Page 3 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 51 to 75 of 441
Thread: My GTE 16V Restoration Thread.
  1. #51
    Aug 2002
    surrey
    GOT E30 YER
    Its cellulose and its as thick as funk you reckon 180 hmm ok i've got 240 i'll run it over in that got filling primer.
    oh.
    then yeah as it will crinkly and crack with you paint over the top,
    so yeah mightbe easyest to 80 it,
    but then 180 then 240,then ech primer it,then a few good think coats of primer,800 it off then paint..
  4. #53
    Aug 2002
    surrey
    GOT E30 YER
    Will heed your advice and get it done thanks
  5. #54
    ok dude,
  6. #55
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Thanks for all the replies and positive remarks. Just to make it clear, only the rear wings have been resprayed, I wouldn't hope (or want, probably) a full re-spray for £400. The rest is, as far as we can tell, original paint, so some credit to the previous owners I guess!
    Um, I've not owned a Starmist, but obviously it flies compared to my mk2 (1.3) and my mk3 (2.0i 8V).
    Been driving it quite a bit today. It's only managed 95 miles to £20,although the plugs are nice and light brown, so I don't think it's over-fuelling. Will monitor the MPG, I would expect to get near 30MPG.
    Also one of the track rod ends broke the other day, so replaced both today and got the tracking reset, much better.
    Next on the list is to re-wire the brake pad senders with the new items I got from Billing as this is the only part of the check control that doens't work. Then I need to dismantle the exhaust and replace the centre section and salvage the back box somehow. They're £110+VAT from Vaux!
    They're there, in their room.
  7. #56
    Aug 2002
    surrey
    GOT E30 YER
    95 miles hmmm redex give it a clean, adjust/fine tune dizzy ? hmm injectors give them a test.
  8. #57
    Quote Originally Posted by the flash
    xe dizzy is fixed...
    and red-x is crap,
  9. #58
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Yesterday I replaced the brake pad warning sensors. I got a pair of new Mk3 Cav ones at Billing for £3 each. They're about 200mm shorter than the GTE ones.
    So I cut the broken ends off the old ones and found two of the right female sockets, on from an old Vectra sensor I had lying about and another was from the oil level sensor connection from a XE engine loom I randomly found.
    Now the pad warning light goes out and I have a 100% working check control.
    Also went to a local exhaust place and found Bosal still make the standard 16V back box, which sells for £56, less than half the Vauxhall price. It comes in tomorrow, but I made sure they know that if I don't like the look of it I won't buy it.
  10. #59
    nrj
    nrj is offline
    Nov 2002
    Hampshire
    Astra Diesel
    the bosal one should come with a silver end, just paint it black.
    CAR FOR SALE: Vauxhall Zafira Vauxhall Astra Mk3
    BREAKING: Yellow Pug 306 Convertible
    WANTED: Downhill Mountain Bike, Set Of Vauxhall Alloys
  11. #60
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    My current GM one has a silver end...
  12. #61
    Joe
    Joe is offline
    Feb 2005
    Liverpool
    Astra GSi Mk3
    Very nice car indeedy!!!
    Plumbing services avalible in the North West. Visit www.tarbock-plumbing.co.uk for more information. Best prices and high standard of work.
  13. #62
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    So Dan you made some little extensions, not cutting the original loom?
  14. #63
    Jun 2000
    Hampshire, UK
    Vectra SRi
    leave it silver dan, it is the right spec for the car
    the vauxhall heritage centre car has a black back box with silver tail pipes
  15. #64
    Jan 2005
    Newport
    Focus LX
    Will you be cleaning up the engine bay dan or leaving it as it is?
  16. #65
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Quote Originally Posted by richie00boy
    Of course! No wires cut on the whole car except for the immobiliser as far as I know.
  17. #66
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Engine is getting some treatment soon. First an oil leak to fix (dizzy I think) which I've just re-sealed. Then a general clean up and a re-spray for the rocker cover and (metal) spark plug cover in as close to original colours as possible.
  18. #67
    Aug 2005
    Hampshire
    GTE Champion, Jaguars
    Very nice Dan
  19. #68
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Hey John! Thank you.
  20. #69
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    I've seen this car in the flesh. You can smell the mintiness walking up the driveway!
    Simps.
  21. #70
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Why thankyou
    Today I got to see what a £56 +vat Bosal replacement back box is like:
    To be frank, utter ****e. My hopes weren't high, but that takes the piss. To not even bother putting the outer trim on straight must mean the quality control is total crap. Looks far more restrictive than the GM box too. Makes me feel much better about paying £110 for a genuine item if I can't get a decent 2nd had one.
  22. #71
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Who in their right mind would buy that, it's shocking! Even if it was assembled straight, it would still look pants due to the peashooters.
  23. #72
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Yep. I took one look at it and told them to send it back. I wouldn't have accepted it off the delivery lorry myself.
  24. #73
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    I've been kicking myself how much I let a genuine used but excellent nick one go for a while ago.
  25. #74
    Jan 2005
    Hampshire
    '10 3 Series MSport 4dr
    ****in hell. thats awful.
    LMF VAUXHALL - 01858 433599
  26. #75
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    RANDOM DRIVE REPORT
    Had a bit if time this afternoon and was going to replace the tank to pump pipe on the GTE, but realised it'd be easier if there was less fuel in the tank. And I've not really driven the GTE properly yet. So out I went to some national limit roads.
    My WORD I've never overtaken that many people in one afternoon. I'm not the most 'sportiest' of drivers, as some will know, and I've not driven many fast-ish standard cars either, mainly engine conversions. But I do like a good blat and I'll overtake almost whenever possible and safe.
    The GTE LOVES it. The pull from the car from almost any revs is nothing I've experienced in any standard car. Not as fast as a LET Mk3 Astra or a Nova obviously, but for something straight out of the box (it still has the cat, too) I'm amazed. Much quicker than the Leon Cupra R I drove (most dissapointing, frankly).
    I actually started laughing to myself as I scudded a line of 3 cars and a van and noticed I changed UP into 5th whilst doing it, such was the ease. No wheel wobble or brake juddder, brakes felt firm and responsive. Her ass got a bit light around some corners and under heavy breaking, but black Bilsteins at the minimum are on the cards. No plans to lower, though. I think I've blown out some of the insulation in the exhaust somewhere, too. Whilst not making a classic blowing/ farting noise, it's got a real mean rasp to it now, which is actually fun.
    Oil pressure seemed perfect to me, 4 straight bars (full) when thrashing, three bars when cruising in 5th and 2, sometimes 1 straight bar on hot idle. Temperature constant on 2 yellow bars. Engine sounds OK, no tapping or knocking, but there's been a funny sort of harsh noise from the bottom pulley area for a while, but I've fitted a new belt and rollers and pump, and had it apart again to check and everything seems OK to me. Belt is a smidgen tight, you can just hear it whining when hot. Well happy.
    Pic:
