Early c20xe alternator wiring help
Results 1 to 8 of 8
Thread: Early c20xe alternator wiring help
    May 2006
    omagh, N. ireland
    Hi I'm making a new charging circuit for the alternator and starter. I have the starter sorted can anyone help me with wiring the alternator ? Thanks
    UK
    Cav turbo and XJR
    Re: Early c20xe alternator wiring help
    well there's the thick red wire to the thick red cable on the starter.
    and the thin blue/white to the dash light
    May 2006
    omagh, N. ireland
    is there a third wire? do i need the battery light fitted for the circuit to work? i have already fitted the big red cable to the starter and it wont charge
    MIGWeb Moderator Paul's Avatar
    Midlands
    Most days
    As far as i know you need a battery light
    Castle Combe Action Day - Please click HERE for more information.
    Performance Vauxhall Show - Please click HERE for more information.
    May 2006
    omagh, N. ireland
    How would I go about wiring up a battery light? It's in. Track car with no dash
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    The bigger terminal just needs to be connected to the positive terminal of the battery. As the thick one from the starter is on the same route and is dead chunky, you can simply join these two.
    The other, smaller terminal is used for the battery light. This goes to the bulb on the dash, the other side of the bulb is connected to a 12V ignition switched supply.
    You NEED the bulb for the alternator to work.
    The alternator itself needs to be grounded to the engine block, or straight to the negative terminal of the battery.
    They're there, in their room.
    May 2006
    omagh, N. ireland
    Cheers for the replys. What fuse would I need for the charging light?
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    You don't, the bulb acts as a fuse.
