This may sound desperate but it's because I am, a lot
The engine in my Veccie is 3ltr bottom end, 2.6 gas flowed heads, kent 270 cams, 4bar fuel regulator, omega plenium setup, Magnecor leads, induction kit, back box, l\flywheel.
I've just had the car on the rollers and I'm only getting 210bhp @ 6200rpm and 196 @ 3200rpm.
The fuelling is 7% then 12% full throttle.
I'm gutted as I have had a problem with both 02 sensors for about 9 months and I cannot fix it. I replaced them the other day and I still get the codes. I thought it maybe to do with the ecu so I replaced my superchipped one with a police spec 2.5 ecu which has a 3ltr map in (the police are a bit cheeky) and I still get the codes.
One of the faults when the ems light comes on is the temp gauge goes right up, then drops and light comes on Wtf!! Because of the hot weather I have even taken out the thermostat. This happens everyday!
Is there anything I have overlooked? I know of similiar spec'd cars running at 260-270bhp there must be something.
If anyone can offer advice as in what to check I would really appreciate it, am totally lost and feeling a bit pi&^*&^ at the whole thing.
Thanks, Russ
Forgot to say I have taken the cat off as well, cheers...
Thanks, Russ
