Rear shoes wearing unevenly
Results 1 to 9 of 9
Thread: Rear shoes wearing unevenly
    Dec 2007
    Letchworth
    Corsa B 1.4 Sport
    Been working on a 106 today. Poor handbrake so took the drums off and this is what i found.
    I noticed no play in the drums before they were removed.
    What could be causing the drums to sit like this and have it still rotate freely without binding up.
    One side had more camber on the shoes than the other.
    Thanks in advance for any replies.
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Rear shoes wearing unevenly
    106's rear brakes are toss
    Sure the self adjusters are working correctly?
    Anyway, stick a new set of shoes and and see how you go.
    Dec 2007
    Letchworth
    Corsa B 1.4 Sport
    The handbrake was almost vertical. When you looked underneath one handbrake cable was taught the other was slack.
    Have tried fitting new shoes with the adjuster completely slack, the drum will go on but is binding on the shoes.
    The drums on the inside have been wirebrushed to get rid of the rusty lip they had.
    I know these cars suffer with beam problems with the bearing going on the arms but not on the stub axels.
    Thanks for your reply Paul
    MIGWeb Moderator
    Midlands
    Nowt
    Not changed the wheel cylinders at all have you?
    Are you 100% sure the parts you have are correct?
    French rear brakes are a pain when ordering parts. So many different shoes etc.
    Dec 2007
    Letchworth
    Corsa B 1.4 Sport
    One wheel cylinder has been changed.
    Shoes have been matched. There are two types for the car and we have the identical ones that came off it.
    I really need to get to the bottom of the uneven wear on the original shoes. Any ideas.
    MIGWeb Moderator
    Midlands
    Nowt
    I really dont see a major issue mate with the wear.
    I'm more concerned with the fact that you cannot even get the drums back on.
    Last one I did was a ball ache. In the end I welded the adjuster. Could not get any bits for it.
    Was an old 93/94 reg one.
    Adjuster was too worn to hold right.
    Made a mental note to quote more money when doing anything French.
    Jul 2009
    Hants/Lincs
    Not sure if the hand brake cable is like the 306 ( 2 parts) but sounds like you will need a new one of them as well if one side is tight while the other is slack
    Dec 2007
    Letchworth
    Corsa B 1.4 Sport
    have put new handbrake cables on the car, not attached them to the handbrake yet though.
    Will have to have a look and see if the adjuster can we wound back an more.
    Thanks for you help guys.
    Dec 2007
    Letchworth
    Corsa B 1.4 Sport
    well got it sorted.
    Paul you were spot on about the adjusters. Took a grinder to them and have been able to give me the extra clearence i needed.
