Vauxhall corsa non starter
Results 1 to 8 of 8
Thread: Vauxhall corsa non starter
    Jan 2012
    Shrewsbury
    Vauxhall Corsa Sport
    Hi I've got a 1.6 corsa sport and it won't start just cranks over and over, it's spark and plenty of air fuel, all plugs and ht leads are fine, put the code reader on it and it came up with can sensor incorrect signal, so I changed the sensor and problem still occurs, wondering if it could be the wiring in the engine loom to the sensor plug? Anyone had this problem or come across it before?
    Jan 2012
    Shrewsbury
    Re: Vauxhall corsa non starter
    Cam sensor*
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    Check wiring and all earths. Sports tend to have 2 or 3 earths either side of the engine.
    Jan 2012
    Shrewsbury
    Ive checked them mate there all fine it has been running and then not running and then not running again for about the past month, I had it running wednesday my mate cranked it over and I wiggled the wires from the engine loom plug to cam sensor etc and it fired, ran on 2 cylinders and then revved it and was running on all four, went to start it Thursday and just kept cranking again, possible break or shorting in the wiring?
    MIGWeb Moderator
    Midlands
    Nowt
    Indeed. Strip the wiring back and take a look
    Jan 2012
    Shrewsbury
    Will do have a go at it tomorrow mate, I'll post on here when I can
    Jul 2009
    Tyne & Wear
    Quote Originally Posted by wkdkris View Post
    Check wiring
    I meant using a multi meter and check the wires at both ends to check for breaks etc... should of been clearer
    Jan 2012
    Shrewsbury
    Alrite mate checked everything today, 1 earth was broke I repaired it and still wouldn't fire, nothing comes up on the code reader, pretty confused
