Corsa B C20XE speedo not working
Results 1 to 6 of 6
Thread: Corsa B C20XE speedo not working
    Feb 2012
    hello everyone i have a 97 corsa b that i have put a c20xe into.I have a problem with the speedo not working.The car has an electrical speedo drive and it has a cable drive gear box that is a f18.I have tried a set off sri corsa cable clocks can it still doesnt work as the plug in the back of the clocks are different and i have also tried to build the cable clocks into the original clocks but it doesnt seem to match up.can anyone help me? many thanks
    MIGWeb Moderator
    Midlands
    Nowt
    Re: speedo not working
    corsa 2.0 xe speedo drive
    Loads of info about, that thread should answer your question.
    Jun 2011
    Herts
    Corsa Redtop
    Re: Corsa B C20XE speedo not working
    if ur running a xe with f18/f20 u need cable driven clocks and the cable speedo too.
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    Quote Originally Posted by Jayy View Post
    +1
    Cable box, Cable clocks
    Elecy box, Elecy clocks
    Aug 2008
    Peterborough/ketton
    Corsa
    Quote Originally Posted by wkdkris View Post
    +1
    Wrong, elec box, you need a feed off an abs ring, and a pulse converter, elec clocks.
    Cable box you can use cable clocks with the right cable, or elec clocks using transducer fitted to the box.
    Sent from my BlackBerry 9700 using Tapatalk
    Jul 2009
    Tyne & Wear
    Quote Originally Posted by Gary_808 View Post
    Not all have ABS, infact, very few do. I wasnt saying it was the only way, just the easiest keeping them matched.
    @harkey87 basicaly mate, you need a transducer, and the correct plug, depending on your loom. Or your guna have to use cable clocks with it
