Fitting an internal car aerial
Results 1 to 24 of 24
Thread: Fitting an internal car aerial
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    I did this modification in my 1.3. You run a flexable arial up the side of the car in the diagonal strut between the door glass and the windscreen and you use the screw for the sunvisor to hold it in place.
    The signal you get is really good and you don't have to worry about an aerial outside the car getting bent or broken or whatever.
    However I had to do it by using an FM aerial I think from the Sony Centre and welding a socket onto it with only partial sucess.
    Can you buy flexable aerials from somewhere?
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
    Oct 2000
    Bracknell
    Mondeo, MR2, Manta
    Halfords, i fitted one to the manta, and it's a big bag'o'shite.
    Originally Posted by Brian_S: Woooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo!
    Dec 2000
    Gloucester
    3MW B18iS
    what about the aerial though?
    No, now f*** ***.
  5. Remove Advertisements
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    lmao
  7. #5
    UK
    Cav turbo and XJR
    Apparently (so I have heard) you can get some new fangled ariels called "Electric ariels".
    They extend up when you want to use them and down when you don't.
    Some are so brillant that they work automatically when you turn the radio on and off.
  8. #6
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    lmao lmao
    Andy are they not to advanced for an old mk2?
  9. #7
    Jan 2002
    Suffolk
    Vectra B SRi 150
    But what if you've just filled in the hole for the aerial (not that I have......... yet )
    I was thinking of fitting one of them inside aerials that can be fitted to the windscreen above the r/view mirror.... apparently not quite as good as the full-on leccy external aerial but supposed to get pretty good results.
  10. #8
    Dec 2000
    Gloucester
    3MW B18iS
    All external aerials look mank. Even Bee stings.
    No, now f*** ***.
  11. #9
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Thread Starter
    The later Mk2 GTE's had them as standard but they break and wear out and I'm not paying 60 for a new one (and thats not even from Vauxhall)
    Exactly.
    I'll check out Halfords tomorrow
  12. #10
    Jan 2002
    Suffolk
    Vectra B SRi 150
    I like bee-stings on some cars but I loathe wing-mounted aerials... soon as I can afford the sparying, mine's coming off and an internal one fitted (professionally...lol)
  13. #11
    Dec 2000
    Gloucester
    3MW B18iS
    Nah you want a CB enthusiast rubber duck 10m rig attached to the centre of the roof and a large curly wire going in through a window. And a "caravanners like to pull" sticker on the rear windscreen.
    No, now f*** ***.
  14. #12
    Newport, S.Wales
    STRAAA GTE 16V
    I had one of these on my nova and it was
    a big bag'o'shite.
    However this may vary between brands?
    Dan
    Keepin it welded!
    THE STRAAA
  15. #13
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Dan
    Seen one recently that runs off a 12V supply... could be better... got a while yet, anyway
  16. #14
    Awaiting Email Confirmation
    Sep 2002
    Kent
    Astra Sport
    Fitted the TV aerial from my house to the roof of my car, to enable tv watching in the car. Looks so cool.
    Wow, its worls fine, but everytime i turn left or right the signal vanishes. Any clues whats going on ?
  17. #15
    Jan 2002
    Suffolk
    Vectra B SRi 150
    Dunno about the cause, but the cure is.....
    Stop using yer indicators
  18. #16
    Sep 2002
    Kent
    Astra Sport
    lmao lmao
  19. #17
    Oct 2002
    Chester
    Toledo, polo & 20XE
    y dont these inside aerials work????
    surley an aerial is a piece of wire?
    wen i take my bee sting off the radio reception is the same,
    so the wire conectin it to the head unit must b
    enuff of an aerial?????
    Holy crap, where did all that rust come from.....
  20. #18
    Nov 2002
    Rochester, NY, USA
    87 Sunbird Turbo GT Conv.
    ack you werid brit's.. It's called an antenna for christs sake, lol.
    Aerial is something int he sky. You're antenna is on the car.
    -Confused american
    Protonus
    aka
    Jim
    1987 Pontiac Sunbird Turbo GT Convertible
    http://www.j-body.org/members/protonus/cars/1
  21. #19
    Oct 2002
    Chester
    Toledo, polo & 20XE
    naaa, ther the things on insects or the big poles on hills to trasmit radio waves
  22. #20
    Mar 2001
    Northwest
    The 1st Phase 4 Calibra
    I feel I need to shout this this to be heard
    1) ALL INTERNAL AERIALS ARE CACK inc THE 12 Volt ones THEY JUST AMPLIFY A BAD SIGNAL
    2) Vaux BEE Stings have an amp in them which works cos its for an external aerial
    ps If you wired in an after market stereo makesure you wire up the electric aerial wire or your FM reception wont be to clever cos on the bee sting this is what powers the amp for it
    Phase 4 nearly done Phase 5 here I come :)
  23. #21
    MIGWeb User selblock's Avatar
    Oct 2002
    [/B]
    what???
  24. #22
    Oct 2000
    Bracknell
    Mondeo, MR2, Manta
    -Confused american
    hey, we invented the language!
  25. #23
    Mar 2001
    Northwest
    Originally posted by selblock
    what???
    Okey doke I will say it again
    If you bought a non vauxhall car radio and put it in your modern vauxhall with a beesting aerial (inc all calibra's as far as I know) or rearwindow aerial (vectra 4dr) Then you must connect up the wire coming from the back of your new car radio that is labelled Electric aerial (probably blue in colour) to the appropriate wire on the loom because these days instead of being used to power an aerial up and down it is used to amplify the incoming signal and make your radio reception better
  26. #24
    Jan 2002
    Suffolk
    Vectra B SRi 150
    And Amerika butchered it lmao
