Vectra 2.2 Sri Y Reg Power Steering Issue
Results 1 to 9 of 9
Thread: Vectra 2.2 Sri Y Reg Power Steering Issue
    Jan 2012
    Hi peeps i am new to this whole forum thing, so please bear with me.
    i have just purchased an Vectra Sri 2.2 Y reg estate and just going over it and finding a couple of issues.
    I noticed that the power steering was making a right old squeal every time i turned the wheel, so i checked the fluid and it was low, i thought that the bloke who i bought it off just didn't check it etc. i filled her up and already after only 30 miles its happening again and saw a big puddle of fluid on my drive, i smelt it and it smells metallic and its too thick for water and too thin for oil so i think its that. It appears to be leaking right at the back of the engine just behind the footwell is and i think thats where the power steering componants live? if so can anyone advise whether this is a common fault on these and what i can do to try and fix the problem. I do have access to a jack and axel stands so I can probably view and fix myself. i think i heard thats it something to do with bolts and washers which are a common fault on these if this is the case can someone advise and maybe send a picture so i can compare to my car? i would really appreciate help and will buy a beer to whoever helps find the right problem on the next big vauxhall meet up.
    One last thing is a rattle when going over light holes in the road from the back, maybe a bush or something, but again any help is much appreciated.
    thanks Steve
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Vectra 2.2 Sri Y Reg Power Steering Issue
    leaking power steering fluid
    Give Vauxhall a call to order parts.
    Rattle could be anything from the exhaust to rear trailing arm bushes.
    Need to get under the car and take a look. Also make sure nothing is loose in the boot, like the jack.
    Jan 2012
    hi thanks for the link, i rang up Vauxhall mentioned the bolts and washers on the rack and the guy there said that this is the only model in which it has a different design or something and it could be the rack which is shed loads to buy and fit etc. my mechanic is going to have a look we are going to fill up the fluid again and see where the leak is coming from, hope its not a rack but you never know.
    i will try that about the rattling, thanks very much for your help
    East Mids Regional Co-ordinator simonsri's Avatar
    Dec 2010
    Chesterfield
    Vectra Sri 150
    recon rack is available for 80 quid from acs power steering i think they are. 01827259699 they will be sorting me one soon.
    Vauxhall, Once Driven Forever Smitten
    May 2009
    Maypole, Birmingham
    V6 Astra Coupe
    Before you buy a new rack check the banjo bolts at the centre of the rack, back of the engine bay.they are common to come loose on the vec b
    Jan 2012
    Excellent thanks guys this forum thing is brilliant i will check the bolts this weekend
    in the mean time i will check that website for the rack just incase thanks simonsri
    Aug 2011
    Vectra b GSI
    Hi, had the same problem on my v6 GSI I found the banjo bolts could be undone with my fingers, my local Vauxhall parts man recommended using copper sump nut washers as they last better than the aluminium ones there a bit of a fiddle to put on but seems to work ok so far. Time will tell.
    Jan 2012
    WOOOOHOOOOOO, just had my car up and had a real good look underneath it, i found that that power steering fluid was leaking from around the rack, and so i ordered some nuts and washers from vauxhall which i will pick up saturday. then i had a idea of checking a bolt which was reachable from the top of the engine with a normal size spanner and found that a nut on top around the steering rack was really loose! Bingo found the issue of the leak! so i put it back up on the ramp and sprayed the area clean started her up and moved the wheel lock to lock a few times and where the leak was there was nothing coming out so fingers crossed that loose nut has solved the issue, i am still gonna go to vauxhall and get the washers etc just incase she decides to leak again but hopefully I have found and sorted the problem.
    Thanks to everyone who has helped me with this issue, now its time to address the knocking noises from the rear lol
    Dec 2010
    Chesterfield
    Vectra Sri 150
    nice one mate glad you sorted it.
    knocking from rear is most likely the dog kennal arb bushes or the rose bushes both common on vec b's
Tags for this Thread
