Page 10 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 226 to 250 of 441
Thread: My GTE 16V Restoration Thread.
  1. #226
    Quote Originally Posted by batesy View Post
    how would i go about that then ??
    have a look at sbd robs thread as hes done it to his,
    but basicly you cut outthe old top mount,and have to weld in a new turret mount,
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    eww, all this modifing crap in a thread about Standard cars. how rude!
  4. #228
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Tonight I started on what some might call the initiation of 20XE ownership: changing the sump gasket.
    Although I doubt it's never been touched, it isn't really that bad:
    Bit grotty, but not pouring out yet.
    Manifold off, this was pretty easy really:
    Whilst under the car, it'd be rude not to have a look about, post-Combe, too:
    Looks ok there.
    Good here, too. I really started to fell sorry for the car towards the end of the session at Combe, I think I got 7 laps in. She lapped it up however, spinning a little into 3rd gear occasionally, so I say it must be putting out good power still.
    Sump off, the oil was still golden as I'd changed literally the day before Combe:
    Nothing scary here:
    Pick up pipe lovely and clear of debris (till I rubbed against it):
    Cool too-far-away-using-macro shot:
    Underside of piston shot:
    Plenty of sealant had been used previously, to no avail. All of the gasket seemed wet to me.
    So tomorrow I'll get a new pick up pipe sealing ring and some RTV sealant. I'm using the Ecotec combined baffle/ gasket with shortened bolts sold by LMf as a kit for £27 at PV.
    Check back for progress!
    They're there, in their room.
  5. #229
    Jun 2000
    Hampshire, UK
    Vectra SRi
    looking good dan, remember to leave it to seal up before filling with oil like i did my LET!!
  6. #230
    Oct 2003
    Romsey
    XE Cav, Monaro
    what sealant is gonna need time to go off Tom, hes putting on an eco baffle
  7. #231
    Jun 2000
    Hampshire, UK
    Vectra SRi
    oh ok then pete, i guess these need to sealant, not even a thin bead to help things along
  8. #232
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    good work as always Dan, ace pics too.
  9. #233
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Well my experience tells me to follow Vauxhall's advice, and apply a small amount of sealant to the gaps on the oil pump and main cap at each end.
    I tried covering the whole gasket in a small amount of sealant on the Mk3 (8V, rubber gasket) and it leaked like a bugger. Second time I used the above method it's tasty as over a year on...
  10. #234
    Very cool,
  11. #235
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Nicely. I did all that on my last XE & it turned out to be the crank shaft end seal leaking.
    Good, fun exercise though.
  12. #236
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Sump gaskets are fooking annoying, usually they still leak even after being replaced,lol.
  13. #237
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Pick up pipe sealing ring not in stock at Vaux, local factors don't sell it. Should be in in the next couple of days. £1.14 I think it was.
  14. #238
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    So here's the new baffle/ gasket:
    The all-important £1.40, non-stock sealing ring. I can't help picturing a 7.5 tonne lorrry pulling up to the Vauxhall dealership with the driver leaning out the window and handing the stores guy a bit of paper with the ring taped to it:
    This stuff is the nuts. I replaced the sump on Byron's lady's Fiat Punto; this is what they use instead of a gasket. This stuff is like glue, it sets so good I actually had to hammer a hole in the old sump to get the bugger off. Just a dab over the gaps between the oil pump and block, and the main cap on the gearbox end.
    Comparing old and new baffles. Sometimes something needs bending to clear the crank, I quickly held it to the block and Benn spun the engine round, no problems there:
    Sump all clean:
    Ahhhhh. All clean. But spot the next bloody job I need to do. I deliberately put a new boot on there to avoid this. Good job thsese photos were taken, I didn't see it when I was under there.
  15. #239
    nice,
    and i'm good and finding a hole....mmwwhahaha
  16. #240
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Booty call! (cv)
    Nice work Dan.
  17. #241
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    You silly, silly TWAT.
    Yup, smashed into the back of another car at a junction. I was in a ****ty mood this morning and probably not concentrating. The only good thing, if it can be called a good thing, is that the car I samahed into was.... my other Mk2! lmao I usually follow Sharon through town then we go out seperate ways to work. She pulled into a road and stopped becuase a dustbin lorry had stopped on the corner. I was still checking the road to the right was clear, pulled out, looked left, stamped on brakes, ABS cut in so I barely lost any speed when I hit the Mk2. The indicator has taken the full force of the shunt and I knew the headlight washer was gone before the two cars even touched. I got into a bit of a rage, I can tell you.
    So, back home this evening I waste precious hours putting the poxy 205 back together to move it out of the garage to get the poorly GTE in.
    Assessment of damage:
    It looks in very good order behind the front bumper. One of the Mk2 Astra's definite strong points is the ease of the design to work on. The front bumper especially should be an example to many a car desginer. Two 13mm bolts and 3 screws is all you need.
    Borken bits.
    The headlights are brand new, lucky it looks like it's just been pushed back a little, with a little crack in the case which I filled with hot melt glue:
    Even the flimsy white clips survived, only one had a side missing. I had one in stock, I think I'll order some more for good measure:
    Time to raid the stores. I got a handful of washer jets from a guy a while back. Wouldn't you know it, one spare good o/s, no complete n/s ones. Luckily you can take them to bits and remove the actual nozzles!
    Found a good indicator. Remember pukka GM ones are grey, not poverty spec white. I have a brand new one for that side, but not a o/s one as yet.
    Testing the lights:
    All done! You'd never know it. The headlight protector has some scratches, but is more than usuable. I have some brand new ones I can use for shows if I feel like it...
    Stupid man. I hope I don't do that again!
  18. #242
    Ah bugger, but lucky you have all the bits needed in stock.
    Glad either car is badly damaged, and i'd have had the ultra rage!
  19. #243
    Jan 2005
    Newport
    Focus LX
    Shows even the best drivers can lose it for a second slip up.
  20. #244
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    lmao @ best drivers. I'll take that as compliment....
  21. #245
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Just hope sharon doesn't put a claim inlmao
  22. #246
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    lol
  23. #247
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Could've been worse. Glad she survived mate & all repaired pronto.
  24. #248
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Cheers Craig.
  25. #249
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: My GTE 16V Restoration Thread.
    Small update. The rocker cover has been looking quite sad for a while now. pitstoppete donated a ready-shot balsted one and JaguarJohn had it powder coated for me (mucho thanks!).
    Minging!
    Off (again):
    Cams look in good order, cam belt looks ok. Lovely.
    Old and new. New one has been pressure washed, degreased then pressure washed again to hopefully clean any debris out.
    Baffle plate re-fitted with way too much sealent:
    But not as much as Vauxhall use!
    Gasket transferred (again!):
    All done:
    Looks much better again. This should, of course, last pretty much forever. Cam belt cover next would be nice.
    Need to redo the plug cover next.
  26. #250
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Blingin', though the dizzy looks a bit gyppo in comparison.
