just wondering if the disc setup from the sri corsa c will bolt on to the corsa b rear axle? any body know? or which is the easiest way to convert them to rear disc but keeping the four stud setup?
cheers callum
cheers callum
Yeah i believe you can use Corsa C stuff, if not you'll need the plates to weld on the beam (David dixon on here sells them) and then hubs from a Astra/Cav
Performance Vauxhall Show - HERE Please click for more information.
VBOA at Billing - HERE Please click for more information.
That would be good if I can it will save some hassle with welding the plates on but need to be 100% before I go buyin partscheers
would also like to know this mate so if you have any luck let me know ?
no smoke no poke ! if in doubt screw it out ;)
It's been done and is one of my future mod, problem I have found so far is people want ££££ for the C rear
Axle! You need to weld handbrake cable guides on the beam!! I looked
At C combo rear discs but they are different to an SRi...
