u cheeky git u told me to mask the bloody doors up should of done the whole car thoOriginally Posted by bux
coming along nicely, not bad for a first effort at spraying, soom good welding there too, your first time at welding?
hmmm your engine i saw that calibra on ebay right?????
yeah the calibra was on ebay mate!
ive welded a few bits and bobs but nothing major!!
12 second corsa....12.1 @ 120mph
vauxsport.com
Total Vauxhall Cover Car Jan 2009
new update.......removed the engine from the calibra today. whilst i was at it i removed transfer box and gave engine a good de-grease and steam cleaned off the sump and box ready to be cleaned up properly for painting!
here are a few pics
next on the agenda is to paint up gearbox and overhaul parts of the engine....
vauxsport.com
ok then updates for the engine.........basically wanted the inside of the engine to be reliable so i decided to stip it right down and check everything properly!! here goes with the pics then
engine out and ready to be stripped......
missed a few stages, but here it is bolted to engine stand, with the head off.....
pics of the headnot good im affraid ....
me cleaning up the block, bores, block face etc all good.....
now the good bit, making it look nice, and getting ready for the rebuild
thats it ofr now, am spraying the gearbox today, took me 4 hours to clean it up tho with wire brush ends on a drill!!
vauxsport.com
looking good dude,
did you use rattle cans? then 2pac or so over the top?
no i just used engine enamel in a tin, i also using it on the gearbox, but i am spraying it on the gearbox with a airbrush kit, will post pictures later on of that, i think it looks really good, just like new![]()
vauxsport.com
ah right..cool,
looking good, u putting core plugs and that in or have you already done that?
core plugs are still in the block and they look in good condition so im not going to disturb them, i will paint them silver tho
going to give the block a couple more coats today, will post pics of gearbox tonight too
vauxsport.com
show the process of the gearbox painting in pictures will you. Im gonna do mine when picked up !
............ive only got a before and after shot mate! just de-grease it fully, then go over it with a wire brush, then go over it with a wire brush on the end of a drill, its not a 5 min job tho!!
before
after
Note the marks on the box is just water as i went out and my mum couldnt lift it![]()
looks like new now!! also took time to mirror polish the clutch cable clamp......WHY???? lol
vauxsport.com
Good progress.
Have you changed the speedo ring on the gearbox yet?
Back in the scene
nope not going to bother with the original speedo! im going to get an electronic one from america, but will use the road angel for time being!
vauxsport.com
right alot of progress over the last couple of days, paid a visit to steveboyslim and got myself lots of goodies
here are the part i have recon coscast head, cosmetic metal head gasket, stud conversion kit, new rings, new mains, new big end brgs, new big end and main brg bolts, new inlet and exhaust gaskets, new front and rear crank seals, new camshaft seals, new cam cover gasket, new uprated metal oil pump gasket, other various o-rings etc
so far i have fitted the new piston rings, new main bearings and bolts, new big end bearings and bolts, refitted the oil pump and timing belt back plate and fitted my stud conversion kit, off in the garage in a bit to rebuild my head
here are a few pics
head should go back on tomorrow hopefully!
vauxsport.com
what paint did you use on that box mate,
nice finish
good work man coming on like a good un, glad to see you got your head, when will the engine be going in, got a feeling your gonna enjoy fraping this around when you get it sorted.
looking good
the paint i used was off of ebay, a place called classicago sell it, (search engine paint....£8 a tin) its basically engine paint. i didnt brush it on tho, i sprayed it on with an airbrush kit and it gave a really good finish!!
as for when the engine is goin in, maybe a little while still as need to get uprated clutch and new flywhell, few other bits and bobs and the conversion kit!!! also need a front mount etc, i want it on the road for march ideally!!
head going on today
vauxsport.com
Great Progress m8![]()
White Corsa sport - de chavving begins!!
head is now on, inlet will be going on tomorrow! thengotta order some silicone hoses, i have now found the breather pipe but they only seem to do it in blue :S
vauxsport.com
put dizzy on today, and injectors also my new breather hose turned up!!
vauxsport.com
good work fella![]()
I couldn't repair your brakes, so I made your horn louder.
some good work there.
was going to do my own sprayin but bottled it think i will have a go at the inside myself
