battery light on very dim..... whats gone wrong?
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: battery light on very dim..... whats gone wrong?
    Aug 2001
    out there!!!
    modified zafira
    Question battery light on very dim..... whats gone wrong?
    tonight i was in my car for about an hour or so playing the x-box so i turned off the screen and went out on a job. 2hrs later, car wont start so i gave it a jump start. on the way home i noticed the battery light was on but everso dim does this mean the battery is fooked? the altenator is fooked, or both?
    gave it a rev, still stayed very dim. i realy dont need this right now, in fact i dont need this at anytime let alone now
    i have also noticed that when i play my music sort of 3/4 volume the lights are diming didnt notice that b4
    do i seek the help of an auto electrician first?
    cars.... dont u just love em!
    gav.
    May 2002
    Mansfield
    Calibra Turbo
    Sounds like alternator but try a different batt if you can first.
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Wouldn't failing alternator make the battery light come on bright rather than dim?
    Any garage should be able to check the condition of your battery and alternator..
    My battery light glows with just the headlights on, local garage checked battery and alternator output and they both seem fine.
    Probably going for a new battery some time soon(ish). Going to get the biggest one that'll fit in the battery tray.
  5. Remove Advertisements
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    i have also noticed that there is loads of battery acid at the bottom of the battery holder looks like i'll have to give that some attention soon
    for some reason when the car is left for a few days (i use the corsa every now and again) it seems a little reluctant to start. d'ya recon its the battery then?
    also if the battery is low on power will the battery light come on or am i facing another problem?
    gav.
  7. #5
    May 2002
    Mansfield
    Calibra Turbo
    When the battery light comes on when driving it means that the alternator cant supply the current needed so uses power from the battery. Dimly lit means a little is borrowed from the batt brightly means alot.
    Also a failed alternator can give very strange readings regarding the battery light.
  8. #6
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    Unhappy now that......
    dont sound good
    i recon its gona be a trip to my local chaps to have a look at 2mora
  9. #7
    May 2002
    Mansfield
    Calibra Turbo
    An un-fused short circuit could also cause your prob but the smell of burning would be a give away.
  10. #8
    Banned
    Oct 2002
    92 Cav-XE'd Astra 3
    Well either way with the altenator messing up, the light will come on.
    Those 2 cases would be
    1) Not charging
    2) Over charging (regulator rectifier)
    Get a battery check.
  11. #9
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Strange... there is absolutely nothing wrong with my alternator and yet I still get the glow from the battery light..
    **Touches wood just in case of speaking too soon about the alternator being ok**
  12. #10
    Jan 2002
    Retford, Notts
    Calibra turbo 4x4
    sounds like it could be the problem that i had the other day
    try connecting a jump lead from the battery - (negative) terminal to the engine somewhere to make a stronger negative connection
    if the lioght goes out start replacing or cleaning the earths up.
    mine was the one that comes off the gearbox.
    hope this helps a little
    fatz
    www.clubvauxhall.net a place where you can abuse everyone and theyll still want to make love to your leg :D
  13. #11
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    it already has one from the engine direct to the battery.
    just went out to the car (will it wont it) it started fine. still gona get it checked out though.
    gav.
  14. #12
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    Unhappy oh dear.....
    yup its the altenator its going in 2mora to be uprated to 120amp cost as yet unknown but its gona need to be sorted out one way or the other.
    only giving 40odd amps under load and charging at 12.9v somit is not doing its thing
    wont see much change if any from 300
  15. #13
    Nov 2000
    St. Asaph, N. Wales
    Nova, Audi, Landrover
    do the work ur self then... and avoid silly labour charges
    LEE69
  16. #14
    May 2001
    52.26320 -0.81374
    2.0 16v Astra GTE
    Re: oh dear.....
    WTF? the alternator and bracket should cost about 120 trade club and it is only an hours work maximum.
    Veni,Vidi,Scubi
  17. #15
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Re: Re: oh dear.....
    Trade club doesn't list alternators for the Omega/Elite ->99.
    But it does have some under Omega/Elite but doesn't specify a year. 120amp alternators on that list are 170+vat trade club.
    Main dealer hourly rate.. something like 70??
    240+vat.... 282....
  18. #16
    May 2001
    52.26320 -0.81374
    2.0 16v Astra GTE
    Re: Re: Re: oh dear.....
    240+vat.... 282....
    This years does and it is 2.2 DTi, Part No R1530020 Alternator 120 Amp and is 84.40 + VAT
    As those who know, know, the R on the part number means it is an exchange unit.
    Or I could be talking ********....
    Veni,Vidi,Scubi
  19. #17
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    by the way it was probably the jump start that killed it, jump satrting cars can be bad for the alternator, believe its something to do with the zenner diode, best to bump it if you can, or even better take the battery off and charge it, i know its not always possible but alternators are pricy!
  20. #18
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Re: Re: Re: Re: oh dear.....
    But the 2.5/3.0 ones (part number R1030078) are 170+vat. Gav doesn't have a 2.2DTi.
    Info from the Trade Club online (so it should be up to date)
  21. #19
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    ever tried to bump a 2 ton automatic i recon i'll need an ambulance. lmao
  22. #20
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    i know iknow, just saying, thats all, if you get an ambulance you would at least get a lift home
  23. #21
    Banned
    Oct 2002
    92 Cav-XE'd Astra 3
    Re: Re: Re: Re: Re: oh dear.....
    Sounds rather cheap.
    My altenator cost 94 for a rebuild, And 120 for a new one
  24. #22
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    Angry someones avin a laugh.....
    took the car for a run today, b/heath to swanley, then to welling to get it tested. air con was on and so was the music. when it was tested had the result above went to start the car no probs thought i'd have a look and see if i can see this bloomin light.....nothing car farad cap was saying 14v sod it i think i'll keep the money, but keep it in mind that it could go soon.
    gav.
  25. #23
    Aug 2002
    north london
    Built COUPE TURBO
    dim
    i had the same prob a little while ago in the nova. the bat was ok and the alternator was ok it was the earth straps between the batt negative and the alternator.sadly i only found this out after changing the alternator twice and thats a right bas$$rd in a valver nova.
    CHECK THE EARTH STRAPS
    t34`d Astra Coupe, brakes by Porsche and Interior by Recaro
  26. #24
    Aug 2001
    out there!!!
    modified zafira
    Thread Starter
    Thumbs down loaded the electrical system up.....
    had the heaters on with the front seats, air con on, lights and hi fi, the battery light was now on brightly
    feck it!!!
  27. #25
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    Re: oh dear.....
    wont see much change if any from 300 [/B][/QUOTE]
    Oh dear,move to Yarmouth,re-con from rotating electrics here is around 30 with years warranty.
    Need custom t-shirts?...www.deathgimp.co.uk
