Corsa Clock Block Connector
Results 1 to 6 of 6
Thread: Corsa Clock Block Connector
    Jun 2011
    Herts
    Corsa Redtop
    i was wondering if all the wires are the same in all corsas for the block that connects into the speedo at the back, reason i ask is im getting sick of my digi dash which i think is the way they are wired up so i want to go back to my old cable clocks, when i converted to digi dash i never broke the wires or the ends of the wires so they can clipped back on to the block but will need to copy a block to connect all the wires up correctly but all i need 2 ask is now i have no backing to hold the block in place will it lock in like before or maybe move about behind the dash?
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Corsa Clock Block Connector
    Not sure what you mean by backing.
    Can you not just cut a plug of one from the scrappy?
    Whats up with the digi dash?
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    I cant make much sense of that.... but if your saying you need a block to check the wires positions, then i can take a picture of mine if you wish....
    And if you mean the wiring block is now lose, and not fitted to the back of the 'pod'...then yeah itl fall about and could be awkward IMO
    Jun 2011
    Herts
    Corsa Redtop
    dam ill have to make a bracket up for block then of some sort then it seems cant remember if i have the backing still .
    yeah was wondering if i copy any speedo block
    Jul 2009
    Tyne & Wear
    yeah should be able to copy any mate
    Jun 2011
    Herts
    Corsa Redtop
    fort so, just wanted to double check. ill pop scrappy soon and cut 1 out
