Digi dash rev counter help
Results 1 to 17 of 17
Thread: Digi dash rev counter help
    Jul 2009
    west mids
    1.7td corsa van
    Hello i fitted a digi dash to my corsa b 1.7td today, i've got it all working as it should apart from the rev counter its' way out its reading 6k at idle (900rpm)
    Is this a problem with the wiring somehow or just the fact the dash wont work with a diesel?
    Any help is much appreciated
    Sep 2005
    Wisbech
    BMW 320d SE Omega Elite
    Re: Digi dash rev counter help
    Will work but you need a frequency adjuster. Well.covered on here think pic bits sell them?
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    That would be me - £35 delivered and make sure you specify the diesel program if you order one.
    Dom
    Jul 2009
    west mids
    1.7td corsa van
    What do you mean by the diesel program?
    Do you also stock the bulbs as i have a few missing
    Thanks for the help
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    I've got two settings on them - one has a wider frequency range for diesel engines as they have a much higher frequency output than the petrol variants - if you specify the diesel program, when I test the units I can set it to the other range so you don't have to mess about.
    I don't do the bulbs any more - too many idiots trying to pull a fast one so gave up selling them.
    Jul 2009
    west mids
    1.7td corsa van
    Ok how would i find out the diesel program?
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    You order and stick a note on at the end (or drop me an email) that you'd like the diesel program lol. When I program your unit after building it, I put a slightly different bit of software on that copes better with the alternator signal from a diesel.
    If you go to Youtube and stick in picbits in the search you'll get some results with the diesel engines on the digidash.
    Jul 2009
    west mids
    1.7td corsa van
    Oh i get you now, i fought you ment i needed to find the program for my engine or something. Il get one ordered up now,
    Thank you
    Jul 2009
    west mids
    1.7td corsa van
    Can you point me in the right direction for the bulbs please Dom, i need both the big ones (main 3) and the small ones that light up each symbol
    Thanks
    MIGWeb Moderator
    Midlands
    Nowt
    Dont think you can get the main bulbs anymore
    Dom will tell you.
    Aug 2005
    Wilts
    MK2 GTE Conv/Vec CDTi XP
    GTE Mk2 Digidash? You only need two, the 3rd hole is slightly smaller so won't take a big bulb. I got replacements about 18 months ago from Vaux. Weren't cheap mind.. About £6 each, cause they are Halogen rather than standard bulbs. One dealer told me he could only order them in 10's so I'd have to buy the lot, another (same chain) just got me a pair, no problems.
    The symbol ones are just standard auto bulbs IIRC, should be able to get them from a car spares place.
    Jul 2009
    west mids
    1.7td corsa van
    Thanks for that pal will pop into my vocal vaux when i get a chance then and get the small ones from the local motor factors
    MIGWeb Moderator
    Midlands
    Nowt
    Or just get the lot from Vauxhall.
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Yup - Vaux do them and there is another place or two online who is now doing them for a few quid each - the bulb number is 433T - its a 5W 12v halogen.
    Order received by the way - will get your unit out as soon as I've built up a few more units.
    Jul 2009
    west mids
    1.7td corsa van
    Ok thank you Dom, any idea on an eta?
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    I normally quote a 14 working day turnaround on these as they are built from scratch but I've got some boards etched up and drilled so that saves a couple of days. Probably towards the beginning of next week but you'll get a notification email as soon as its in the post.
    Jul 2009
    west mids
    1.7td corsa van
    Ok thank you
