Page 11 of 18 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 251 to 275 of 441
Thread: My GTE 16V Restoration Thread.
  1. #251
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: My GTE 16V Restoration Thread.
    I guess, like the heat shield. Most know I'm not the type to fanny about polishing, so I'd expect if I cleaned them up once, they'd just go manky again....
    They're there, in their room.
    MIGClub Member SammyP's Avatar
    Dec 2002
    Wrexham, N.W
    Mk4 Astra SRi Turbo
    Nice, I like it
    I took my heat sheild off an XE I once had, cleaned it and sprayed it with a can as it was looking manky, came out pretty well and never flaked.
  4. #253
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Quote Originally Posted by SammyP View Post
    nah.. It got baked on.
  5. #254
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Sammy P-Thats a very clean/cool looking XE you have there
  6. #255
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    looks nice Dan.
  7. #256
    Jun 2000
    Hampshire, UK
    Vectra SRi
    Looks smart Dan.
  8. #257
    Oct 2005
    SA
    Kadett 200ts
    I'm quite excited as I've solved one of the most annoying 'faults' with the GTE; different bloody keys! It has a different fuel cap so has two keys. Really annoys me. eBay came to the rescue, complete new, INCLUDING the glove box, lock set for £19 delivered! Yes!
    Nice Work!
    Do you have a link for the lock set on Ebay??
    Thanks, I also need to sort that problem out with mine.
  9. #258
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Post Track day report:
    My GTE was thrashed for 3 sessions (about 7-8 laps over 10 minutes) at Castle Comb last Friday for my 'stag do'. It's exactly 100 miles to Combe, I came back with 3/4 of a tank left. I took it our for 2, Tom Williams gave it thrash the 3rd time and drive it very well indeed, much more progressive and altogether tidier than me!
    The whole day the car didn't put a foot wrong, and ticked over to 146k miles with Tom at the helm. I was extremely chuffed with it. I abused the hell out of it, powering out of corners with the inside wheel spinning, revving right to the limiter on far too many gesr changes, all sorts of bad things. I hope this goes to show the car has been looked after most of it's life and clearly proves the engine is in good health. I think in the 2 and a bit years I've had it, it's had at least 8 oil changes.
    Now I've re-connected the oil pressure sender properly, it now reads, I feel, much more accurately. Which made me panic as it wouldn't go any higher than 3 bars on the track, even when revved hard. But then I realised this is exactly what the pressure relief valve is supposed to do. On hot idle (it went up to 3 ars on the temperature guage very soon after coming off the track) it still showed one bar, with the engine quiet as anything, so I think this is perfect.
    This is the rear tyre after the first session:
    I got my dad to drive home as I was very tired. He commeted on how well it drives for it's age (17 years) and considering what it has to put up with. Obviously the standard suspensions and huge tyres hampered it's abilities on the track, but I'm happy with that. As I said earlier, I don't want to be tempted to push it much further and risk crashing it. As it is it's very controllable and you can really feel when you're pushing too far. I find on the whole lowered cars give a little less feedback than I'm used to and I wonder if this is how it was intended to be.
    Also the brakes are clearly not up to the task, they faded very quickly on track, but did remain useful, just about. Obviosuly the desire to keep standard wheels limits the size of the disc, so a bit of investigation into pad compounds is in order. Saying that, 95% it's on the public road and GM pads are absolutely fine for this. I did, however, notice the brake fluid has dropped about a third of the way between min and max on the reservior, not enough to trip the check control though. So although the brakes recovered very quickly and were normal on the drive home, I thought I'd investigate. Good job I did:
    These were brand new GM pads just under 2 years ago. It came with Greenstuff pads which I changed as the brakes have never been as good after it's first track session in 2006 I think. So I've refitted the Greenstuff for now as they have similar amount of meat left and interestngly have a slot cut into them where the GM pads have cracked. So although I get no more resistance to fade using the Greenstuff, at least they stay 'safe' if you intend to go on track.
  10. #259
    Oooo good work. They are nicely funked.
    Has it really been two years that you've had it?
  11. #260
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Good to hear you gave it a proper battering
    LOL @ the brake pads destruction lmao
    How worn were the front tyres?
  12. #261
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Annoyingly the FURIO DEBICAS have plenty of life left in them
  13. #262
    Gonna have to tie it to a post and burn the fronts off aint we..
  14. #263
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    wowsers, will have to check mine.
  15. #264
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Wouldn't hurt Dave.
    Also, my windscreen has cracked! Halfway up, on the driver's side. In other words, right in front of my face.
    Will have to save up as I might as well have the roof (and bonnet) sprayed at the same time whilst the screen is out.
  16. #265
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    Bugger, When did that happen, At Combe?
  17. #266
    Aug 2003
    plymouth
    wife around the
    Wouldn't hurt Dave.
    £55 fitted for a new screen
    ''THE REAL ROB''
  18. #267
    Quote Originally Posted by sbd16vastra View Post
    He knows, got him a price just after he got the car..lol
  19. #268
    Aug 2003
    plymouth
    wife around the
    my price is more accurate then as mine was from having my screen fitted 2 weeks ago
    ''THE REAL ROB''
  20. #269
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    All sounds cooshti Dan. A great example of the car in safe hands.
    Glad you had a good day & the car performed as you'd expect.
  21. #270
    Oct 2003
    Romsey
    XE Cav, Monaro
    time for some M1144s for all round use I reckon ole buddy. green stuff are absolutely superb tied together in a large stack if u need to wedge a shed door open or something, but I wouldnt use them anywhere near a caliper...
  22. #271
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    Looks good.
    Those pads are comedy!
    ///SOUTH CENTRAL MINCERS
  23. #272
    Quote Originally Posted by pitstoppete View Post
    Same thing i said.. am getting him a price.
  24. #273
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    Oh, wish I knew you could get them cheap when I was after them for the corsa!!
  25. #274
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Yeah.
    The screen didn't happen at Combe, or on the way back. But may have happened 'because' of Combe.
  26. #275
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    This crack was present when I bought the car:
    As was this bit of grot:
    And this poo looking bit on the roof:
    Along with the new 'Combe Crack':
    ...it was tme for some bodyshop loving. As usual, it went to Station Bodyshop of Fareham, to have the roof and pillars painted and a new screen fitted.
    Mmmmmm:
    Ahhhhhhh:
    And this area had a slight dusting of surface rust:
    Whilst I was in the mood, I thought I'd investigate something brought to my attention by DarrenH (0ddball) on Mk2.com. Whilst doing the breather mod after beign concerned about the amount of oil in his inlet, he found the small breather to the throttle bottle was jammed up with sludge. So packed in he needed to drill it out, but found the larger bore size meant the idle was too high after. I wondered if a blocked pipe could have a reverse, or at least detrimental, effect.
    Removing the fitting (19mm ratchet spanner is ideal):
    I found if you removed the alternator belt and pushed the alternator back, you can feed the piped to the fitting out and above the engine to work on them easier.
    Krunk!
    I used a lot of carb cleaner and some 0.8mm welding wire to clear it out. Took a while and a lot of soaking and probing.
    So this is how the car stands, and how it will be at Billing, after a bit of treatment from Benn, Master of Wax.
