My Nova Turbo Build - http://www.migweb.co.uk/forums/vauxh...rbo-build.html
lol
Well, incase your all wondering what the hell i've been up to. Here's the latest mod.
I send the old turbo off to Universal turbos for a recon. I went for a stage 1 hybrid, which runs a larger bearing, compressor wheel and better flowed internals.
Also opted for a new actuator to cope with the added increase in PSI.
It came back looking absolutely fantastic
Keith
oooo looks nice...
and cool there just down the road from me...
You should buy a turbo and take it down to them
Keith
UT not far from me, and probably drive past them at least 3 times a week
Miny tastic chap keep up the good work....![]()
It actually is the same turbo, as its got a few marks in it i've matched up with old pictures!
I want it finished for 2008, and i think thats achieveable. I'll have the shell strengthened, dipped/coated and painted by Ade culley, back in my garage for september. The engine will be finished ready to be dropped in. And i should have all the powder coating/cleaning of bits done.
Then i just need new suspension, some form of interior/retrim, intercooler/rad, and all the cooling/boost pipes etc.
Keith
looking well keith. could you do me a favour and measure the outside diameter of the turbo outlet. im not sure if its 48 or 52 and i need to order a silicone hose for the calibra
Are you having the inlet elbow of the turbo modded Keith?
You know the old clearance for slam panel issue?
I think he was planning too Craig yeah as his neighbour can ally weld.
Simps.
turbo looks gud m8, can i ask how much was the turbo rebuild as thinking of sending mine away before engine goes in car!!!
Snap.........me and keith did i kinda deal with universal turbo's so got a better deal!! Got mine back today looks superb!! i also got the stage 1 hybrid..........i had to have a new exhaust wheel on mine tho as it was damaged so it cost a little bit more but still over the moon with it and looks just like a new turbo!! just gotta wait for my coolant pipes to turn up then its goin on!!
12 second corsa....12.1 @ 120mph
vauxsport.com
Total Vauxhall Cover Car Jan 2009
Tiny update -
Got some passat syncro bearings to make some GrpA front hubs, that shouldnt break under pressure
Some poly bush's for my steering rack
Some new braided brake lines (forgot to take them off my old shell lol)
And finally, but the best, is the new equal length driveshaft setup - Thanks to Mark Beeson for sorthing this out!
Connecting shaft from box to bracket
New custom outer shaft - Just needs some new C.V joints.
Keith
nice,
get on with it dude...lol
Are those rack mountings from Just Novas?
Nice one to Beastie for the equal length shaft setup.
I got them off ebay Craig for around £6!
Keith
alloy bottom pully and lightened fly now ordered from VXLGSI - Cheers mate!!
