quick rack and quaiffe here. try been side by side with a mate in a 20k evo and letting it rip in 2nd or 3rd. scary
6 SPEED, LSD, MINT GREEN BALLISTIC BOGEY. TOTB 09 FWD SHOOTOUT WINNER
10.9 @ 132 ON TREADS MAPPING AND SETUP BY RICKY @ www.race-tech.net
Ah....the joys of toruqe steer with EPAS. That'll be one hand then!![]()
Rob how hard is it to fit E pas? cant believe how old skool non pas feels! 3 point turns are now 30point turns!
[quote]The Simps;
If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
It's quite easy, just a case of lowering the column by the stalks, lenghtening the shaft and making a custom mount for the centre bracket by the motor. I've fitted the corsa servo/pedal so I bolted it through that in the battery try.![]()
Also for the observant, thats ABS where the standard nova servo is![]()
looks good buddy clea novas with turbos..rule
corssaaaa powwwaaaa
abs..cool but why?
When doing 140MPH + on private A roads it's nice to be able to slam on through bends etc without having to worry if its going to lock up or go side ways. Personal preference I suppose.
Also, I just wanted to prove I could retro fit it!
There's a switch on the dash to switch it off though![]()
ah very cool,
looks good on the spec list too...lol
small update for any one that is intrested;
car has been at marks for a while as he is fitting a dwell board in the ecu so i can run a single ignition amp on the vaux coil pack, car was running but now isnt, poss a dry solder joint on the new dwell board as there is no signal between the ecu and amp![]()
[quote]The Simps;
Cool cool
keep at it
Break it!
Back in the scene
could be the way forward! as i said last night already started buying escort parts, doh!
[quote]The Simps;
Get SM4!
Back in the scene
Is it still alive!
Back in the scene
Not sure!!, would not mind it back for this summer to drive about in! was a right laff running it in last year, untill 4k........ lol
[quote]The Simps;
