1994 Corsa, Cooling fan not working
Results 1 to 3 of 3
Thread: 1994 Corsa, Cooling fan not working
    Jan 2011
    Hull Yorkshire
    Corsa b SRI
    Question 1994 Corsa, Cooling fan not working
    The cooling fan on my 1994 corsa sri (1.4 8v C14SE) has stopped kicking in... its fine while driving as it runs at around 90 degrees anyway but if im sat in traffic it just gets hotter and hotter and the fan doesnt work.
    I have tested the fan direct to the battery and that works fine.
    Ive checked the fan plug with my multimeter and when it gets to about 95 degrees it shows 13v
    so something is telling it to work but could it be possible that there is a relay thats not working properly? or a bad earth somewhere?
    I am a bit lost with this one :/
    Oct 2011
    conon bridge (inverness)
    nothing!
    Re: 1994 Corsa, Cooling fan not working?
    happened to me with the redtop dont know if yours is the same for the 14se but is there a sensor in the thermostat bit it could be faulty thats what my problem was , its just a screw in thing with a spade connection on it
    Jan 2011
    Hull Yorkshire
    Corsa b SRI
    ive fixed it now, it was the fan switch, well that or the plug that clips into it, i replaced the switch in the radiator and snipped the old plug off and fitted a new plug because the contacts were quite grubby.
    im glad it was just something simple
