Em where can we find these engine?
x25xe
y25xe
y26xe
i am not quite sure about these engines....
but the if i turn this the other way.....
2.5 V6
2.6 V6....where cau i find these engines?in which cars...
And is 2.6 engine much difrent from 2.5?by it's size?can 2.6 be fitted with F28.....???
One putted 2.5 V6 from vectra B into kadett....i think it was x25xe engine type.....i wanna put in y26xe(i think that it's type code)
help please...beacouse i have chance to ger those engines,but i don't wana screw up.....and can anybody tell what must i modify to fit F28 into kadett?and 2.6 V6 engine....
Beacouse Paul Baldwin had it done x25xe engine fitted into kadett.....and he had to modify one engine mount!so i gues y26xe is basicaly the same engine and so are the mounts?right?
Now does anybody have any idea or picture which mount on fearbox/f28 needs to be modified?
em does anyone have any pictures from x25xe engine???exauts mainfold!!or can anyone tell me how is it done?and what's diameter of the pipe.......are there two pipes or one under the car?and what's the optimum.....going like this:
V
V V6
V
III III 2x3
I I
I I
0 0
I I
Using standard exhaust, will have one made if money becomes available.
Cut cat off V6 downpipes, welded exhaust clamp off ford escort onto remaining pipe, flared end of existing astra exhaust to match and simply bolted together. Easy really.
i dont think Y26XE exists, but if it did, the difference would be the compression ratio
72.7K members
