no power to fuel pump
car was running fine for over a month there (astra mk3 c14nz) went to start it yesterday and nothing no power at the fuel pump again i'm getting power at the relay have had a look at all the wires cant see any breaks or anything can someone advise me on what to look for now thanks
Re: no power to fuel pump
could be
fuse
alarm
aftermarket imboliser
fuse is ok mate and had the imobiliser took out as it failed on me before giving me this problem going to look at all the wiring again
think i have found out the problem its the wires that run from the connector block under the tank to the fuel pump itself because i'm getting power every where else up to that point
