Astra MK4 Temp Gauge / Engine Swap etc
Page 2 of 2 FirstFirst 1 2
Results 26 to 33 of 33
Thread: Astra MK4 Temp Gauge / Engine Swap etc
  1. #26
    Dec 2004
    plymouth
    Vectra Challenge Car
    Re: Astra MK4 Temp Gauge / Engine Swap etc
    Here's my fix for the Astra mk4 temp gauge/engine conversion problem.
    Cheap £15 LCD temp gauge and a couple hr's modding the standard dials end up with this
    Personally I wouldn't bother emulating the signal for the mk4 astra dials.
    Normaly the ecu feeds the fan control module with the temp signal, the fan control module then feeds the temp gauge, this makes the rad fans work I dependant of the temp gauge.
    Now if you make some board to use With some form of temp sensor to feed the Astra temp gauge you still end up with te big problem of no fans. Seeing as the mk4 Astros don't he a fan switch in the rad it makes things very awkward.
    What needs to be done is you need something to emulate the correct temp aigbal that the ecu would give out, which would go to the fan control module, the module will then work as it should so the fans would work as they should and then the fan/cooling control module sends its own signal to the Astra temp gauge.
    Hope this makes sense as it would be a millions times better to do it that way, also saving people much time and money tryin to sort something out to then get their fans working properly...
    Dom
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Quote Originally Posted by Tomk View Post
    Makes perfect sense and the idea is to have a couple of switched ouputs from my module which will give a two stage fan control if needed without messing about with the engine ECU / cooling module. I've got a feeling (need to investigate though) that the signal that feeds the dash will be the same signal the ECU feeds the cooling module but will have to have a play with the scope when I get some more time.
    Dom's online shop - www.picbits.co.uk/catalog,bulbs,cable,heatshrink etc
  4. #28
    Aug 2012
    Sudbury Suffolk
    Mk4 astra sri ( gsi rep )
    i see your in process of making a few parts that i need for my v6 mk4 astra sri, when and if you put these up for sale il be up for purchasing one for myself ,
    also do you sell the pulse converter for the mk4 astra rev counter to take reading for a 6 cylinder as my rev counter is all over the place if you do sell them, how much would you sell me one for posted
  5. #29
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Possibly relevant thoughts:
    When I wired up a CLET in a Mk4, we left the old ECU in to drive the dash gauge and it worked fine and also turned the fans on when the engine got hot enough, but then the fan light came on and the fans stayed on till ignition cycle.
    Not all Mk4s have the coolant module either.
    They're there, in their room.
  6. #30
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Hi Gary
    Still doing the pulse converters and it should sort out your rev counter problem. They are £35 delivered but I'm in the process of rebuilding the workshop so can't make anything for a few weeks at least. I'm taking advance orders on them and they will be sent out in order of purchase. If you want to bag one you can order it off the webshop and either pay upfront or click on the "check/postal order" option so your order will be on the system but no money will be taken. I'm more than doubling in size the space I have to work in so with a bit of luck can make more stock upfront in the future
  7. #31
    Aug 2012
    Sudbury Suffolk
    Ok thank you thats brilliant il buy one soon as im payed,
  8. #32
    Aug 2012
    Sudbury Suffolk
    Hello again dom , do you have any pulse converters ready to sell ? As id like to sort my rev counter finealy , also have you cracked the temp guage and fan thing yet ?
  9. #33
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Hi Gary - had to stop making all bits and bobs for cars as I couldn't renew my public liability to cover my to make and sell them.
    I may start selling parts to let people build their own at sometime in the near future but I won't be able to sell ready made modules. If you're still interested, create an account on my webshop and when I get back up and running I'll do a mailshot to all customers.
