and making it look messy!! also fitted up most of the loom to the car but couldnt fit too much as im still waiting for my fpr, once that is fitted then it can all go on properly!
    vauxsport.com
  23. #172
    Jan 2007
    birmingham
    C20let corsa
    alright mate purchased my c20 let now so will be starting my thread soon on my corsa conversion, any more pictures of your project?
  24. #173
    bux
    bux is offline
    Jul 2006
    Northants
    lots of parts ordered or arrived today........
    short shifter kit is here
    3.5 bar fuel press reg is here
    turbo is back tomorrow
    lots of parts from vauxhall are here (inc turbo return pies, clips, bumper bar ready to be cut for intercooler mount etc)
    coolant turbo pipes (blue silicon....cheers to rally man)
    so tonight got the saab reds and fuel press reg in, alos put the loom in and connected all the engine bay side up...........was hoping to get the turbo coolant pipes for sat so i could put the turbo on but might have to wait now........or put it on then take it off.....should be able to fire it up if i do!!
    vauxsport.com
  25. #174
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    shouldnt it be 4.5 bar reg or have i missed something
  26. #175
    bux
    bux is offline
    Jul 2006
    Northants
    not for the power im running! (phase 2)........... saab reds and 3.5 bar reg is good for 300bhp. thats wot ive found whilst doin my research. check max-boost website, its all on there.
    vauxsport.com
