I read the fault codes on my kit car today now i've got it on the road and it flashed code 13 - oxygen sensor open circuit/low voltage
I presume it's currently over fueling, would it be in limp mode? I didn't think it would have a lambda sensor being an early dizzy XE, it has an FP ecu if that makes a difference. I have read you can ground pin 20 to ignore that sensor?
