My mum's cally have developed a strange fault, the ignition won't switch off... it can even switch itself on (with the car all locked up).
Tracked it down to a relay hidden behind the fuse panel, I can't get the bugger out but if you tap it you can switch the ignition on/off!!!!
Is this just a main relay for the ignition that's worn out? Wondering if I should buy a new one or get another second hand one
