Page 6 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 126 to 150 of 866
Thread: Few pics of my corsa turbo project
  1. #126
    Sep 2004
    boston
    GSXR 600
    Cracking on nicely now mate good to see your still busy at it, wish i had that sort of motivation, have you decided what your doing with the exhaust system yet.
    bux
    bux is offline
    Jul 2006
    Northants
    12.1 sec Corsa..@120
    yes mate side exit with a nice tailpipe on the end, gunna go for 3inch from downpipe back for now as still got bits to buy and i no the exhaust aint gunna be cheap!
    still need turbo recon, mocal oil cooler, cutom alloy rad, hoses, intercooler pipes, decent chip (phase 2), short shifter, bigger injectors, bigger fuel press reg............the list goes on but i want it right!!!
    12 second corsa....12.1 @ 120mph
    vauxsport.com
    Total Vauxhall Cover Car Jan 2009
  4. #128
    Jan 2007
    birmingham
    C20let corsa
    alright bux,
    How much have you spent overall on your conversion so far including buying the corsa and all the stuff for the engine?
  5. #129
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Quote Originally Posted by koorsa View Post
    alright bux,
    You need to be able to do work yourself, and to build a good corsa turb id say atleast 4k, not inclucing any work the engine needs or bodywork costs.
    When your going the whole hog like Bux or me, its best not to add everything up tbh. lmao
    www.wix.com/vxlgsi/zxr-750-r
  6. #130
    Jan 2007
    birmingham
    C20let corsa
    Quote Originally Posted by vxlgsi View Post
    well i have been putting k-series 1.8vvcinto metros for a while and thought id try something different going for a 2.0tubz corsa, alot diff to metros but its worth a go!
  7. #131
    bux
    bux is offline
    Jul 2006
    Northants
    a hell of alot of money! if you add up the engine alone there is a far bit there here is my engine spec without labour charges
    flywheel and clutch were alomost £700, engine cost me just over £1100 with buyin the calibra (sold few parts) so it knocked the price down!!
    actually its easier to do it this way, price all this up and work it out, the corsa cost me £400 to buy and i aint no where near fnished yet!! still got alloy rad commin, oil cooler, turbo upgrade, bigger injectors and fuel press reg, hoses etc...........
    Engine stripped bare ready for rebuild
    Block cleaned and painted black
    Bores honed
    New piston rings
    New main bearings & bolts
    New big end bearings & bolts
    New oil pump metal gasket
    Cosmetic 1.9mm metal head gasket
    Head stud conversion kit and arp head nuts with early xe head bolt washers
    Rebuilt coascast head (valves re-lapped, new seals)
    New front and rear crank seals & camshaft seals
    New inlet & exhaust gaskets
    New modified sump gasket (all in one bonded together)
    Sump cleaned and polished & new sump bung
    New cam belt, tensioner and idlers x 2
    Cam cover stripped and powder coated
    Cam belt cover stripped and powder coated
    Spark plug cover stripped and painted
    New main crank bolt and Allen head crank pulley bolts as apposed to torx bolts
    New lightened billet flywheel and bolts
    Throttle cable mount powder coated
    New samco breather hose
    Stainless steel heat shield & bolts
    New exhaust manifold studs and manifold bolts
    New silicone vacuum hose (blue)
    Dipstick covered in silicone hose (blue)
    Aluminium polished oil cap
    Gearbox stripped and cleaned and re-painted in silver
    Modified alternator bracket and belt to compromise driving only crank and alternator pulleys (£50)
    Blue silicone vacuum hose
    New thermostat seals
    New oil filter
    Helix 4 paddle cosmetic racing clutch (£450)
    M-Tec conversion kit (£625)
    Body/chassis
    Battery tray removed and battery re-located behind passenger seat
    100 amp circuit breaker used for trip (short circuit)
    Battery isolator switch in engine bay
    Aluminium battery tray hold the battery
    Front of chassis fully strengthened and seam welded
    New lower arms
    New ball joints
    FK fully adjustable coil over suspension, painted up yellow
    Brakes
    New brake pipes run through the engine bay with new barake pipe securing clips
    Good-ridge braided hoses
    Vauxhall astra 2.0l 16v front brake upgrade
    Callipers cleaned and painted up silver
    Drilled, grooved and vented EBC turbo discs
    Fast road pads
    Interior
    Cobra bucket seats x 2
    Sparco harnesses
    Rear seats removed
    vauxsport.com
  8. #132
    Jan 2007
    birmingham
    C20let corsa
    alot of money spent there then, what bhp you hoping to get out of his corsa? and btw it is going mint by the looks of it well done m8!
