Bleed nipple size
Results 1 to 6 of 6
Thread: Bleed nipple size
    Apr 2007
    Stuttgart Germany
    Astra Gsi\Skoda Vrs
    Bleed nipple size
    Anyone know what size the bleed nipples are on vectra v6 front 57/25 calipers need to get two and threw out the old ones!
    Cheers
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: Bleed nipple size
    VX do them, cheap as chips just tell them the ones you want and they will order them, get the dust caps while your there
    Apr 2007
    Stuttgart Germany
    Astra Gsi\Skoda Vrs
    That's a real problem over here, they will only order parts with the key number of the car :-/ and then explaining to Germans that you have changed the brakes......well let's just say forget it lol! The problems I have with my skoda, when I give them the vin number they just say Z Key nummer, Ja!
    Not to worry i'll whip a caliper off and measure it with a tap that will give me an idea of the thread size.
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    I'll look at mine and find out for you
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Right the bleed nipples for the vectra B are all the same and also are the same as cavalier mk3, calibra, astra F, carlton, senator, Omega b the GM part number is 90094817 and over here they are nearly £8 each inc VAT without any discounts
    Apr 2007
    Stuttgart Germany
    Astra Gsi\Skoda Vrs
    Cheers Buddy that really Helps as I am near the dealer now!
    Thanks for that!
