thinkin about gettin rear coilovers for my corsa b,
just wondering is it a take-out put-in sort of job or is there more to it?
help wud be much appreciated
So so easy mate. Few bolts to do it
INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
404 error: Season not found.
17mm at the bottom of the shock, 13mm(normally) in the boot(might need grips or an adjustable to hold the top of the shock as it will turn), shock will fall out.
Same to refit the coilover.
cheers was hoping it was that so its basically as if i was changing th shock![]()
