Be careful when fitting it though! The bolts that hold the thermostat housing on can sieze and the heads will shear off if you're not careful. So get WD40ing the bolts for a few days in advance.
Cheers guys, I will start WD 40ing now for the next couple of days, just to be safe.
When I put a new thermostat on 30000 miles ago, I knew then that if I had to change it again in the future those bolts could be a problem, which is why (if i remember correctly) I didn't over tighten them.
Thanks again
