Shock horror!! the nova is alive!!
Page 5 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 101 to 125 of 343
Thread: Shock horror!! the nova is alive!!
  1. #101
    Glasgow
    saab turbo
    but is it driving yet? as in you behind the wheel and it going under it's own steam?
    curiosity killed the cat...................but for a while i was a suspect!!
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Are you going to be driving it over to Benn's on saturday tho for the mini Nova LET meet?
    Simps.
  4. #103
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    no mapping just troubleshooting then ?
    so now youv'e fitted a known working sensor its not picking up a rpm ?
    i the rpm trigger disc on the crank ? ( i know its meant to be but is yours on?)
  5. #104
    Jan 2002
    southampton
    sm2'd, T3'd let nova
    no its not running! i havnt got around to getting another hall sensor yet! we definatly had an rpm signal at marks by wiring a crank sensor into the hall sensor plug and tapping it on the cam shaft! so it does realy point to a duff hall sensor! will have to get a new one or try a know working one!
    simps ill be coming down in the scort!
    [quote]The Simps;
    If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
  6. #105
    get it sorted damn it!
  7. #106
    London, United Kingdom
    78 Kadett C
    Quote Originally Posted by dan-j
    crap pics! always comes out to dark
    point the cam at the floor near the car (so its same distance from the lens as the car, otherwise it'll be blurry, wheels are a good point), then half-press the shutter (pre-focus it), then move it back to the car is central in the frame, then press it all the way !!!
    its cos it's a white car, it fools the camera's metering system as it thinks its damn bright, so blacks come out far too black !!!
    i work in a camera shop :P
    now off to read the rest of the thread lmao
    78 Kadett C 2.0 8v turbo
  8. #107
    Quote Originally Posted by djivesp
    or bring it next sunday to my meet and we'll take great pics of it...
  9. #108
    Jan 2002
    southampton
    taa for that tip i will try that! i do notice the camera dip i colour as it focus's!
    car still brown bread! got a signal from tapping the crank sensor on a bolt! but then nowt with the dizzy hall sensor!!
    [quote]The Simps;
  10. #109
    Jan 2002
    southampton
    small update! havnt realy done any thing due to buying a house
    started to mince around with it now though, sent my ecu off to Mark to get a chip change so i can run the std crank sensor and 60-2 trigger, hope it will sort my problem out!
    also picked up some new rear lights from the fag of which is Benn last week end!, and Simps the first pic is for you mate! happy now?lmao lmao
    car will soon be living in a nice double garage
    [quote]The Simps;
  11. #110
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Car is quality
    You much have patients on a saint,will be nice when its eventually running
  12. #111
    Jan 2002
    southampton
    thanks mate! i have patience upto a point! if this chip change does not lead to the ecu detecting the trigger disk, i realy do not know what to do next! its a long way for me to go to get help with autronic fecking car! it will work one day
    [quote]The Simps;
  13. #112
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Its a long way for youlmao Its an even longer way for me I'm going with sm4 perosnally,i hope its fires so i can atleast check for leaks n stuff before karting it off to Mark.
    Do you know if the sm2 runs the same ecu plug/wiring as the smc? If it does and your wont fire on the new chip i have an smc ecu which will definalty take the std crank trigger and hall sensor that i could sell you extremely cheap Downside is that is doesnt have the traction/launch features of the sm2
    Fingers crossed it'll fire
  14. #113
    Jan 2002
    southampton
    lmao its also the hassle of hiring a trailer etc to get it down there!
    thanks for the offer mate, but the reason i went after market is for the traction control as i was hoping to lay down some 12's on the 1/4. unsure if the plugs tie up? if i realy have no joy im screwed may have to buy sm4lmao
    [quote]The Simps;
  15. #114
    looks funking ace,
    lights look great on there,
    get it on the funking road!
  16. #115
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Awesome Dan! Really looks the part now that you've removed said offending item and got the bumper/grille lined up properly
    Good luck with the ecu swap!
    Simps.
  17. #116
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    evo boys will buy your autronic then get dta s60 £600 ish . very well spec'd.
  18. #117
    Jan 2002
    southampton
    would have though every one would just buy sm4 now lee? if you can afford an evo you can afford sm4 its pritty cheap!
    Simps want me to send you the SRI badge so you can put it on your grill?
    [quote]The Simps;
  19. #118
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Looks awesome, rear lights look cool
  20. #119
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    Quote Originally Posted by dan-j View Post
    You can send it to me so I can put it into the bin as to make sure you don't get tempted to put it back on again! lmao
    Simps.
  21. #120
    Mar 2006
    Highlands
    Astra's & Nova
    holly smoke you got some air there bud....!!!!! NICE
    Vauxhall Power....
  22. #121
    got the cables yet?
    its it running ya slag.
  23. #122
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    looks fantastic! White looks soooo clean!
  24. #123
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Looks bloody awesome!
  25. #124
    Jan 2002
    southampton
    thanks! the toyota super white, is very very white when you see it in the flesh!
    [quote]The Simps;
  26. #125
    Jan 2002
    Oswestry, United Kingdom
    Cbr 600 RR
    very nice mate cant wait to see this running