  9. #133
    May 2005
    nova turbo phase 3.5
    how much did you pay for your coilovers?
    nova turbo
  10. #134
    bux
    bux is offline
    Jul 2006
    Northants
    ive had a few people pm me about my coilovers, i didnt pay that much as my mate has got too much money and didnt like them as they had gone slightly rusty (surface rust) so i took his c20let engine out of his corsa fr him and gave him some cash too, ive gotta wack it back in for him too but its not hard at all! all i did was wack em on the buffer and cleaned them up, then mxed up some paint and gave them a decent coat....job done!
    oh and Koorsa.......hoping to get around 280 by the summer.....then in the winter it will be having a tubilar manifold, garrat turbo and other goodies fitted! i would do it now but ive spent far too much on it so far................and ive got a holiday to pay for!! so the big power will have to wait till next year!!!
    vauxsport.com
  11. #135
    Sep 2004
    St.Austell, Cornwall
    Astra MK4 1.6 club
    Are you thinking about getting a rad similar to this?
    http://www.regal-shop.co.uk/acatalog...Upgrades1.html
  12. #136
    Oct 2005
    clacton on sea,essex
    corsa c20let
    im doing a corsa turbo at the min just got my engine. ive beenin waiting on my fitting kit got it today so wait on a mate to start it this week end cant wait should be around 2 week till it will be up an running
  13. #137
    bux
    bux is offline
    Jul 2006
    Northants
    Quote Originally Posted by rich.21 View Post
    your not doin the usaual just wack the engine in job are you? could be bad news as alot of the c20lets have had a hard life!! id rebuild it to see more power and reliability!
    vauxsport.com
  14. #138
    bux
    bux is offline
    Jul 2006
    Northants
    Quote Originally Posted by flopstocks View Post
    i did look at that rad, but im in talks with a company for a proper alloy rad, just wating for a price for me and my mate to get em both at the same time! should work out cheaper that way!
    vauxsport.com
  15. #139
    Oct 2005
    corsa c20let
    i am going for corsa td rad!
  16. #140
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Im hopeing to be able to use my corsa gsi rad, but i have a secret cooling weapon.. lol
    its a remote hi flo stat, 87 degree stat (so its the correct temp) but due to its larger size allows water to flow more easily, reducing the bottleneck effect that happens at high rpm at the stat opening gap... Something the lotus elise boys use when they track em, and got the thumbs up. easy to fit, simply remove your stock stat, and cut your rad hose and fit it in place..
  17. #141
    May 2005
    Quote Originally Posted by bux View Post
    how much is your rad costing you? i'm doing a corsa at the mo too
    nova turbo
  18. #142
    bux
    bux is offline
    Jul 2006
    Northants
    Quote Originally Posted by danielparrish View Post
    for a proper decent alloy one its lookin like its going to be just under Ј300 but they will custom make it to fit where they originally fit and will also add any tubing where needed for any hoses......? i think thats quite a good price for a custom rad!! should help to keep it cooler too!!
    vauxsport.com
  19. #143
    bux
    bux is offline
    Jul 2006
    Northants
    abit more progress, with the m-tec kit here i couldnt wait to get started so firstly the tie rod lowering kit was fitted! that consisted of tapping out the mounting bolt threads to m12x175 and fitting the lowering kit to the lower arms also, then i converted the gearbox to 2 wheel drive and fitted up the mount, the gearbox had to be drilled and tapped in 4 places, which i didnt like doin just incase it went wrong!! then a bit of paint on the mounts as they came in a greeny colour and fitted the gearbox upto the block!! made a few adjustments in the engine bay, now all i need to do is await saturday to come and get the engine in!!!! cant wait tho!!!
    vauxsport.com
  20. #144
    bux
    bux is offline
    Jul 2006
    Northants
    Right then updates for you!! a big hurdle was over come today.............AT LONG LAST THE ENGINE IS IN!!!!
    This week has been very busy, converting the gearbox, tapping out the chassis, painting up the mounts etc,etc but finally the time came to get the engine in!! So off i took it to my work, put the m-tec mount kit on.........positioned the engine underneath and put it up in place, few small mods needed to be done, e.g. the amal valve bracket had to be cut off as it was touchin the brake pipes and few other bits and bobs but it went in really nice really!! also got the main loom wired in for the alternator and starter motor so here are a few progress pics!!
    ENJOY! Im very chuffed with the outcome and how it looks hope you like it too!!!
    My mate took it there for me and belive me it was a tight squeeze on his trailor!! and he caped it in mud down his farm track!!! tut tut!!!
    Car up on the ramp, tie rods removed
    Fitting mounts, with new bolts
    Pic of the engine
    Goin in time!!!!!!
    Almost there
    And there we have it!!!!! shes in
    Back home to my workshop
    Few pics of the engine in place
    vauxsport.com
  21. #145
    Suffolk
    335d E90
    Looks very very nice
    DRIZZ
    DEVELOPMENTS
  22. #146
    Aug 2003
    Durham
    looking nice, keep up the good work.
  23. #147
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    well done this project is fookin mint mate i cant believe how thorough youre being
  24. #148
    bux
    bux is offline
    Jul 2006
    Northants
    cheers for the replies so far! my aim is to get the engine absolutely gleaming so it may look like a bit of a shed on the outside (for now) but when i pop the bonnet people will be amazed
    going to do a few more bits today e.g. plumb some pipes in etc but now need to get on the phone and order more stuff!! hybrid turbo is next on the agenda along with the mocal oil cooler........should get them within the next few weeks!!
    vauxsport.com
  25. #149
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    I spy a Muuuuuuultii V...... Good work fella, engine bay looks imaculate....
  26. #150
    ooooo very nice dude,
    looks great!
