I was thinking of going this route on the cav turbo next due to might not be any room for the next turbo unit to have enough room for the afm pipe..at mo the pipe is kinked between turbo and afm.
I use the ribbed set-up so was wondering couldnt I just go to the astra gte16v pas set-up?...hence the pas pump would be lower on the block then and give more room for my turbo to have the afm pipe from turno to afm sitting un-squashed?
Any info be appreciated.
