soi friends of Venezuela, and I have a turbo engine corsa b C20XE with the following Specifications:
- C20XE turbo
- Compression 9.5
- Programmable microtech
- Wiseco forged connecting rods scat.
- Pump of 430 PLH
- Methanol system.
- Aem truboos
- Turbo precicion 6262
- Tial wasgate and blow off
- 1000cc injectors brand conic
- All ARP bolts
- Cometic gaskets
- Clucht act stage 3.
- Original factory cam is the only thing that holds the original vehicle.
- Among other changes ...
actually is a new project already completed in a few days now and caught him without ignition problems so far no one single issue which can not find the solution and would like more assistance acertiva sincere on your part and the problem is as follows :
the motor is no more than 7 000 rpm. only goes to 6600 both in vacuum and walking in the street. I have searched many solutions. is no spark or fuel pump, and I tried 3 different programmable including AEM, fuel tech, and now microtech and continuing the same problem and thus can not be programmed ... the motor time I just checked it today and is perfect in all points or guides both cam and the oil pump ...
whom should it last beyond this problem or know the solution is the demasidado would appreciate. please .... this problem has me mad a big hug from our country .. excuse the language I use a translator. I speak Spanish
Deshacer cambios
